https://cache.gmh-to...boout1small.jpg
https://cache.gmh-to...rboin2small.jpg
Posted 31 July 2006 - 05:37 PM
Posted 31 July 2006 - 06:27 PM
Posted 31 July 2006 - 08:47 PM
Posted 31 July 2006 - 09:42 PM
Posted 31 July 2006 - 10:05 PM
Posted 31 July 2006 - 10:10 PM
Edited by jabba, 31 July 2006 - 10:18 PM.
Posted 31 July 2006 - 10:18 PM
With the STA supercharger on 5.5 psi it made 230 RwKw. Never dynoed it with the turbo.any HP figures dude?
Posted 31 July 2006 - 10:21 PM
Posted 01 August 2006 - 08:10 AM
Posted 01 August 2006 - 08:26 AM
Posted 01 August 2006 - 10:58 AM
Posted 01 August 2006 - 09:38 PM
OK, my basic setup was a near stock 308, machined down flat top pistons, 228/235 @ 050 hyd. cam and standard heads. I used a Redline Maxitork manifold (because it was given to me) and a 450 mech.sec. Holley. As I was on a budget I boost referenced my mech. fuel pump. The Holley had the black plastic floats and I cut the choke housing off. Apart from that it was stock - right down to the jetting. This combo worked really well with about 6 psi of boost. I think I still have a pic of it complete with the STA supercharger, plumbing and intercooler if someone wants to host it. With the STA it was great. From a standing start I could put it in top gear and smoke tyres for as long as you had the nerve to hang on to it. With the turbo you had to wait for it to spool up a bit before it got going, but when it did, hang on !!! Like I said earlier, the turbo was a bit mismatched to my engine, it could have been a lot better.I should have some time tonight to post some more details.
Posted 01 August 2006 - 09:52 PM
Edited by jap-xu1, 01 August 2006 - 09:54 PM.
Posted 01 August 2006 - 10:04 PM
Yeah, raced it there a few times, the HZ raced there a lot too, (green metallic four door).i think i saw your car at the wakefield 1/8 drags about 5 years ago!
like you stated the turbo rear was too large and was pretty useless over th 1/8 mile but im sure it would have been a serious top end stormer on the 1/4 mile!
Posted 01 August 2006 - 10:08 PM
Posted 01 August 2006 - 10:48 PM
Posted 30 October 2006 - 09:26 PM
Edited by LhMusL, 30 October 2006 - 09:28 PM.
Posted 31 October 2006 - 08:30 AM
Yes, engine had stock rods, crank etc.Hey struggler with this 308 turbo you had you pritty much saying that you only really changed the pistons and cam and left the rest of the engine(crank, rods etc) pritty much stock?
Lets say you just put a well matched turbo and a good W/A intercooler on a standard 308, how much boost do you think you could run, and power figures from this. Would want it still to be a daily and reliable so not expecting anything to extreme just realistic. If you go LPG to help with the Compressnio ratio side of things, could a GRA LPG single carb supply enough in a blow through setup??
What would you do on the ignotion side of things??
Just me thinking out loud for a budjet 308 turbo.
Posted 31 October 2006 - 07:00 PM
Posted 20 November 2006 - 08:25 PM
Posted 20 November 2006 - 09:41 PM
Posted 21 November 2006 - 07:02 AM
A 304 would be a fine starting point.Would it be better to start with a 304 so you get the vn heads and rods, plus might be easyer/look better to set up with the GRA carb at the front of the engine instead of on top?
Best option maybe a factory 355????
Don't know what the comp ration is on these though........
Could you get a 308 turbo engineered in victoria, or gulp would you need to go a 253 to get it legal
Posted 21 November 2006 - 11:02 AM
Posted 21 November 2006 - 12:04 PM
On the Cappa website they say you can run up to 10psi on a untouched 304 with there blower kits.. I wonder how long this would last as they reckon it shouldnt have a problem with the correct fuel system..The factory 304 intake is NOT ideal for forced induction. Due to is design some cylinders take all the boost and others lose out. It will blow H/gaskets and melt pistons.
Edited by TORANASS, 21 November 2006 - 12:05 PM.
