So it’s too hot to be in the shed today, the next few days are all 35+ and I wouldn’t mind a mini break from it. Luckily after this Friday I have three weeks off from work so I can make some solid progress on it during my holidays. I have a few small mini projects to make my space more user friendly I want to achieve during that time off as well.
Since it’s too hot though, I figured I’d just post some progress over the last two weeks or so for everyone to see. Things have been moving along pretty well, some minor roadblocks but plenty of other things to work on.
Last update I had trimmed the rails and started die grinding the stitch welds along the wheel tub seams. This is the finished result:
att.i4VGFvwmpR2Uoxr1Ftt_cLCN7Q436j-RPyu4BCfjkJo.jpeg 109.93K
0 downloads
att.YCeewtR146imepf6XjAzpDCdGBaXS_NSi-uzFRn7cMo.jpeg 126.24K
0 downloads
I still need to do the rest of the seams but I’ve had a bit of a challenging time trying to replicate the shape of the wheel tub where the brake lines go, I want to smooth it out so I cut out the passenger side, after a ridiculous amount of hammer and dolly work and bending over various items in the shed, I was close but not close enough. I even made a stand that I could mount my utility dolly in to so I could sit and hammer away and make it easier with a working position. I ‘borrowed’ some stuff from work and knocked this up:
att.ugOX6g-lk13Fg9SNX2c2cXr7masKNmU9XXPDUQl3DYk.jpeg 86.49K
0 downloads
However, with the compound curve of the wheel tub and the way metal works, I wasn’t able to get the curves exactly how I wanted it. I could have not gotten the curve right but then I’m putting in way too much filler and it will just crack anyway. Here is some photos of the work and the shape:
att.Wd7Ens3P6NCnKciIbVLYPYYIbmHRC3AelwIulT5LGtI.jpeg 115.44K
0 downloads
att.jucmAEPn-6wh536BhJ-reGRIMyBGHEfmcqhSIzV0QzE.jpeg 106.61K
0 downloads
att.C5KESjS3vgbwKpXJCRnuvwrWksqIF4L4Me9t160mpAw.jpeg 105.01K
0 downloads
Turns out one of the guys I work with is good friends with a coach builder and he said he would be happy to let me use some of his tools and show me how to do it and teach me some things so that’s a huge win. Hopefully over my holidays I can make up an accurate wire buck and take it there and shape the metal better with the use of an English wheel and some shrinking and stretching.
I moved on to the firewall, I wanted to smooth this out since I’ll be using an aftermarket heater/air con so I started with where the heater hoses enter the cabin.
Made a hole:
att.bah7e21Yrlt8NG2_TMPezJ6_q1H2V9_WaDHbkBRCNLQ.jpeg 138.68K
0 downloads
Filled the hole:
att.KCgm9Wi6mAykqPwrCryRmha0WyUt4QfECJRXHyna7mU.jpeg 114.88K
0 downloads
This has been planished out and the weld beads ground down.
att.d16PnaEV4HA2LBYq8_DsqNmM58e5-8ocJ1fWvY8i_F0.jpeg 201.9K
0 downloads
You will be able to see I have taken the cowl off the get access to the plenum as well. We have been kissed on the you know what here with a very good plenum overall. I also didn't want too muck around with the A-Pillar caps so I cut in a way that I can mig weld and it will be covered by other panels and will look like it never happened.
att.CZIhyj20X-kXcoDhGH672oQdlZkdrCaf3qcf07nK8PM.jpeg 163.66K
0 downloads
We had previously repaired the area on the passenger side but I’m not happy with what we did so I cut it out:
att.sTqzjzJT85y5IQ01xtIBbN5deh4NX7C4JHCT2i4o4JA.jpeg 134.11K
0 downloads
Considering the overall condition of the plenum, and the fact I have a completely rust free one (back at the start of the thread) I feel selfish taking the part I need from the rust cut as using it in my own car when I’m only going to be blanking it off anyway. The only thing that would make me feel more comfortable if I did it would be if I then repaired the rust cut plenum and sold it to someone who really needs it. I haven’t done anything about this bit yet because it helps with access behind the firewall for planishing tig welds. Will have a think about what I do in due course.
This leads me to another fix up I have had to do. To get access to the repair back in the day, and because I didnt want to go too deep and go above my skill level at the time, we did a less than satisfactory repair on the cowl:
att.ffXdZVtRSNcSEKc6WMKMs1sEHT_NrnZhHwaMSIm86yk.jpeg 146.97K
0 downloads
It is welded under that bog, however because we didn’t have the absolute correct tools we had to overlap part of the top. I’ve now cut this out and fixed it properly:
att.tiEpx8coqvMftBrpIkSGKJ0B9w6VYKR1pe6ZglL99E4.jpeg 153.49K
0 downloads
Before I weld the cowl and plenum back on, I'll be using the KBS 3-step rust treatment and paint to protect it all and some copper weld-thru primer to protect it for years to come.
I’ve now ran out of attachment space for this post so I’ll finish it off in the next one. I didn’t realise I had done this much work in the last two weeks but turns out I’m moving faster than I feel hahaha
Edited by tuxedo123, 17 December 2025 - 10:34 AM.
