VH212 Booster Offset
1 reply to this topic
#1 nanbar
nanbar
  • 170 posts
  • Name:Nando Barbanera
  • Car:LC 2 door V8
Posted 23 November 2025 - 11:06 AM
Hi There
Has anyone ever successfully offset a 9" booster away from the rover cover (V8) for clearance? the HK boosters with the offset move the booster towards the motor, I want to go the other way by 15mm.
#2 yel327
Posted 23 November 2025 - 12:18 PM
HK-HG boosters (and others like them) are the same body, it’s the bracket at the back that changes along with the rod actuation. Later HK to HG are direct actuation off the pedal whereas early HK have the linkage actuation. I’d imagine the only way you could do it is do how the early HK are done but mirrored 180deg so it pushes it the opposite way.
