our N/A 202 is into the 12's
#51
_big_als_army_
Posted 15 July 2007 - 10:34 AM
12.79 is a mad time for a 6 cyl mate. You should be proud of all the r & d you've put into it as its paying off for you. Good stuff. Keep it up and I am looking forward to hearing of bigger and better things from you and this car.
#52
_Drag lc_
Posted 15 July 2007 - 10:39 AM
Thanks Hayden
#53
Posted 15 July 2007 - 10:01 PM
#54
Posted 15 July 2007 - 11:55 PM
#55
Posted 16 July 2007 - 03:06 PM
it's not had to get one to run 12sec, spend a little bit of money. A good head and right camshaft, and any 1000kilo lc will run a 12esc 1/4On another note we had our lc at the strip again friday night and ran even faster with a 12.79 @ 105.38 we are now going to put this engine on methanol and try again in a month or so.
Thanks Hayden
#56
_draglc_
Posted 17 July 2007 - 01:42 PM
member 44.. i was first
#57
_big_als_army_
Posted 17 July 2007 - 01:49 PM
I'm surprised that the second username was allowed. I'd be pissed if I was you A1.
#58
Posted 17 July 2007 - 05:44 PM
Drag thats tough...any Torry six that runs 12s is a serious eye opener to the ricers..well do matey and keep going. Must piss off HSVs when you smoke em too!all you people talking up v8 this and v8 that i would like to say this if we wanted a v8 like 99% of the cars at the strip we would have one but we want to be diffrent and like a challange
,i know we are no match for a real v8. so if you could please take the argument elsewear that would be great.
On another note we had our lc at the strip again friday night and ran even faster with a 12.79 @ 105.38 we are now going to put this engine on methanol and try again in a month or so.![]()
Thanks Hayden
P.S...I think you should change Andrews to Drag308LC
Edited by rorym, 17 July 2007 - 05:45 PM.
#59
_70rey_
Posted 17 July 2007 - 10:11 PM
u had her dynod yet if so can you let us know what you got? id love to know
#60
Posted 17 July 2007 - 10:48 PM
#61
_dave720gtr_
Posted 18 July 2007 - 10:27 AM
Yes but its just too easy to drop a v8 in one and run good times" big deal"At the drag strip its different. There are so many V8 LC/LJ's. Why? Because they pull good times, easily. You aren't ringing a V8's neck trying to run a mid to high 12 like you are a 6 cyl.
any one can do that ..
cross member/ chassi kit .9"diff.big brakes. it all adds up. i have driven plenty of both v8 and 6 lj lcs and thay feel totaly diffrent handling wise !but we will not go there..beause in the end it all comes down to who set the car up .and for what reason!
Six in a row is the way to go! hayden . i would be thinking them webbers on alcohol would be better than a 4 barrel holley,bring your comp up to 12.1.you can also get alcohol needle kits for SU carbis a good freind run a hemi 265 with 2" SUs on alcohol for some years.
Give your self a big pat on the back hayden ! you got it flying
Just as a side note: i saw many years ago at willowbank an all steel street driven EH station wagon 186 webbers run a 12.8 on 13" slicks.
cheers good luck
Edited by dave720gtr, 18 July 2007 - 10:31 AM.
#62
_Drag lc_
Posted 21 July 2007 - 09:33 AM
we have not had it on a dyno as yet.
#63
Posted 21 July 2007 - 03:45 PM
If it's a drag only engine then bump it to like 14:1 and run straight alcohol and see where it takes ya!
But i think that staying where you are from the fuel is a good thing.
I'd be concerned about fuel delivery from a 4 barrel on an inline 6... Wouldnt the acceleration forces be enough to pull the fuel mixture toward teh rear cylinders thus leaning out the fronts slightly?
Just something that comes to mind when i think about the situation.
As dave said ^... No matter where yo go from here.. Youve dead set got that thing flying! You do deserve a pat on the back!
Tiny.
#64
Posted 22 July 2007 - 10:55 AM
If you intend to run methanol, as tiny said, bump up the compression, 11.1 is the bordeline you would run methanol on.
as for the four barrel, it will need to be properly tuned to run the methanol (i think somewhere back somewhere, you mentioned it was off a car that ran meth anyway) but if it wasnt off a meth car then it will need modifying to run methanol. im assuming your fuel system is all braided anyway? as rubber hose is no good, as is anything plastic really.
Tinys suggestion re: aceleration forces does have some warrant, but the effect it has is minimal, and from what my old man explained the methanol moves "slower" when its in the vapour mixture, so the effect on a 4 barrel running meth is less then that on one running petroleum.
anything else?
Cheers Chris
#65
_Drag lc_
Posted 23 July 2007 - 07:33 PM
Thanks Hayden
#66
_runna_202_
Posted 23 July 2007 - 08:12 PM
to run on alcohol by jb race engines, and it ran 12.7 with automatic transmission, and 9in.
Before that they had webbers on pump gas and managed the best of 13.0, so obviously those big carbs get them old stick motors going on methanol?
