monster tacho?
#26
_GTR071_
Posted 28 December 2006 - 12:17 PM
#27
_Barman_
Posted 09 January 2007 - 02:47 PM
Baz
#28
Posted 09 January 2007 - 08:05 PM
And you stole my seat covers...
RIM
#29
_ianshere_
Posted 10 January 2007 - 08:58 PM
I have to agree that the use of monster tacho's and shift lights on puss buckets that belong being used as a starter motor is absolute bollocks!
BUT however the use of shift lights in a high performance vehicle is of a good use because if your busy keeping ya eyes glued to where your going that "big bright light" is a good indication to get ready to shift. Yes you should know your engine but as was stated earlier it all sounds different fom inside a helmet.
NOW if shift lights is something you find useful but you dont like monster tacho's or dont have anywhere to install them then check this neat little sucker out.
https://cache.gmh-to...igitaltacho.jpg
Its a shift light with a inbuilt digital tacho installed in the middle of it.
If your interested in where to purchase these gauges or any others let me know as i import all types of auto gauges and other stuff and can supply to most needs.
ian
#30
_1QUICK LJ_
Posted 11 January 2007 - 01:22 AM
#31
_devilsadvocate_
Posted 11 January 2007 - 04:09 AM
But why do you need them in a street car, do everyone a favour and take them off unless you are at the drags, its possibly the dragsters that have produced this culture of ricers driving around with all these extra rubbish instruments. That obviously annoy most people here because they are just pose value in a road car.......lead from the front and change things . Too much trouble to take off, do you drive around the streets with a helmet and slicks on too?
Another thought would be to have an ear piece in the helmet wired up to a buzzer instead of the shift light and just use a conventional tach if you're only real need is to know when to shift. Then you dont get blinded by the shift light, or have to take your eyes of the road in that 10-14sec adrenalin rush.
#32
Posted 11 January 2007 - 04:28 AM
a tacho in general, not just for redline driving, is a good thing to guage (pardon the pun) engine performance.
i dont think you will need electric shocks to your body tho.
EDIT; i think the shift light along with a rev limiter set up right is cheap insurance if you live life to the fullest.
Edited by ALX76, 11 January 2007 - 04:31 AM.
#33
_1QUICK LJ_
Posted 11 January 2007 - 03:10 PM
Edited by 1QUICK LJ, 11 January 2007 - 03:11 PM.
#34
_1QUICK LJ_
Posted 11 January 2007 - 03:14 PM
#35
Posted 11 January 2007 - 06:08 PM
Interesting suggestion, although with the hearing limitations which occur from wearing a helmet, I think most racers would want to keep as much of their hearing unoccupied by unnecessary noises so that if something goes wrong (whether it's mechanical, or the car you're dragging has an accident etc) you don't have to think twice about what you're listening to.Another thought would be to have an ear piece in the helmet wired up to a buzzer instead of the shift light and just use a conventional tach if you're only real need is to know when to shift.
#36
Posted 11 January 2007 - 06:38 PM
I have to agree with Heath, I want my hearing as free of anything else but that engine noise as possible, so a shift light it is for me..
On the street.. most guys use them as pose value ( especially the rice brigade who run 10,000Rpm tachos on cars that redline or are limited to 5000....
I'm a bit of a freak for gauges and knowing whats happening inside that donk!
The one buzzer i want to install is a low oil pressure buzzer... when oil pressure drops <20Psi.. Triggers a piezo buzzer AND a light to warn of the engine damage coming.. but thats Off topic.
Having said that.. Ive already got my big tach and shift light... But i am SUPER SERIOUSLY looking at Ian's shift light/digital tach there instead. It could be a VERY cool alternative!
Posted 11 January 2007 - 07:51 PM
Yep I like to be in the same position, a perfect example was watching Stubber racing in the Muscle car Masters on TV a few weeks ago, absolutely hauling arse, checks his guages as he comes onto the strait and he has no oil pressure, pulls it over to the side. When you're pushing a car to its limits, things can go wrong quickly and although I don't know what happened afterwards, I would presume looking at that guage would have saved having to rebuild that race motor (which would probably be necessary if he kept it flat to the boards much longer with no oil pressure).I'm a bit of a freak for gauges and knowing whats happening inside that donk!
So yes, guages definately have their advantages, and it's always good to have a tacho in a car just so that you understand exactly what it's doing. Not only for tuning, but you can say "this pinging occurs between x rpm and y rpm" . Instead of like... a and b km/h in this gear hahahaha
And if you know the car half decently, you can judge speed off the tacho, which is often more accurate than a speedo
#38
_devilsadvocate_
Posted 11 January 2007 - 09:40 PM
The standard tacho is fine, just dont see why youd need it the size of a dinner plate, especially if youve got a light that comes on at your desired rpm. Dinner plate tachos are more accurate? Maybe, but the standard tacho offers very good precision, which will be of use to set optimum shift points and really I dont think overall accuracy is that important. ie whether the tacho is +/_ 5% is not going to affect anything.
Don't really understand the reluctance of the buzzer in the helmet. Even though we have five senses, the mind is still troubled by multiple inputs regardless of whether these inputs come through the same medium or different ones. One would be able to anticipate when the buzzer was going to sound, it would just be a prompt to change, rather than having to totally occupy onself thinking where the buzzer is going to go off.
Tiny do install the oil buzzer, its a 5 min job and will cost less than $4 provided you you already have a low pressure oil switch fitted. As posted b4, I have one in the UC, as well as a high intensity led in the dash aimed straight at the driver........had the experience where the oil pressure dropped away when i was driving and I didnt notice the slow drop on the gauge.........gauges are good......but idiot lights and buzzers should also be fitted for oil and temp.
The advantage of a buzzer is unlike a warning light, it simply cant be turned a "blind eye" to, sure weve all heard the "a light came on in the dash but I kept driving, do you think there is a problem"........if the buzzer is irritating enough they wont keep driving! (some of us have to let other people drive our cars) One person that drive my car referred to the oil pressure buzzer as the stall indicator!
#39
Posted 11 January 2007 - 10:04 PM
#40
Posted 12 January 2007 - 02:57 PM
I think the buzzer is a GREAT idea, although on the ign circuilt not the accessory circuit cause it operates while starting the car too!
Warning lights/buzzers are very important as your right.. your not always watching the guage!
_devilsadvocate_
Posted 12 January 2007 - 04:12 PM
Edited by devilsadvocate, 12 January 2007 - 04:15 PM.
#42
Posted 12 January 2007 - 05:01 PM
if you cranking it over till you get enough pressure, wouldnt that defeat the purpose as most wear happens on start up. i was always under the impression to get em going as quick as possible to get the pressure up.I always like to have min oil pressure before firing on the 1st start of the day(possibly achieves nothing in the long run) and crank it over til the pressure light goes out,.
#43
_devilsadvocate_
Posted 12 January 2007 - 05:14 PM
Edited by devilsadvocate, 12 January 2007 - 05:15 PM.
#44
Posted 12 January 2007 - 06:20 PM
in any event oil travels 5 times faster at 1000rpm than at 200 rpm.
#45
_devilsadvocate_
Posted 12 January 2007 - 07:00 PM
ALX76: This maybe true, but Im talking about what I do.....and I dont have roller rockers. One of the reasons I took this action was in several cars I have owned there was a large clatter from the top end of the motor for several seconds on start up....sounded like metal on metal to me(some of it due to hydraulic lifters etc........priming it with the starter 1st, never heard clatter turning it at 200rpm or whatever the starter does.........low speed reduces the interaction.......motor starts no large clatter.^ the top end wears the least, with enduro motors with roller rockers near completly cutting the oil supply off to the top.
There may be some truth in the logic you mention about the bearings needing a minimum speed to achieve lubrication....however, you have also ignored the key factor that speed and wear between moving parts is not linearly based. Also parts of the motor rely on the force of gravity to get the oil in the right spot, in a cold environment how fast the oil gets there depends on how thick it is, not how much oil is pumped to the top of the motor and extra time is of benefit, delaying time before starting the motor. Anyway, Im not suggesting that anyone follows my lead here, I dont have any long term evidence or results with which to support it, and as stated initally it probably makes minimal difference in the long run.
#46
_devilsadvocate_
Posted 12 January 2007 - 07:17 PM
Edited by devilsadvocate, 12 January 2007 - 07:20 PM.
#47
Posted 12 January 2007 - 08:16 PM
is that because the oil filter doesnt have a non return valve?
#48
_devilsadvocate_
Posted 12 January 2007 - 09:03 PM
Edited by devilsadvocate, 12 January 2007 - 09:04 PM.
#49
Posted 12 January 2007 - 09:19 PM
#50
_LXChev366_
Posted 12 January 2007 - 10:29 PM
https://cache.gmh-to...Car/LXDash2.jpg
Shift Light on the left and Oil warning light on the right. Other 2 gauges are Water temp and Oil Pressure. Both My Tacho and MSD 6AL have rev limiters... I have set the 6AL to 6500, the Tacho to 6600 (as a backup). The shift light to 6000. Peak power is 6200 rpm.. Max Ft Lb is 5300... engine will rev to 7000 but to conserve engine life I use 6000 as a shift point... and of course I need to be looking out ahead... I don't need to run any standard Torana gauges so have removed them completely.... its funny I still asked "how fast will she go???? pppffftt I have no idea...(after they stick their head into the car)
Of course street cars cant mount all this like I have....but anyhow, I thought I would show you what I use...
