#251
_jabba_
Posted 03 October 2011 - 08:41 PM
#252
Posted 03 October 2011 - 08:44 PM
#253
_jabba_
Posted 03 October 2011 - 08:46 PM
Ring gaps would have been set within 'standard' tolerances... What causes the expansion, increased combustion temps?
Edited by jabba, 03 October 2011 - 08:47 PM.
#254
Posted 03 October 2011 - 08:53 PM
.004" per inch of bore is the rule of thumb for standard engines.
Therefore, my 202 being approx 3 9/16" bore would be .014" ring gap in the ball park.
But I'm running .020" on the top compression and a gapless second ring because I race it. It's not turbo'd.
Edited by rodomo, 03 October 2011 - 08:55 PM.
#255
_jabba_
Posted 03 October 2011 - 08:54 PM
Thanks again mate!
#256
_jabba_
Posted 03 October 2011 - 09:46 PM
#257
Posted 03 October 2011 - 09:56 PM
But I forget?
Ask this bloke (Wayne) http://www.gmh-toran...ser/5368-2elcs/
I went through this with 2ELCS and my engine builder buddy some time ago.
He will have it written down somewhere I'd reckon? He gapped the rings himself.
His is a 202 and he will be turboing it later.
#258
_jabba_
Posted 05 October 2011 - 01:03 AM
After i rebuild the engine i found out that the 18rg sump doesn't like holding oil in the engine while doing fast right hand corners, when i did the motokhana the oil light came on a couple of times. I backed off straight away but obviously too late... Mains looks new still *shrug*. Ill baffle up the sump this time
#259
_jabba_
Posted 16 October 2011 - 03:28 PM
Edited by jabba, 16 October 2011 - 03:29 PM.
#260
_jabba_
Posted 22 April 2012 - 11:07 PM
So far i think the EFI conversion has cost him
megasquirt ecu = <$400
Throttle bodies = $80
Manifold, including the webber flanges = $200
VL fuel pump = $140
Swirlpot = $80
throttle cable = $30
And loads of my time for free
Total = $930ish but hopefully the sound of quad throttles, priceless
Edited by jabba, 22 April 2012 - 11:12 PM.
#261
Posted 23 April 2012 - 07:17 AM
#262
_jabba_
Posted 23 April 2012 - 09:20 PM
It started first kick tonight, gotta be happy about that
#263
Posted 23 April 2012 - 09:27 PM
And does it handle coil packs??
Was toying with the idea of running a Delco 808 on ignition only with a 3 bar map censor to run coil packs on a 202 running off crank angle censor holes in the flexplate.......
But it all got to hard and complicated just thinking about it.
Is the MS nice and simple and strait foward??
Posted 23 April 2012 - 09:29 PM
#265
_jabba_
Posted 24 April 2012 - 10:41 PM
Whats the megasquirt like to dick with??
The software (tuner studio) is awesome to play with, very easy
Ah, so they're not actually independent runners, there is a common plenum for a MAP sensor to work with. Makes life easy!
Yep, the only problem is that the MAP signal is still poor. I have it running fairly well, i tried doing a bit more tonight and went backwards, luckily i saved the last tune
#266
Posted 24 April 2012 - 11:30 PM
Only seems to handle a 2.5 bar map censor though, that limits me to around 22psi boost
Interesting.
Edited by Bomber Watson, 24 April 2012 - 11:39 PM.
#267
_jabba_
Posted 26 April 2012 - 01:30 PM
http://www.diyautotu...tion-p-117.html
Edited by jabba, 26 April 2012 - 01:33 PM.
#268
_jabba_
Posted 26 April 2012 - 07:23 PM
#269
_hutch_
Posted 10 July 2012 - 06:24 PM
_jabba_
Posted 09 September 2012 - 09:42 PM
As of this afternoon, we gave it a custom paint job to make it look like it belonged until he finishes preping for paint
#271
_jabba_
Posted 09 September 2012 - 09:49 PM
#272
Posted 09 September 2012 - 10:04 PM
No sheilas?
#273
_jabba_
Posted 09 September 2012 - 10:09 PM
Next weekend i might do a bit on the Monaro (*Gasp*). I picked up a 05 Subaru Liberty GT for its engine (long story) and it came with nice leather seats. Might see if they can be made to fit...
#274
_jabba_
Posted 10 September 2012 - 10:42 PM
#275
Posted 10 September 2012 - 11:28 PM
