The Shed Thread
884 replies to this topic
#551 Rockoz
Posted 02 July 2014 - 11:06 PM
Got power to the shed yet Datto?
#552 dattoman
Posted 02 July 2014 - 11:35 PM
Nope.... couple of candles
2 more sets of racking to go in... trip to Bali (Mrs idea) then I can get power
Waiting on the missing Dan to emerge with some sockets and plugs we spoke about he has to share first
#553 Ice
Posted 02 July 2014 - 11:39 PM
Do you want some flouros Neil
#554 N/A-PWR
Posted 02 July 2014 - 11:50 PM
my shed has 11 double fluro jobs.
and need another 11  double fluro's I recond, plus another slow combustion fire
just to feel comfy
#555 dattoman
Posted 03 July 2014 - 12:09 AM
Yup
Salvaged 5 out of the old shed that will go up on the mezz... so definalty need more for over the benches
#556 Ice
Posted 03 July 2014 - 12:10 AM
I will see what i can muster up for you
#557 Rockoz
Posted 03 July 2014 - 10:02 AM
Im hoping you will be running conduit from the house to the shed.
Fork out the bit of extra dollars and run 50mm conduit.
If you have a compressor dont worry about putting cables or draw wires in. Just put them in the ground glued up well.
You can pull the cables through later.
Run 16mm2 cables to the shed. Will reduce voltage drop and allow you to use more stuff easily.
Put in at least another 25mm conduit in the trench. It can be used for phone/data etc
#558 dattoman
Posted 03 July 2014 - 11:55 PM
Shall let the elec guy sort all that and the new board in the house
Apparently mines old and needs more RCD's or something
Shall advise him when the time comes of your recommendation
#559 N/A-PWR
Posted 04 July 2014 - 12:04 AM
I got 50square mm single phase, metal shielded with a conduit beside having a Cat5 cable it there
comes from a 240vac 100 amp transformer
and the Telstra cable connection point
#560 Rockoz
Posted 04 July 2014 - 10:31 AM
If your budget can handle it make sure he uses seperate RCDs on the circuits.
Nothing worse than having 3 circuits on the 1 RCD then having a little fault dropping power to almost everything
#561 _Liam_
_Liam_
Posted 15 August 2014 - 04:50 PM
Well hopefully within the month will have my new shed up, measurements are 12 x 9 x 3.6 eaves.  Even have some nice Algoa pallet racking to put in there and makes it into a shelving/ workbench unit.  Then after that, some new toys to fill it, mainly a new MIG, Panbrake/guillotine, bead roller, English Wheel, Lathe and Mill and Air compressor.  Can't wait.
#562 _mumbo_
_mumbo_
Posted 16 August 2014 - 07:41 AM
Mine went up this week so I will be able to bring MUMBO home next week.
Looks huge but it's only 7/8
Attached File  image.jpg   217.85K   8 downloads
Attached File  image.jpg   107.59K   9 downloads
Attached File  image.jpg   134.03K   8 downloads
Attached File  image.jpg   149.08K   8 downloads
Going to start on racking and benches after work today then just needs wiring
#563 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 16 August 2014 - 10:09 AM
Only 7/8....
Wish i had built a bigger shed now, might have to save for an extension.
#564 _Liam_
_Liam_
Posted 16 August 2014 - 11:24 AM
I originally wanted 18 x 9 but the missus decided it wasn't necessary
#565 Potta
Posted 17 August 2014 - 01:18 AM
Mezz floor is go
Saw this in person the other day and it's awesome!
So much space up on the mez, well done Datto, well thought out mate.
#566 N/A-PWR
Posted 17 August 2014 - 01:55 AM
Looks really good Kevin
#567 _mumbo_
_mumbo_
Posted 17 August 2014 - 07:37 PM
Started putting racking together
Attached File  image.jpg   111.22K   9 downloads
It is big enough for 2 cars ;)
Attached File  image.jpg   159.93K   9 downloads
Went and picked up Mumbo this morning and she is now sitting in her new home C10 is in the old shed
#568 N/A-PWR
Posted 17 August 2014 - 07:47 PM
Very Nice Kevin,
So another Working Bee, and BBQ coming up, Yay
#569 _Liam_
_Liam_
Posted 21 August 2014 - 05:39 PM
So I left Bunnings and gave my mate Evan a call. He had coated his floor in a 2 part 2pac Epoxy. After looking at his after 3 years of use I was very happy to go that way.
$500 later, I came home with this.
Acid washed the floor and get ready for paint.
Laid down 2 coats over 5 days resulting in this. (Its still wet)
Hey mate, where abouts did you get the Epoxy from?
#570 Evan
Evan
  • 1,287 posts
Posted 21 August 2014 - 11:01 PM
Liam
http://www.cameleon.com.au/
#571 rodomo
Posted 25 October 2014 - 10:19 PM
I just need a good erection to get it up.......................Single phase, 2 poster $1880 delivered.
Got this working today....................finally!
Note the new bit of slab. The original wasn't thick enough. I bought and drilled 2 spreader plates and was also going to tie it to the roof trusses but my "guardian angel" wasn't happy with that so new slab. ($850)
I Googled Subaru and it's Japanese for "to fly"
#572 Potta
Posted 26 October 2014 - 02:03 AM
Do I spy the Torana in the corner?
Much nicer than the old shack that it used to live in.
#573 rodomo
Posted 26 October 2014 - 10:25 AM
Yes mate. I was hoping it was gunna be the first car on the hoist but the Sooby has done a wheel bearing...................and a couple of rack boots..............and the CV boot.................not to mention oil leaks and paint falling off.
#574 _Macca97_
_Macca97_
Posted 26 October 2014 - 01:23 PM
heres our place with the 2 sheds, house is tinny compared to them, one closest is 12x18 5m high in the middle, adding another 6m to the side soon, other shed is about 9x12 thats just throw crap in there and forget,  all sits on 20acres loads of fun :)
#575 ben23
ben23
  • 262 posts
  • Name:Ben
  • Car:'77 LX 2850 sedan
Posted 14 January 2015 - 11:28 PM
Still living with my parents, a drive through single garage with a single carport out the back has seen many cars since my first and not just mine either, do my best to keep it clean. A mate and I are going to go halves on renting a small industrial workshop unit near us so we can have somewhere to work properly and keep cars out of the weather.
Currently putting up a small 3 x 2.5 garden shed next to the existing one to move all seldom used but cant get rid of stuff out of the garage so its purely just tools and car related stuff. Have an electric door opener to go on the front roller and plan to use the wrong paint we bought to do the house with to paint the garage, although seeing as I'm probably going to be moving the Torana to the unit I won't be spending much time in the garage (or at home for that matter)
