LC/LJ 308/253 Exhaust Manifold
8 replies to this topic
#1 nanbar
nanbar
  • 168 posts
  • Name:Nando Barbanera
  • Car:LC 2 door V8
Posted 05 January 2026 - 05:51 PM
Hi All
I am trawling through the hundred of posts on LC/LJ V8 conversions, in the mean time, I am wondering in the brains trust on here can short cut me to info on the best options for exhaust manifolds that provide the best clearance to the steering staft. I currently run extractors and the shaft has the two  LX/LH couplings. I have seen that people use standard factory manifolds instead which provide better clearance. I'm chasing more clearance but am not sure if its commodore manifolds or HQ-WB ones that I need to use. I have an early style 308 (ie pre VN).
All help/pointers would be appreciated.
Nando
#2 Shiney005
Posted 06 January 2026 - 01:00 PM
I don't know...........but I guess LH / LX would be your best bet?  Some of the 308 Bedford trucks had manifolds that tucked in nice and close as well.
Edited by Shiney005, 06 January 2026 - 01:00 PM.
#3 rexy
  • 3,831 posts
Posted 06 January 2026 - 03:19 PM
It might be easier to modify your existing pipes?
I have custom pipes in both my LJs which are multi piece which makes it very easy to remove them without moving the engine, crossmember or box.
#4 nanbar
nanbar
  • 168 posts
  • Car:LC 2 door V8
Posted 06 January 2026 - 04:30 PM
Thankyou, Ive got it booked into an exhaust place on the 16th, when he looked it before xmas he thought Im pushing shit up hill but he'll give it a go. I looking for plan B.
#5 yel327
  • 13,964 posts
Posted 07 January 2026 - 10:13 AM
LH and LX driver side V8 exhaust manifolds are the same as HT-WB Holden ones (heat tube variation aside). It is the passenger side that differs.
Relevant but slightly off topic:
Does anyone have GMH docs that show why the U-body (Torana) used different V8 engine location via the mount adapters to H-body (HK-HG) and W-body (HQ-WB)?
What I mean is why is the V8 engine in a U-body slightly higher and further forward? Is this to have sump and firewall clearance?
Is the different left side exhaust manifold a result of the engine moving a bit? Or is that required regardless?
#6 Shiney005
Posted 07 January 2026 - 12:43 PM
Both?  Certainly firewall / fan duct clearance.
#7 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 09 January 2026 - 04:35 PM
I always thought it was so the bottom of the sump sat higher than the bottom of the K-frame?
#8 nanbar
nanbar
  • 168 posts
  • Car:LC 2 door V8
Posted 09 January 2026 - 05:29 PM
Sump bottom sitting above the Kframe would be nice in my case, it's one of the issues I have (sump/cross member clearance not enough). Having said that, if the motor sat higher the booster and rocker cover would clash.
#9 gtrboyy
Posted 11 January 2026 - 11:49 AM
Hurricane extractors by Liverpool Exhaust were good...they were 2 piece items.
Used the top & remade bottom piece to clear steering shaft.
Being able to remove bottom piece made them easy to fit.
