Having Cars sit around for months / weeks is not good for the fuel so i thinking of a idea that may help
Vented fuel tanks are supposed to worst than sealed tanks for fuel life so the idea is to put a tap on the vent that can be open when used and closed when the car is stored.
This would cause a problem on hot days with to much pressure in the tank , to over come this problem a Pressure relief valve would also be added
Finding a small enough Pressure relief valve with the right pressure and having a tap that is easy to get to may be a problem
Other things like non vented cap and fuel tap could also be added
Would make it a little bit harder to steal as well if done right
Is this a Good idea or bad and anyone seen / done something similar ?
tank vent1.jpg 41.6K
2 downloads
Edited by UCSLE, 19 September 2025 - 03:14 PM.
