Spark plug gap setting
63 replies to this topic
#51 rodomo
Posted 27 June 2008 - 07:51 PM
O.K. sorry :D
Did you fit the electronic dissy after Terry looked at it?
It sounds like the dissy might have just moved on it's own, like a loose clamp?
With the pinging, that tells me it is too far advanced and the timing needs re-setting.
Worse case is your plastic gear has allowed it to jump a tooth or 2.
#52 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 27 June 2008 - 10:41 PM
Thats cool mate, sorry for sounding rude, was just in a shit mood.
Yeah the nrma guy said the tooth could of jumped a cog or 2 aswell. I took the cog out and its stripped off one little tooth. Best to get a new cog and re-fit? I odnt have to set timign and all that again right mate? Just line up the timing marks and put the dissy in at the timing marks?
#53 rodomo
Posted 27 June 2008 - 10:47 PM
You will have to find No.1 firing but do that before you pull the dissy out.
That way you will get an idea where it goes back. Take note of where the rotor button is pointing. It may still not be right, though maybe enough to get it running. It will need to be timed with a timing light after.
The plastic gear is available from Bursons or the one off you old points dissy is the same part.
#54 TerrA LX
Posted 27 June 2008 - 11:47 PM
^^ Looks like we will have to start all over again.
#55 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 28 June 2008 - 10:27 AM
Really :S.. so its too late to just get a new dizzy gear and put it back in with the timing marks.. I thought thats what electronic dizzy's are for :(
#56 TerrA LX
Posted 28 June 2008 - 04:44 PM
Every time u remove a dizzy (elect or points) you will need to re time it.
#57 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 29 June 2008 - 10:42 PM
What is the correct timing? 6 degree's still or is it different now because I have th HEI ignition?
#58 rodomo
Posted 29 June 2008 - 10:50 PM
If it was 6 before it should be O.K.
#59 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 30 June 2008 - 05:28 PM
hmm.. I may need the infamous Ultra-TerryTune to come to the rescue :P
#60 TerrA LX
Posted 30 June 2008 - 06:28 PM
^ booked solid ATM, but get that cog sorted and let me know how ur traveling.
#61 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 30 June 2008 - 06:34 PM
No worries mate, I'll put the new one on and try get it running.
Not too desperate atm anyways, cheers mate
#62 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 08 July 2008 - 01:29 PM
Hey Terry let me know when you can come around, called up every hiring store in Syd, nobody seems to have a friggen' timing light to hire! Peddy money and brews for your troubles (again),
cheers mate
#63 TerrA LX
Posted 08 July 2008 - 10:12 PM
cheers mate
Maybe the 11th after 2pm or the 15th after 6pm if that suites, let me know and make sure you remind me o.k.
Edited by ALX76, 08 July 2008 - 10:15 PM.
#64 _Chriskoss-79uc_
_Chriskoss-79uc_
Posted 09 July 2008 - 01:34 AM
yeh anytime is fine mate, on holidays :) . I'll remind you closer to the dates.
