Hydraulic roller cam
6 replies to this topic
#1 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 03 October 2025 - 04:14 PM
Hi All
thinking of heading down the road of Hydraulic roller cam in 253
Roller Cam Crow 51330
Roller cam followers
I have checked valve lift and there is no binding at advertised lift so problems there (.550” max)
Do I need different pushrods?
Can i run std bridges?
 Has anybody run a roller cam in Holden 308 or 253 have a view
#2 yel327
  • 13,939 posts
Posted 03 October 2025 - 05:21 PM
Talk to Crow. They'll know exactly what you nee. You'll probably need stronger springs though.
#3 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 03 October 2025 - 05:38 PM
 I will talk to Crow, stronger springs  not sure if i will need them it isn’t going to see more than 5000 ever, its a Hplate car not a burn out machine
#4 yel327
  • 13,939 posts
Posted 03 October 2025 - 07:54 PM
Roller cans need different spring pressure. Tell they guys at Crow what you have and they’ll advise.
#5 LXCHEV
  • 3,670 posts
Posted 03 October 2025 - 09:05 PM
When I converted my SBC to hydraulic roller, the engine builder used beehive valve springs. Much more modern design with lots of advantages - easier on components etc.
#6 rexy
  • 3,788 posts
Posted 03 October 2025 - 11:08 PM
Its a lot more expensive than doing a flat tappet cam and probably no advantage in a mild street engine.
The best low cost performance improvement you could do is ditch the 253 and build a 308.
#7 Muzza
Muzza
  • 83 posts
  • Name:Muzza
  • Car:LH Torana
Posted 04 October 2025 - 10:56 AM
After reading crows instructions which differ from lunati , I will flat bottom again and follow crows instructions
( the big difference crow request you trail fit and check for rotation of every lifter before final assembly and running)
 Was never chasing huge performance,
