Door belt rubber clips
51 replies to this topic
#1 torry nut
torry nut
  • 1,474 posts
Posted 29 December 2006 - 04:48 PM
I have been to a number of places and have been told that nobody makes clips to attach new belt rubbers to a LC XU1.
Rare spares makes the rubbers but it seems that nobody makes the clips!
Is this true ???
#2 _LXChev366_
_LXChev366_
Posted 13 January 2007 - 03:29 PM
Good Question, I would like to find out also, but for a LX.
#3 _Toranaman24_
_Toranaman24_
Posted 13 January 2007 - 03:51 PM
hi torry nut,
r u talking about the out side door belt, because 2 days ago i bought the inside and out door belts from a rubber shop for a 2 door LJ and he said that they don't make them with the clips any more, he told us we needed to glue the outside belt on. but the inside one came with clips
im sure u could find spares at ur local wreckers and attatch them some how.
hope it helps
Matt
#4 _rorym_
Posted 13 January 2007 - 04:08 PM
NOPE!..They all break when you try to get them off....this was the LONGEST pain in the arse doing the car!..I made a U shaped puller...looked around until I found a clip that would work and spent 4 days doing the 2 front doors...Only worse job is door pins! Good luck Luke!
#5 _devilsadvocate_
_devilsadvocate_
Posted 13 January 2007 - 05:17 PM
This thread is close to my heart atm. Have been struggling with the inner window sill window seal(is that the belt?) there are clips missing and it appears the only way to try and reinstall the belt to push the clips on is to pull the glass out of the door. Looked at my other UC wreck to see how it was attached and it had small tiny clips, whereas the other used a clip that was much wider and slotted through a 1.5 cm gap in the door.
If anyone wants to compile a "How to do it section on these" there will be at least one reader!
#6 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 13 January 2007 - 05:20 PM
I bought a heap of trim clips at an auction..but i don't know what you are wanting..I might have what you are after.
So a pic or a detailed drawing would help.
#7 _Yella SLuR_
Posted 13 January 2007 - 06:04 PM
Yup, they are a pain in the ass, and I have never been able to remove them without breaking them. I bought some three years ago, but there was some problem with the clips (too wide for the holes). Still need to get some, but haven't gone back and revisited that yet.
LH you have some advantage in that the outer connects into the chrome strip, so it can be removed from the car for fitting.
I know the door belts in the Commondore are glued in, as I've had to reglue 3 of the 4 doors so far.
One of the things I forgot to try buy at the Nats. Get that with old age.
#8 _rorym_
Posted 13 January 2007 - 06:09 PM
The LH ones look heaps easier than the LC ones..They appear to just pop back in the holes..I hope.
#9 _Yella SLuR_
Posted 13 January 2007 - 09:07 PM
Oh, LC ones. Don't know sorry.
If it's of any consequence and you have to resort to glue, I use Quik Grip on the Commodore, same stuff your kitchen laminate is put on with. Applies to both surfaces, let cure for 15 minutes, then push the two surfaces together.
Edited by Yella SLuR, 13 January 2007 - 09:08 PM.
#10 _rorym_
Posted 13 January 2007 - 10:08 PM
And HOPE like all shit they are in the right place! :cry:
#11 rodomo
Posted 13 January 2007 - 11:09 PM
Sikaflex!
#12 _keith1962_
_keith1962_
Posted 14 January 2007 - 09:19 PM
Have you guys been to Spectrum in Sydney?????
because they carry a lot of $h!t for our cars
cheers Keith
#13 torry nut
torry nut
  • 1,474 posts
Posted 15 January 2007 - 06:43 PM
Haven't heard of Spectrum Keith!
Do you know if they have these clips ?
#14 _gtr-xu1_
_gtr-xu1_
Posted 25 January 2007 - 09:10 PM
http://www.spectrumrubber.com.au/
#15 _Yella SLuR_
Posted 26 January 2007 - 01:12 AM
Any luck finding these clips? I broke a couple tonight taking the damn door belts off. Might rip them all out and refit with new clips if you can get them from anywhere. Looks like a simple crimp install through the door belt.
Door belts are still in good condition, so would be a waste getting whole new door belts.
Edited by Yella SLuR, 26 January 2007 - 01:13 AM.
#16 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 26 January 2007 - 12:44 PM
:<_<: can someone post up a pic of exactly what you guys need... i do have contacts you no !!
maybe i can help.. the word is "maybe"
#17 _gtr161s_
_gtr161s_
Posted 26 January 2007 - 01:42 PM
I'd be inclined to try one of the sikaflex products
with glue technologies going leaps and bounds im sure they would have a product to replace those clips\.
they use these types of glue to joint car panel to avoid heat etc, saves time and money for the manufacturer so it must be good
#18 _LXChev366_
_LXChev366_
Posted 26 January 2007 - 09:10 PM
I have taken a photo of the buggers.. but photobucket is offline atm... I can email the photo??
#19 _LXChev366_
_LXChev366_
Posted 26 January 2007 - 09:19 PM
Hey Boomfunk,
check your emails I sent you a pick..
#20 _Yella SLuR_
Posted 26 January 2007 - 10:11 PM
If we can get em, I'll buy a bag of em.
#21 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 27 January 2007 - 08:45 AM
email received, i will look thru some books that i have.
hopefully we can find some, i actually call them weather strips,
watch this space
#22 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 30 January 2007 - 03:34 PM
i have been in contact with someone and waiting to hear back from them as what the go is either possibly -
something similar that will do the job just the same or better or
possibly get made if it doesnt cost an arm/leg
i probably would be looking at around 1000 clips.. we will see what this fellow says
i explained there is a rather large torana comunity needing these special clips :D
#23 torry nut
torry nut
  • 1,474 posts
Posted 30 January 2007 - 06:13 PM
Thats the way Boomfunk!
Keep us posted!
L
#24 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 31 January 2007 - 11:24 AM
update !!, an old sample clip is being sent, he thinks they have what we need
i will beleive it when i see it :D
#25 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 31 January 2007 - 02:40 PM
so l gather people would be interested in these if i can get them ?
