Have you found it to be neutral with this setup?,...Pushing in the front on the limit or losing the rear?With regard to the suspension setup, its based on information given to me by a chap called Rick Kemp from Toperformance (in melb) This guy has been responsible for suspension setup in a number of racing Torana's, so I thought it was worth going with what he said. He recommended the spring rates and shocks that I run, and it certainly has made a big difference to the way my car handles, which has definately helped my lap times!
The shocks are as follows:
front - koni pt number - 82-5074 (designed for a Pajero!)
rear - koni pt number - 80-2299
Apparently the valving on that particular front shock will suit the spring rate I specified, and to go 1 click off the softest setting. The rear shocks will need to be revalved to go with the heavier rear spring though. I get all my springs made at Industrial Springs here in Adelaide, I just give them the dimensions of the spring (installed height and desired rate) and they make them.
The other thing to take into account is that I run a light front sway bar. Its the Kmac 24mm adjustable front mount type and I run NO rear bar at all. I've tried it with and without, and without suits my driving style the best. The fact that it runs a full spool 3.8 ratio diff also plays a part in how it feels (handling wise) - in racing conditions.
I'm not one to hide what I'm running, as far as I'm concerned if its working and been of benefit to me, then why not share the info..
Somthing else to consider, different ppl like the car to handle different ways, or should I say, feel more comfortable with the car setup a certain way... Some like it to push, others like it more pointy... Really you just have to get out there with a base line setup, if you dont like it, make adjustments ONE AT A TIME, try it out and record the results. THERE IS NO ONE SETUP THAT SUITS EVERYONE!
hope this helps!
cheers,
Sam
