It also sticks with my preferred philosophy of "street car" as the only change is the tyre!
Cheers, and the thought HAD crossed my mind.. Struggler bought my 4.11 Spooled centre to take the temptation away from me
Posted 10 March 2007 - 10:43 AM
Posted 12 March 2007 - 01:30 PM
Posted 13 March 2007 - 11:36 PM
Posted 23 April 2007 - 07:41 PM
Posted 20 May 2007 - 02:11 PM
Posted 20 May 2007 - 08:07 PM
Your eighth mile times and quarter times add up OK, but your terminal speeds should be closer. The 117mph one is obviously incorrect, and even 112 is weird.What is the difference supposed to be between the first 1/8 and the second 1/8th? My quickest time saw a first 1/8th 8.1 @ 87.72mph while the second 1/8th took 4.5 @ 24.81mph, looking at the splits the 60-330ft is also slower than the rest. I was attributing both these to lack of grip early on, would this be a fair conlcusion?
Any other observations are welcome.
Posted 21 May 2007 - 05:38 PM
Posted 21 May 2007 - 06:04 PM
Posted 22 May 2007 - 10:15 AM
Posted 23 May 2007 - 10:45 PM
Posted 23 May 2007 - 11:18 PM
Posted 24 May 2007 - 11:06 AM
Posted 24 May 2007 - 03:06 PM
Edited by devilsadvocate, 24 May 2007 - 03:07 PM.
Posted 24 May 2007 - 08:23 PM
Posted 24 May 2007 - 10:12 PM
Posted 29 June 2007 - 11:30 PM
Posted 12 April 2008 - 06:17 PM
Posted 12 April 2008 - 08:42 PM
Posted 12 April 2008 - 09:41 PM
Posted 13 April 2008 - 08:48 AM
Leave the line at idle if possible. This gives the engine the biggest pump shot possible out of your carb and hits the convertor hardest to make it work properly. If you don't have a transbrake then stalling the car at the line is a waste.
Posted 13 April 2008 - 04:38 PM
Posted 14 April 2008 - 10:20 AM
Yes, I always load up the driveline a bit by raising the rpm to about 1200-1500 rpm but there is no point revving it any harder than this, in fact as I said earlier it is a detriment.Leave the line at idle if possible. This gives the engine the biggest pump shot possible out of your carb and hits the convertor hardest to make it work properly. If you don't have a transbrake then stalling the car at the line is a waste.
Hopefuly not a stupid question, but would this also apply to a stock VT V6 with small street tyres on it? (but in reverse)
The 2 times I have run my Commodore, I loaded my revs up slightly to reduce a bit of wheel spin, or did I, I cant really remember why I did it, it just felt better than dumping the accelerator from idle ...
Posted 14 April 2008 - 05:04 PM
Posted 14 April 2008 - 06:18 PM
Posted 15 April 2008 - 09:06 AM
Exactly.Struggler: I assume your talking about sticking with the same style tyre all round and not mixing bias ply and raidals front/rear? I've run the ET street raidals and my normal street tyres on the front down to around 14Psi at the track ( 14Psi in the rear obviously)
. Am i right in saying that your recommendation is to keep the car stable?
