Mig Welding Help?
#1
_Viper_
Posted 24 October 2009 - 12:48 PM
Is there anything wrong with doing it this way? obviously its slower and id say its possibly not getting as much penetration... on the other side it is penetrating but you see a line of dots more so rather then a continuous line..
But so far what Ive been welding isnt really structural at all and and more just a seal.... I guess another disadvantage would be possibility of pin holes if i dont get the welds right next to each other.
I can weld in a continuous line just it doesnt give the neat tig weld sorta of look and it blows through alot easier (1.6mm steel was what I last welded)
So yea any thoughts?
I thinking of using the method for things that are visible, ie custom turbo exhaust manifolds, dump pipes etc but arnt really under much stress
#2
_nial8r_
Posted 24 October 2009 - 02:05 PM
#3
Posted 24 October 2009 - 02:24 PM
Turn down the amps till you can get the weld slow enough to look like you want then test if it is strong enough for your needs.
So long as you see a little burn thru on the other side it will be plenty strong.
#4
_torana_umunga74_
Posted 24 October 2009 - 02:30 PM
#5
Posted 24 October 2009 - 02:45 PM
This method can work well on lighter gauge material,as it will minimise distortion.
If done correctly ,you can minimise pinholes,which can be a very real concern on car panels as water will penetrate the pinhole and cause rust to start and bog repairs to delaminate.
That being said,I would not use this method on heavier gauge materials.
Your method should be OK on exhausts,depending upon how you are going about it.
If you could put up some pics of what you are welding and your finished welds I might be able to give you a better analysis.
#6
Posted 24 October 2009 - 06:09 PM
Yup, all that they've said, tack into position first, then isolated 25mm line welds around the panel to control the heat/metal movement.
#7
Posted 25 October 2009 - 01:30 AM
I use this method for my exhaust and for some thin panel work, the welder needs to be up a bit higher because you don't get the current flow without continuous wire feed, works well thoughThis method can work well on lighter gauge material,as it will minimise distortion.
#8
Posted 25 October 2009 - 08:43 AM
#9
Posted 25 October 2009 - 11:30 AM
BUT just one consideration, you mentioned a turbo exhaust manifold as a low stress item, i think you should do a bit more research there.
_chrome yella_
Posted 25 October 2009 - 11:44 AM
#11
_Viper_
Posted 25 October 2009 - 12:05 PM
I meant compared to something like suspension components or structural parts of the car.
Turbo exhaust manifold only needs to hold the weight of the turbo, part of the exhaust and some of the intake and thermal expansion
#12
Posted 25 October 2009 - 04:52 PM
If you add everything together an exhaust manifold is probably the highest stressed part of a turbo engine.
_Viper_
Posted 25 October 2009 - 08:19 PM
Heres another question, I cut and welded in some GTS guard flutes to my Gemini Guard today using the leap frog tack cool method and was just wondering is there any way to stop/reduce the shrinkage around the welds?
Like i get both the panels perfectly level but sometimes when you weld it then grind it back flush, around the weld is a little lower like its sunken away?
#14
Posted 25 October 2009 - 08:23 PM
Re read what yella said.
Youll just have to plop it up and break out the speed file.
#15
Posted 25 October 2009 - 08:24 PM
#16
Posted 25 October 2009 - 08:39 PM
Also cooling rags help.
Using fresh grinding wheels and not going ape shit, grinding also heats the panel.
As above, you will still need to plenish some with these type of welds.
#17
Posted 25 October 2009 - 08:41 PM
Apart from that,
Tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool, tack hammer cool.
Then, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat, bog sand repeat,
Basically
Edited by Bomber Watson, 25 October 2009 - 08:43 PM.
#18
Posted 25 October 2009 - 08:53 PM
#19
_Viper_
Posted 25 October 2009 - 10:11 PM
Is that planishing? and if so what is it and what do i I do exactly... and what does it achieve
#20
Posted 25 October 2009 - 10:25 PM
when it cools, it contracts.
Sometimes it contracts more than the surrounding substrate so you need to stretch the weld with a hammer and dolly, this will bring the panel flat again if the sink is caused by the "heat shrink" of the weld.
Edited by TerrA LX, 25 October 2009 - 10:28 PM.
#21
_Viper_
Posted 25 October 2009 - 10:40 PM
Cheers for the info btw guys... Im actually a construction worker. everything ive learnt to do is just from DVD's and forums (you guys) oh and I did a short night course at tafe for 6 weeks which covered basics.
Edited by Viper, 25 October 2009 - 10:42 PM.
#22
Posted 25 October 2009 - 11:10 PM
#23
_2DR_
Posted 25 October 2009 - 11:26 PM
space out your tacks 25 mm and hammer each one to keep the panels flush as possible then let cool.
then weld small sections between each of the tacks leaving sections out as not to generate to much heat in one section then let cool .
repeat untill fully welded and if you are going to cool the panel or weld i would use a air gun to blow cool air on it rather than wet rags you can also heatshrink using this method .
and remember be patient.
good luck
2dr
#24
Posted 26 October 2009 - 06:25 AM
Let it cool naturally, putting a dolly or hammer near a hot MIG weld will just induce a hot shrink and make everything worse. Cooling natural, while taking longer, all should come back to where you started.Cooling it slower and hammering the welds can help a little (not so easy with the mig but), hard to avoid it though
You can't really plenish MIG welds, just tends to bend the metal around the weld making everything very untidy.
I'm still very much on my L's as well, just picking up little tid bits the more and more I have a go.
Edited by Yella SLuR, 26 October 2009 - 06:28 AM.
#25
Posted 26 October 2009 - 08:21 AM
