Mal wood hydraulic and Holley sniper efi thread
#1
Posted 13 November 2025 - 07:43 PM
#2
Posted 13 November 2025 - 07:55 PM
#3
Posted 13 November 2025 - 08:08 PM
#4
Posted 13 November 2025 - 08:10 PM
#5
Posted 13 November 2025 - 08:15 PM
Edited by Grumpy72LJ, 13 November 2025 - 08:16 PM.
#6
Posted 13 November 2025 - 08:23 PM
Edited by Grumpy72LJ, 13 November 2025 - 08:25 PM.
#7
Posted 13 November 2025 - 08:27 PM
Edited by Grumpy72LJ, 13 November 2025 - 08:30 PM.
#8
Posted 13 November 2025 - 09:05 PM
33 years programming and I can’t work out how to upload an image.
If you reply to a post , click on the blue box on the bottom right, more reply options.
that will bring you to an option to upload photos on the LHS. If uploading off an iPhone/ipad make sure you reduce the file size.
then put your cursor in your text where you want the photo to appear, and select the use image button ( or. It’s something like that) and you should see a file name pop up in your text where your cursor was. You can check it on the preview post button ( I think on the bottom Rhs)
Edited by 4dabush, 13 November 2025 - 09:06 PM.
#9
Posted 16 November 2025 - 08:48 AM
When I installed the Mal Wood slave in my 179 Aussie M15, I reckon I used 4 shims to get to the low side of required clearance. After bedding in, the thrust bearing was noisy at rest, and inspection revealed that the clearance had decreased to allow it to ride on the fingers. I was able to remove one shim without splitting the engine/trans assembly, by carefully cutting it with offset aviation snips and wrenching it out with multi grips. The rest of the shims were undamaged in the process, and it has been spot on ever since. It did seem that the clearence decrease with bedding in. I hope that helps.
