Air con clearnace
6 replies to this topic
#1 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 10 August 2025 - 01:59 PM
Hi All
 I’m making some AC mounts to mount my compressor ( 508)
near LH rocker cover
Just wondering is anyone couple give me a idea of bonnet clearance  between the rocker cover highest point and bonnet
my mount will be similar to the 2 pictures attached ( NMP) or in between , possible closer to the green painted torana
#2 Mandarins
Mandarins
  • 18 posts
  • Name:Chris
  • Car:LH SLR 5000
Posted 10 August 2025 - 10:59 PM
Not sure if this helps but I can send a pic of my air con set up. LH.
PM me your email address, file is too big to post here.
Chris
#3 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 12 August 2025 - 05:40 PM
Based on pictures I have seen I have about 10am to spare, on my design
clearance to covers and hoses
Edited by Muzza, 12 August 2025 - 05:47 PM.
#4 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 12 August 2025 - 05:53 PM
From the front, looks high, but isn’t really
#5 dale
dale
  • 78 posts
  • Name:dale
  • Car:ss hatch
Posted 14 August 2025 - 07:21 AM
I am running the same setup and had to ground off the unused mounting lug on the back of the compressor. As you adjust the belt the compressor raises and slightly rotates colckwise. It clears no issues but there isn't much there. I am also running HQ engine mounts which sit the engine a little lower but I think from memory also move the engine forward slightly. Hope this helps. Dale
#6 yel327
  • 13,939 posts
Posted 14 August 2025 - 01:59 PM
These guys do a low side bracket setup specifically for Torana:
https://www.autoware...ressor-mount-2/
#7 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 14 August 2025 - 06:53 PM
I have removed the unused lug to give better clearance with heater hose, I have HQ mounts as well as Tiorana mounts that have been cut down 13mm
 I have looked at this, it won’t work for me, thanks for the suggestion, I’m happy with the way I’m going
