Commodore booster and Master on LH/X.
#1
Posted 27 January 2009 - 07:23 PM
Posted 27 January 2009 - 07:33 PM
Question time
Is it an LH or an LX ?
Does it originally have a straight rod or bent rod to pedal ?
#3
Posted 27 January 2009 - 10:07 PM
Edited by rorym, 27 January 2009 - 10:09 PM.
#4
_rocket_
Posted 28 January 2009 - 07:31 AM
#5
Posted 28 January 2009 - 08:01 AM
rod is 6mm too long........so i have been told.
#6
Posted 28 January 2009 - 08:47 AM
The have almost identical bolt pattern to a Torana one but smaller studs going thru the firewall so they will boilt in
Now the rod on a straight car... all LH and LX till about Dec 76
If its a straight rod one you can cut and reweld the rod straight and it will go onto the Torana
If its a bent rod one its abit harder but not impossible... cut the rods on both boosters and fit the bent one to the Commy booster is an easy way if your not stripping the booster for overhaul
If the booster is apart you can swap the rods
I use P10050 XC/E Falcon master cylinders cause they are 1" and cheaper than 1" Commodore ones
#7
Posted 28 January 2009 - 09:04 AM
_slydog71_
Posted 29 January 2009 - 06:32 PM
1 RVH346 MR Special upgrade brake booster to suit ford master cylinder
1 P10050 Ford B/M/ Cylinder
1 K8815 Caliper kit
1 BF17 Bleeder repair kit
1 DB2470 caliper piston
3 P4285 tube nuts
3 M202-3 pipe adaptors
3 P555 tube nuts
rorym half of this is not required as I had some other work done at the same time , unsure if part no.s still exist maybe datto (who seems to be the brake guru can verify)
Why did I do this upgrade because I hated seeing the proporting valve in the engine bay now have a similar look to the a9x , pretty anal I know .
My car is a 1977 LX
Edited by slydog71, 29 January 2009 - 06:33 PM.
#9
_brett_32i_
Posted 29 January 2009 - 07:03 PM
bent push rod will give you improved pedal ratio. i would advise to lower the push rod on the pedal as much as you can (maybe only 5 or 10mm) to further improve it.
#10
Posted 02 February 2009 - 09:19 PM
Ytahnks, Max
#11
Posted 02 February 2009 - 09:25 PM
Thats right
Or 5.41" in my old PBR books
Same same
The bent rod is also 5.41" but the eye is lower down the pedal by about.... um... approx 8mm.... but someone will have to measure that I don't have a pushrod handy
Edited by dattoman, 02 February 2009 - 09:27 PM.
#12
Posted 02 February 2009 - 09:34 PM
I have shortened the VL booster rod and have threaded it for mm adjustment. Overdone I know but ..............
Thanks Datto
#13
Posted 02 February 2009 - 11:06 PM
Which style is better for a 4 wheel disc setup?Yup
Thats right
Same same
I understand that for a given amount of pedal movement the bent pushrod will move further but with less force than the straight pushrod. Is the difference significant?
#14
_1ARC_
Posted 04 February 2009 - 10:53 AM
#15
Posted 04 February 2009 - 11:12 AM
Will the XD proportioning valve crake point be similar to that of the LX configuration
We fitted up a XD M/C to the std torana booster years back. There were no mods required to the booster or m/s i can recall.
Ok.....so the memory is a little fuzzy.....but i think the threads for the brake lines are metric, but the tory is imperial?
I remember changing the brake lines, but cant remember why. LOL
We also used an adjustable actuating rod, though i dont think it needed to be adjusted.
The car was subjected to a brake test for rwc......it passed ok.
#16
Posted 04 February 2009 - 01:19 PM
But the old ones won't go into the new master
#17
_1ARC_
Posted 04 February 2009 - 02:13 PM
I intend on having new brake lines made up to suit. How difficult is it to make new brake lines or can you suggest who I can contact. I am in Perth. Thanks
#18
Posted 04 February 2009 - 06:05 PM
For a Torana with HQ discs on the front and HQ drums on the back would you recomend an XD Disc/Drum master or an XD Disc/Disc master?Both imperial threads
#19
Posted 04 February 2009 - 06:56 PM
P10050 ... so doesn't matter
I used to know a guy who did pipes in Perth... liked Toranas too ... but he closed down
Kim Skim is a mobile disc machinist that has done pipes for people before... he's in Midland but I guess will travel but not too far.
#20
Posted 04 February 2009 - 07:09 PM
Posted 04 February 2009 - 07:39 PM
http://www.aussiev8....ace-brakes.html
#22
Posted 04 February 2009 - 08:42 PM
Like for starters... it doesn't bolt in like he says
Look at Jim's mod page for the changes he had to make to that bracket to fit his VN http://users.bigpond...au/jimbo123/VN/
The flares he got around the wrong way first up then talked back around to the right way second time round
Forget VT stuff its an extra hardship waiting to happen and not going to save you any money
You don't need the bigger master cylinder anyway
The wheels been invented once already
#23
Posted 04 February 2009 - 09:23 PM
#24
Posted 04 February 2009 - 10:43 PM
Question..if you fit the VB-VR big booster...is the std Holden master cylinder the go for Disc front and rear or do you need the Foord one?
Posted 05 February 2009 - 01:02 AM
Ford is 1"
You decide
