Will this setup work for ls3 water temp sensor and original lx ss yellow needle dash?
3 replies to this topic
#1 horsepowerhowie
horsepowerhowie
  • 92 posts
  • Name:Howie
Posted 29 June 2025 - 04:13 AM
Just wanted to know if you can just use this LS adapter and original torana blue ring temperature sensor
on my lx ss yellow needle dash
and what will happen when removing the original LS3 temperature sensor?
Is there a better way?
#2 Dr Terry
Dr Terry
  • 3,359 posts
Posted 29 June 2025 - 10:22 AM
Yes that will work, but you've missed the point
You are meant to leave the original LS3 sensor as is & fit your new 1/8 NPT sensor in the rear of the RHS head at the rear, where there is currently a plug fitted.
Dr Terry
#3 horsepowerhowie
horsepowerhowie
  • 92 posts
  • Name:Howie
Posted 29 June 2025 - 12:46 PM
Thanks bud
#4 ozyozyozy
ozyozyozy
  • 953 posts
Posted 12 July 2025 - 10:31 PM
Also to note, temps of an LS are generally higher than the old 6 and 8’s, so what is normal temp for LS will prob put the guage at, what looks to be over heat.
