'Purple' build thread
591 replies to this topic
#576 76lxhatch
  • 7,227 posts
Posted 07 November 2023 - 02:01 PM
The blower is a YellaTerra kit. It doesn't require any upgrades from the stock GM set up. It's basically a straight bolt on kit that uses the stock ECU & MAP.
Sorry but that doesn't sound right at all. The standard MAP sensor cannot read boost at all, it only goes to 1 bar. At minimum you'd need a new map sensor and a tune.
#577 yel327
  • 13,939 posts
Posted 07 November 2023 - 03:21 PM
Agree. Minimum would be a re-tune via a new Eeprom or Eprom in the Memcal and a boost ready MAP sensor.
#578 hanra
  • 11,050 posts
Posted 07 November 2023 - 06:36 PM
Any helpful info here?
https://support.halt...icles/holden-v8
#579 hanra
  • 11,050 posts
Posted 07 November 2023 - 06:58 PM
Is this a similar kit to yours? Seems like this one comes with a 2 BAR MAP?
https://store.yellat...led-6rib-drive/
#580 hanra
  • 11,050 posts
Posted 07 November 2023 - 07:08 PM
Sort of seems like yeah, you need a 2 BAR MAP sensor in any boosted application.
Edited by hanra, 07 November 2023 - 07:08 PM.
#581 Statler
  • 6,341 posts
Posted 09 November 2023 - 01:38 PM
The 304 has been running just fine for the past 6 years .
The TerraCharger kit doesn't require a MAF change.
The ECU module was reprogrammed by Chiptorque for this application.
I believe they transfered the data from the VR chip (the one for the 355) , done something to accomodate the piddly little blower , & converted it to run in the VN ECU,
Something i noticed yesterday . I let it idle for about 3 mins when it started to stall . I was watching the fuel pressure gauge as it done this & the fuel pressure was dropping as the revs lowered.
Now i'm wondering if the Bosche 44 is dying.
#582 76lxhatch
  • 7,227 posts
Posted 09 November 2023 - 07:32 PM
If the primary load sensor is mass air flow rather than speed density, that would make more sense.
... converted it to run in the VN ECU
Have never heard of VN ECU being capable of this though, perhaps it is a VSIII/VT one if you're running MAF?
Sounds like you may be onto something here, if you're seeing a pressure drop at low injector opening times then it's going to be bad when it needs a bit more fuel. Also worth checking the regulator, depending on the flow capabilities it could be bypassing.
#583 Statler
  • 6,341 posts
Posted 10 November 2023 - 11:08 AM
Let me try to explain this a little better.
Purple has been running fine for 6 years with no issue. I have been using the stock ECU (albeit the chip has been changed prior to me buying the wreck that the engine came from) . It is basically a VN 304 / T5 from a wrecked VN .
The 355 was fitted to a VR . It also has a hot chip , also from Chiptorque.
The VN / VP ECU is not interchangable with the VR / VS ECU. I believe that even the wiring is different. I know that the plug for the dizzy certainly is different.
I sent the VR chip back to Chiptorque for them to do whatever they do , I expected they would copy the VR chip data onto a VN chip , therefore allowing the engine to run on the same designed chip , but in the earlier ECU.
The fuel regulator is one of those things i have already changed in this process.
#584 76lxhatch
  • 7,227 posts
Posted 10 November 2023 - 01:45 PM
Don't know where the supercharger fits into your timeline, but the statement stands: if you're running a MAP-based (speed density) ECU/tune it simply cannot read boost with a standard (1 bar) MAP sensor. Perhaps it already had a 2 bar sensor for some reason.
#585 gtrboyy
  • 3,262 posts
Posted 10 November 2023 - 05:41 PM
Yes does take 2 bar map sensor.
Have you checked it for fault codes?
Got fuel pressure guage on it & done compression test to rule out basics?
#586 Statler
  • 6,341 posts
Posted 22 March 2024 - 01:48 PM
Well it's running like a rocketship again. ........... but still has a little flat spot. Hmmmm.
Fuel filter element was partially collapsed which was blocking the flow.  All up i probably spent 1hr fixing the issue.
That's after the car being at a local "mechanic" for 6 weeks & him being unable to fix it. That will be $880 thanks.
Chiptorque sent the chip back & it ran sweet.
BTW , i don't recommend Earls fuel components anymore.
Almost ready for Rockynats 4.
Oh ...... boost is controlled by a Microtec.
#587 Statler
  • 6,341 posts
Posted 08 November 2024 - 12:39 PM
I've had the blower on since i built it .
It's a YellaTerra TerraCharger 4081 'kit' that was on a VS Maloo . It uses a 2 bar MAP sensor & stock  ECU . I apologise for any confusion when i said it had a MAF .  There are 2 additional injectors mounted high on the intake which are boost controlled by a Microtec MF-1 .
I think the blower is at , or beyond it's usefull limits with the 355 . Still sounds cool though . :)
Rockynats used a pic of Purple for a promo ,
Attached File  465787303_876694941336333_3450955336421198266_n.jpg   306.36K   6 downloads
#588 Shiney005
  • 9,970 posts
Posted 09 November 2024 - 10:43 AM
It still looks great. A fellow Sandgroper made the trip this year and he thought Rockynats was a better vibe than the Canberra show.
#589 Statler
  • 6,341 posts
Posted 10 November 2024 - 10:47 AM
I can't check it for fault codes because it's a VN ECU (light flash) & the wire isn't connected to a lamp /
Yes i have fuel pressure & compression .
It's running sweet . Just has a flat spot from idle.
#590 gtrboyy
  • 3,262 posts
Posted 10 November 2024 - 08:30 PM
I've hooked up cel to handbrake wire on a few old holdens to keep dash looking stock.
Been told should be able to do it with a test light if no globe wired in.
Edited by gtrboyy, 10 November 2024 - 08:31 PM.
#591 Statler
  • 6,341 posts
Posted 20 August 2025 - 08:00 PM
Well . I'm thinking this car doesn't like me .
While i was trying to diagnose the failed AIC valve , the fuel pressure regulator suddenly died .
Replaced the AIC , replaced the fuel reg , & she is firing on all 8 again .
But now instead of a slight leak from the rear main , i think it has completely blown out . (sigh) .
#592 SmacT
  • 1,019 posts
Posted 20 August 2025 - 09:25 PM
It's almost enough to make you go LS1, isn't it? No good mate.
