Lower Control Arm too tight?
5 replies to this topic
#1 Liam S
Liam S
  • 97 posts
  • Name:Liam Stephenson
  • Car:LX Torana
Posted 29 April 2025 - 06:42 PM
Hi all,
It appears one of my control arms on LX is too narrow with the bushes installed and doesnt locate correctly in the Frame, possibly the mounting points have been squashed together 10mm when bushes were removed with no mandrel placed between the arm mounts while bushes pressed out?
How do I resolve this? Any tips to expand the mounting points or do I have to get new Lower Control Arms.
Thanks all.
#2 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 02 May 2025 - 09:46 AM
Do you mean the two bushes are now too close together, as in having been pressed in at the same time?
#3 Shiney005
Posted 02 May 2025 - 10:07 AM
Anything steel that has been bent can be unbent.
#4 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 02 May 2025 - 12:32 PM
^^^ Yep.
#5 Liam S
Liam S
  • 97 posts
  • Car:LX Torana
Posted 03 May 2025 - 02:58 PM
Yes that is correct, I am unsure whether the bush is meant to be flush on the flared side, but there is a 10mm difference between the left and right Lower Control Arm.
#6 Liam S
Liam S
  • 97 posts
  • Car:LX Torana
Posted 04 May 2025 - 02:26 PM
Does anyone have any measurements of Lower Control Arms, outside to outside as well as inside to inside?
