LC S 2250 Sleeper
42 replies to this topic
#26 _big_als_army_
_big_als_army_
Posted 13 July 2007 - 04:35 PM
Probably something similar to your member name. No seriously, thats all for now... I think.
#27 _holdon_
_holdon_
Posted 24 July 2007 - 04:07 PM
regarding the lh brakes - how much better are they than the lc brakes?
i too am building a v8 lc - and im susing out the options for brakes.
#28 _big_als_army_
_big_als_army_
Posted 24 July 2007 - 04:16 PM
LC/LJ brakes are better I reckon but an engineer won't pass them. LH V8 is the minimum requirement. I have complete HJ stubs, discs, iron calipers, etc. on my V8 GTR which work really well and are a straight bolt up application like these were but I wanted to stick with Torana stud pattern on the LC and be able to run 13" rims so I went for these LH ones. It depends on what stud pattern you want to run, etc. Apparently you can turn down some HQ discs to be the same diameter as LC/LJ ones and bolt them and the matching HQ calipers straight up to LC/LJ stub sxles. There is a small amount of clearance grinding that may need doing but it doesn't throw the steering out which happens with the use of HQ type stubs.
#29 _holdon_
_holdon_
Posted 24 July 2007 - 04:28 PM
hmm - well it seems that xu1 disks are 'better than std' which is the requirements for brakes for a lc v8 here in QLD. with xu1 brakes - can i use the std calipers? or are xu1 disks too wide? are these easily sourced/expensive?
sorry to thread steal
#30 _JBird_
_JBird_
Posted 24 July 2007 - 04:34 PM
There's little caliper spacers for the XU-1 disc clearance, Holdon.
#31 _big_als_army_
_big_als_army_
XU-1 discs and calipers are the same as HK/HT/HG V8 ones. They are the same 6 cyl calipers but with a spacer in the middle to clear the same diameter but slightly thicker discs. I have heard of people getting knocked back by engineers in NSW for trying to run these brakes even though they pulled up the 327 and 350 SBC powered HK/HT/HG GTS Monaros and would have been standard fitment had the LJ XU-1 V8 gone ahead. I have a pair of these calipers and discs here too but I'm using them on my V8 HG ute. If you can get away with it, use the XU-1 / V8 HK/HT/HG type ones. You can get repro spacer plates, split your standard calipers and add them to the centre and get the thicker discs new.
#32 _MAWLER_
_MAWLER_
Posted 24 July 2007 - 05:15 PM
Love the projects where you receive all the updates at once. Takes all the impatient waiting out of it :). Good stuff happening, will be great fun when finished.
#33 micklx
micklx
  • 1,785 posts
Posted 24 July 2007 - 07:19 PM
Looks like an awesome project, the way things have gone so far, I won't be surprised if a big block goes in in a month or two....
#34 gtrboyy
Posted 24 July 2007 - 09:34 PM
That thing will be fun with 13's on it lol.
#35 _tyre fryer_
_tyre fryer_
Posted 24 July 2007 - 10:57 PM
so what will be next once that lot is done
a blower!!
sleepers are my favourite....
what's happening with Keithy's btw?
very nice Al. I absolutely love that car no matter what engine it has, simply gorgeous. 2 tone is great.
anybody else got a good sleeper story?
#36 _high_rpm_
_high_rpm_
Posted 25 July 2007 - 01:00 AM
my torry's such a sleeper its been sleeping for 18 months lol
#37 _big_als_army_
_big_als_army_
Posted 07 August 2007 - 12:01 PM
I turned the column shift column into a blank column to get rid of the ugly gear shift knuckle and shift levers at the bottom. I just ground off the column shift knuckle on the one that was in my LC and filed it smooth in that area. I also took the whole thing apart and the two shift levers at the bottom I took out, ground the ends off and re-fitted them to the column so it all holds together properly again. It probably took me about an hour to pull the column out and modify it and saved me the cost of a blank column which is well over $100. I've seen people just take the column shift lever off and leave the knuckle and shifting levers at the bottom which looks crap. Its pretty easy to get rid of them. Now I just have to fill the small hole where the knuckle was, paint and refit it.
#38 _Machine_
_Machine_
Posted 10 August 2007 - 02:01 AM
In WA the LJ standard brakes are fine; this is from an engineer.
M.
#39 _why-psi_
_why-psi_
Posted 10 August 2007 - 08:20 AM
i used the knuckle on the column as a mounting for a monster tach. fits perfect and looks "factory" almost lol
#40 _@milco@_
_@milco@_
Posted 10 August 2007 - 08:24 AM
yeah i did that with my last LJ 4 door.
#41 red6
red6
  • 591 posts
  • Car:1971 Lc Torana S 2 Door
Posted 10 August 2007 - 03:40 PM
do either of you guys have pics of your tachos mounted like this? id be keen to see them
#42 Heath
Posted 10 August 2007 - 04:47 PM
Same.
#43 _big_als_army_
_big_als_army_
Posted 11 November 2007 - 12:26 PM
I've modified the steering shaft to clear the V8 extractors and moved over and refitted the steering column.
With a new LJ 2 door on its way and the decision to return my V8 GTR back to original, this build will be completed and the car offered for sale in one of many forms I've not yet decided on. See the final build options here.
