My crossmember rebuild
37 replies to this topic
#26 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 03 February 2006 - 06:53 AM
Marty I hope you dont plan on running those 15" simmons with the hoppers kit?
I have spoken to Pete from Hoppers and he says to run 15 inch Simmons you get 8mm spacers so the bolts don't hit the calipers.
s
#27 _QIKSLR_
_QIKSLR_
Posted 03 February 2006 - 10:50 AM
M@;
Thanks for the info mate. So it definatly sounds like I'm better off going with HQ stubs with the A9X steering arms. I will definatly take you up on the sketch. I've been playing around with autocad myself and i love it. I'm not sure on the front wheel specs. I've got the rear end completly sorted, but the fronts are still wrong. They were off an HQ so the front's sit in too far. I'm pretty sure I will be able to make up the track with fatter tyres, otherwise I may need wider outers. I've never actually had the front wheels fitted at the same time as the flares, so I'm not sure. I'm pretty sure that there is no backspacing on them (4"outer/4"inner).
LS1LX;
I had heard the same as what Stephen said about the spacers. As I said above, I need all the track I can get, so pushing the wheels out with a spacer should help the situation, providing it doesn't throw the geometry out.
Stephen;
I'm in Sydney mate. I wont be sending much away to get done. The only thing I can think of is getting the bushes pressed in and out. I'll be buying the balljoints from repco and fitting myself and Robbos Spares in Blacktown can hook me up with an exchange steering rack, I was told about $180 from memory.
Edited by QIKSLR, 03 February 2006 - 10:53 AM.
#28 Dangerous
Dangerous
  • 948 posts
Posted 03 February 2006 - 01:41 PM
G'day guys,
I have wanted to get a few people to check something for me on their Torana front subframes - should be useful info to all as well.
I have heard these front subframes were prone to bending. Just wondering what measurement your front subframes are across the top mounting holes (centre to centre) where the subframe bolts to the chassis.
Yep, I've 'porta-powered' a few LH/LX front ends to get them back into spec because they'd sagged. Offhand I can't remember the specs, but I recall that the measurements for the chassis rails (including the holes for the front suspension) are either in the original LH manual in the 'body' section, or that I worked them out based on the measurements in the manual.
#29 _CHOPPER_
Posted 03 February 2006 - 05:38 PM
I have those measurements in front of me. However, it's not for the ones we have been comparing. The specs are for the nuts that hold the bumper bar bracket. They come to 790.0 MM from the factory.
#30 _rorym_
Posted 23 January 2007 - 09:24 PM
Great! NOT!..My UC 4 cyl front measures 785mmF 790MM r...what next? OK..Rechecked..at the top of the pins...and 792f and 794mmr at the holes..whew!!..had panic there for a while
Edited by rorym, 23 January 2007 - 09:31 PM.
#31 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 January 2007 - 11:25 AM
re-drill the upper control arm mounts and inch lower as per the A9Xs and remove the steering bush.
I've redrilled the upper control arm mounts and ground off the mount for the steering nuckle shroud.
Why are you removing the mount for the steering knuckle shroud and removing the steering bush?
Oh yeah the LX has a steering ratio of 18:1,
the UC 20:1,
the A9X 25:1
You can tell which box you have by the numbers on them, I'm sure someone here will post them.
s
#32 _rorym_
Posted 28 January 2007 - 02:40 PM
Thanks Steve...UC one looks the goods again.
#33 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 16 February 2007 - 11:26 AM
Here is a pic of the upper balljoint in my LX - these are the Repco upper type.
I notice they are bolted in. My ball joints have rivets, are these going to be a drama to remove when necessary?
#34 TerrA LX
Posted 16 February 2007 - 12:07 PM
^ 4" angle grinder removes the rivets but the uppers very rarely wear, i would only replace them if they show signs of wear or the boots have been letting in dirt and crap.
#35 _rorym_
Posted 16 February 2007 - 02:53 PM
Cheap as chips...do them anyway if the front end is out.
#36 _rorym_
Posted 16 February 2007 - 03:05 PM
the UC 20:1,
the A9X 25:1
So the higher the number the quicker the ratio>?..I thought it was the other way?
#37 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 16 February 2007 - 07:20 PM
I took the control arms to the mechanic to have the bushes removed and he said the ball joints looked ok and didn't think they needed replacing.
I just thought it would make it a hell of a lot easier to have bolt in ones should they fail later on.
s
#38 Statler
Posted 05 March 2007 - 04:45 PM
Can i ask a couple of quick questions?
I thought the top control arm mounting holes were HIGHER on the UC?
When used with the UC top control arms, instant A9X?
Why would you re drill the mount holes lower? LH/LX pre RTS?
