Commodore booster and Master on LH/X.
144 replies to this topic
#26 ls2lxhatch
Posted 05 February 2009 - 01:13 AM
Same part # for both
P10050 ... so doesn't matter
I remembered that there was two master cylinders for the XD and thought they would be for the disc/disc and disc/drum applications. The part I was thinking of is P10049 which is for the disc/disc and disc/drum panel vans, utes and wagons. I expect that the difference is in the prop valve.
#27 _rorym_
Posted 05 February 2009 - 07:44 AM
Wouldn't the crack point for disc/disc and disc/drum be different?
#28 _rorym_
Posted 05 February 2009 - 06:29 PM
And wouldnt it be easier to fit the LH brake pedal?
#29 _rorym_
Posted 06 February 2009 - 09:39 PM
Ping!..If you missed it.
#30 dattoman
Posted 06 February 2009 - 10:10 PM
I didn't miss it
I'm ignoring any discussion on the "new wheel"
#31 _rorym_
Posted 06 February 2009 - 10:53 PM
WELL!!..You better talk then...this is a mod for the "Old Wheel!"...then if it works the new wheel might get it too....
Edited by rorym, 06 February 2009 - 10:53 PM.
#32 dattoman
Posted 06 February 2009 - 11:04 PM
booster ... shorten rod... falcon master... new pipes... check clearances... race
#33 _rorym_
Posted 07 February 2009 - 09:37 AM
Whats the CP for the rear on a P10050?..OK for rear discs?
#34 _rorym_
Posted 07 February 2009 - 12:23 PM
Whats different with VR/VS ones?..Look the same.
#35 dattoman
Posted 07 February 2009 - 12:58 PM
VS booster is single diaph and plastic and different master cyl
#36 _rorym_
Posted 07 February 2009 - 01:36 PM
and the CP for the P10050?
#37 dattoman
Posted 07 February 2009 - 03:34 PM
Read it off the end of the cylinder
Yes it will suit disc rear.... but its not actually relevant anyway
Since a Torana weighs differently and has different sized rear brakes to a Falcon
Show me a formula that can calculate the desired pressure for a car and I'll start to believe it matters to people like us
You probably use a bias valve on the back that you adjust anyway don't you ?
#38 _rorym_
Posted 07 February 2009 - 03:38 PM
Got one for the current car.
#39 _rorym_
Posted 08 February 2009 - 02:14 PM
Just noticed the WB statesman booster has the bent arm on it already...Fit OK?
#40 dattoman
Posted 08 February 2009 - 02:26 PM
No
#41 _rorym_
Posted 08 February 2009 - 02:29 PM
Bugger....so I will stick with Commodore and mod it then.
#42 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 14 February 2009 - 10:54 PM
I believe you Dattoman, but why wont it fit?
Still wrong pushrod length or Mounting holes wrong position or Booster physically too large diameter?
#43 _rorym_
Posted 18 February 2009 - 10:52 PM
Think it just needs the cut and shut on the rod Fuzzy.
#44 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 18 February 2009 - 11:46 PM
Ahh Ok , Thanks Rorym
#45 _Drue_
_Drue_
Posted 21 February 2009 - 11:03 AM
hi guys im new on here.
i have just had a look at this thread and am a bit confused.
i have a 76 lx sedan. (straight rod i guess.)
i want to get rid of the proportinal valve and have a later plastic comodoore style booster/master clyinder.
so what do i need?
i have std torana brakes disc/drum
i do want to up grade them to comodoore later (if that can be done)
#46 TUF 308
TUF 308
  • 169 posts
Posted 02 March 2009 - 08:12 PM
How is this going rory? thinkin of doing the same. the torana master just dont cut it i think with the skyline calipers.
Is the double diaphram commodore booster only in V8 commies or in 6's as well?
#47 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 03 March 2009 - 06:37 PM
I'm pretty sure it was used for the 6 cylinders as well as V8's (VB through to VR).
#48 dattoman
Posted 03 March 2009 - 07:07 PM
VB-VK with 4w disc usually
VL turbo and V8
VN-VR all V8 and alot with FE2 suspension
Just go measure the bugger
#49 TUF 308
TUF 308
  • 169 posts
Posted 03 March 2009 - 08:21 PM
Looks like a trip to the wreckers tomorrow :D
#50 _rorym_
Posted 05 March 2009 - 07:01 AM
Still waiting for delivery of both of them TUF...One guy hasnt answered emails since 20 Feb...I paid for it on 11 Feb.
