Fitting Original Rear Discs to UC
74 replies to this topic
#26 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 26 October 2009 - 09:04 PM
Yes, I realise they have to change the bearings as well, just wondering if they had to relocate the retaining collar or anything like that. I'd feel pretty stupid if I got them back and they didn't fit.
So HZ seals and new bearings and I'm good to go. Thanks all.
#27 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 26 October 2009 - 10:19 PM
To fit the seals requires removing the bearings
So they can't just "fit the seals"
So its new bearings and seals time
And since HQ never had disc rears... try HZ or WB rear :)
Most diff shops aren't as knowledgable as you Neil :P
#28 _torana50_
_torana50_
Posted 28 October 2009 - 07:06 PM
Thanks for that. It does get a bit confusing.
I have no probs getting new bearings and seals, I'd rather new stuff going into the car anyway.
I am still curious about the discussion with chopper and others about getting new rotors to suit in a limited run.
No one seems to respond to the question about if, when and how much.
#29 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 29 October 2009 - 06:06 AM
I'm also interested in that one. One guy said he could arrange it, but didn't say anything about costs. It seemed there were enough interested people to make it worthwhile though.
#30 dattoman
Posted 29 October 2009 - 09:26 AM
I think the issue was not enough takers
Especially ones with the cash in hand to pay upfront
Chopchop would be the best to answer this though as he did the research
#31 _CHOPPER_
Posted 01 November 2009 - 01:02 PM
I am closer to orgnising a batch of ten new UC rear discs. I am currently in a couple of disputes with the ATO. The first one is virtually finalised. Should I win both, that should mean they finally pay me about $12K. I will be then right to go on the discs.
#32 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 01 November 2009 - 04:02 PM
Can you give us a cost estimate so that interested parties can start saving?
#33 _CHOPPER_
Posted 04 November 2009 - 02:27 PM
If I get the $12K, I will get a set made, regardless of interest.
However, I will start a new thread to discuss interests and options.
#34 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 01 January 2010 - 09:58 AM
keep us informed
#35 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 04 January 2010 - 05:09 PM
I'm confused about my rear wheel bearings. Got replacement bearing kit inc. seals and collars, but they are self-contained bearings, with a cylindrical casing. Inspection of my UC shows it has tapered roller bearings. Did I get sent the wrong bearings? The Gregory's manual shows a picture of the rear axle (disc type) with the non-tapered bearings, which look like the ones I have received. This picture also shows the axle as having extremely coarse splines. Mine have 23. It doesn't show any picture of the drum-type axle. Did they use different bearings?
#36 yel327
Posted 04 January 2010 - 06:15 PM
AFAIK disc brake rear ends use the same bearings they just have a collar/seal behind the bearing to account for the caliper carrier. They should all have fine spline axles too.
#37 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 04 January 2010 - 06:19 PM
So it seems I was sent the wrong bearings then. Also I'll be in need of the spacers... Any suggestions?
Edited by Steve TPF, 04 January 2010 - 06:27 PM.
#38 TerrA LX
Posted 04 January 2010 - 06:45 PM
There are two different types/styles of bearings that do much the same job, and both styles, tapered two piece and the captive type you have are available to fit these axles.
Matter of opinion which is better, I along with some believe the captive type you have to be superior, as would have the supplier, that's probably why he gave this type to you,
Other people believe the tapered two piece bearing to be better...
#39 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 04 January 2010 - 07:09 PM
Except the axle housing has a tapered receiver, which means the captive type won't fit. If all the toranas used the same bearing why would he make this mistake?
#40 TerrA LX
Posted 04 January 2010 - 07:35 PM
Except the axle housing has a tapered receiver...
Just take it out.
#41 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 04 January 2010 - 07:37 PM
So it's removable? I thought it was part of the housing.
Ok, so if I take out the inner receiver I still need a spacer to take up the extra thickness of the caliper mounting plate. I'm guessing these aren't readily available...
Edited by Steve TPF, 04 January 2010 - 07:39 PM.
#42 TerrA LX
Posted 04 January 2010 - 07:49 PM
Same as the tapered bearing in the front disc, two piece = the bearing and the cone
tapered bearings
Either bearing will need the spacer.
Edited by TerrA LX, 04 January 2010 - 07:47 PM.
#43 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 04 January 2010 - 08:03 PM
Yeah, thanks, I get the point about the bearings, but where do I gt the spacer?
#44 rodomo
Posted 04 January 2010 - 10:02 PM
There are 2 different seals.
2 different depths/widths/thicknesses if that makes sense?
You need the disc brake ones (thicker/wider) if converting from drum to disc.
Edited by rodomo, 04 January 2010 - 10:07 PM.
#45 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 05 January 2010 - 06:40 AM
I have the disc brake seals, but they don't seem thick enough to compensate for the missing spacer.
#46 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 05 January 2010 - 08:11 PM
I hate to double-post, but i can't add to my previous one.
Checked today and the new seals don't make up the difference. A spacer will be needed. But that's now a moot point. With the standard axle in place, the disc sits too far out - there's no room for the pad between the caliper and the disc. The disc brake axle must have the wheel mounting flange set in closer to the axle housing (which makes sense now I think about it because this will maintain the same track width). So fitting new seals and bearings to the original axles won't help at all - the disc brake axles will be required.
#47 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 06 January 2010 - 12:33 PM
I think the problem is you are getting advice to get HZ - WB disc bearings. They will need the 1/4 inch spacer. To do the conversion without the spacer you need the later commodore VB-VK salisbury kit which has the sam bearing but a thicker seal. You may be able to buy the seals. Alternaively I think others have cut down an old bearing ring for the spacer.
#48 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Car:UC hatch
Posted 06 January 2010 - 08:30 PM
Thanks for that, but the spacer's the easy part really. The real issue is that the drum brake axles won't work with the discs. I need the disc brake axles (which will presumably have the spacers on them anyway).
#49 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 17 January 2010 - 03:27 PM
It has been done many times in the past, using drum axles, std bearing (or UC disc brake bearing which AFAIK is the same part anyway) and the HZ disc brake seal.
I would suggest you check to ensure the bearing that has been pressed on is correct.  I have LX Drum and UC Disc axles here and the bearing is identical.  The wheel track will be slightly wider (<1/4" I think) with the discs.
Grant..
#50 _UC HATCH_
_UC HATCH_
Posted 25 January 2010 - 08:04 PM
Any further reports on your fitment of the discs. Steve TPF
First thing I would do is get the tapered bearings, I have never seen other than tapper on older Holden (I could be wrong)but that's what you had on there.
Why go for the HZ - WB seals or commodore VB-VK Salisbury kit? Isn't there a UC disc brake rear bearing and seal kit?
Or did the UC have a spacer and the thicker seals came out later, or was the spacer a workaround someone came up with?
Mark
