LC - LJ Steering Rack Maintenance
3 replies to this topic
#1 ChrisLC
ChrisLC
  • 107 posts
  • Name:Chris
  • Car:1971 LC Four Door S
Posted 16 October 2025 - 11:47 PM
https://www.ultimate...ering-rack-end/
Has anybody used these rack ends on their LC-LJ steering rack?
Do these rack ends really wear out or do they just need a tighten up?
#2 S pack
Posted 17 October 2025 - 07:51 AM
Yes, the original rack ends can be adjusted. The GMH LC Torana workshop manual outlines the procedure.
From memory, using a spring gauge, the rods should require a load of 25lbs (need to look in the shop manual to confirm lbs) to get them to move and they should move smoothly throughout their arc of travel.
If they do not move smoothly when correctly adjusted then the ball end on the rod & or the seat are worn and need replacement.
Edited by S pack, 17 October 2025 - 07:52 AM.
#3 UCSLE
UCSLE
  • 740 posts
  • Name:troy
  • Car:Goggomobil
Posted 17 October 2025 - 08:04 AM
Those rack ends are crap , bought a pair for my UC and didn't use them
They increase the steering rack width causing bump steer
#4 ChrisLC
ChrisLC
  • 107 posts
  • Name:Chris
Posted 17 October 2025 - 02:13 PM
Thanks for the warning.
