Tachometer install
3 replies to this topic
#1 Rana101
Rana101
  • 56 posts
  • Name:Derek
  • Car:Lh
Posted 16 January 2026 - 04:17 PM
Hi all,
   Have just installed an aftermarket tachometer to my LH with 186 and electronic distributor.
all went well although when ignition initially turned on the needle jumps aggressively for around 10 seconds.
 Do i need to put anything in the line to remedy this ?
thank you
Derek
#2 rodomo
  • 18,095 posts
Posted 16 January 2026 - 09:01 PM
Sounds like it doesn't know what's happening. Is it an Ol' Skool tacho?
Try this, turn the crank a bit by hand prior to turning the ignition and tell us what happens?
#3 dron
dron
  • 138 posts
  • Name:Darren
  • Car:UC
Posted 17 January 2026 - 03:07 PM
Some electronic tacos sweep to max rpm on a self test when powered
#4 Rana101
Rana101
  • 56 posts
  • Name:Derek
  • Car:Lh
Posted 18 January 2026 - 06:04 AM
Thanks guys ,
  Is a new tacho , and yes does the sweep , although when comes back to zero jumps aggressively until you bring up revs and it settles was wondering if I need a resistor or something in the line
