Radiator with a thread connection for a E-Fan switch ?
fan switch
4 replies to this topic
#1 The German
The German
  • 271 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 20 April 2025 - 07:48 PM
Dear Torana friends,
I wonder if there is a manufacturer who builds aluminium radiators with a thread connection for a electric fan switch ?
Otherwise where did you place it ?
Uwe
#2 rodomo
  • 18,080 posts
Posted 20 April 2025 - 08:47 PM
Aluminum is the hard bit. Plenty of switches around but not a lot of ally bosses/nuts to weld in.
#3 76lxhatch
  • 7,227 posts
Posted 21 April 2025 - 06:02 AM
Best spot is in the manifold near the thermostat. Take a look at where most EFI systems put their temperature sensor.
edit: same place as the gauge sensor.
Edited by 76lxhatch, 21 April 2025 - 06:03 AM.
#4 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 24 April 2025 - 01:53 PM
 I drilled and tapped the lower thermostat housing
fitted a 90-95 NO Switch for my thermo fans
#5 RallyRed
  • 8,252 posts
Posted 24 April 2025 - 03:35 PM
Same.
Seems a lot of the older temp senders are
1/8 NPT taper thread.i.e you need a special tap.
Although I notice on the VDO sheets, there's now a few metric threaded ones as well.
