Hi All,
I know there are lots of threads on using the H series stubs but I haven't found an answer to whether or not standard Torana brakes will fit on the HQ-HZ stubs? I have seen the options of machined down HQ discs with HQ-HZ calipers etc but not sure if Torana discs and calipers will fit the HQ-HZ stub.
I have LX stubs with a VN Commodore disc, an adapter bracket and Wilwood calipers. I'm thinking about HQ-HZ stubs for the slight drop which I think is 20-25mm and that they are stronger/stiffer.
So I'm wondering if my brakes with the adapter bracket will line up with the mounting holes in the HQ-HZ stub and if standard Torana brakes fit I am thinking it is likely my brakes will fit.
Are the mounting points the same?
Cheers, Tom
