Picked up a couple of sixes
3 replies to this topic
#1 Shiney005
  • 10,074 posts
Posted 11 March 2026 - 11:33 AM
The Harvey Ag School had a cleanout and I managed to pick up a 202, a 3.3, and a 186. The first two were on engine stands with radiators and a small control panel to start them. The 186 was lying outside in the grass and I thought there could be some salvageable parts in it.  $500 for the lot.
The 202 and 3.3 hadn't been started in years and the red motor was missing the starter motor.  The blue motor just needed a set of leads, and after a quick initial timing I poured a bit of fuel into the two barrel Holley and it fired up straight away.
They both have the forward dipstick holes through the sump, and although the 202 has it sealed up, the blue motor still has a hole through to the sump at the rear hole. The red motor is also a QL, so I would have thought that would have come from a HZ Holden and therefore should have the rear hole???
The 186 ended up being a boat anchor.
Attached File  Harvey Ag motors (2)small.JPG   261.55K   0 downloads
Attached File  Harvey Ag motors (3)small.JPG   217.04K   0 downloads
Attached File  Harvey Ag motors (5)small.JPG   218.1K   0 downloads
Edited by Shiney005, 11 March 2026 - 11:34 AM.
#2 Shiney005
  • 10,074 posts
Posted 11 March 2026 - 11:35 AM
Attached File  Harvey Ag motors (4)small.JPG   234.13K   1 downloads
Attached File  Harvey Ag motors (6)small.JPG   201.88K   0 downloads
#3 Shiney005
  • 10,074 posts
Posted 11 March 2026 - 11:37 AM
Attached File  Harvey Ag motors (1)small.JPG   428.76K   0 downloads
#4 yel327
  • 14,007 posts
Posted 11 March 2026 - 11:47 AM
The blue one is a 2.85, VD144288 is VC Commodore. The red 202 is a HQ one but it has HX/HZ/VB head and manifolds on it. Both have Commodore sumps on them.
Soak the 186 in molasses/water mix, it clean up and you'll be able to dismantle it. What engine number is on it?
Edited by yel327, 11 March 2026 - 11:48 AM.
