Combinations.
49 replies to this topic
#26 LXCHEV
Posted 14 April 2006 - 01:07 AM
bones - Wow, very impressive mate. So close to running a 10sec pass too! Couple of questions if you don't mind me asking (I'm real interested in your combo, as I'm also running a 383 Chev): what intake manifold are you using? dual or single plane? Cam - solid or hydraulic, big or small?? Also curious as to what kind of hi-stall you have? Oh, and lastly - extractors? Tri-Y's or 4-into-1's?? Is your engine a big revver or not? I find that 383's tend to fall over after 6000rpm. How driveable is yours? A flat 11 is FAST! Your combo sounds quite tame. My car is a couple hundred kilo's heavier than yours, but a lot of the other stuff is very similar.
myss427 - beautiful work! I rate your car up there with Howard's SLR8000. Awesome stuff!!
I'll post up my combo when I get the time too....
Cheers :D
#27 _wombat_
_wombat_
Posted 14 April 2006 - 02:05 AM
Tiny its a C/ Altered chassis with a fibreglass 23 t bucket body,125 inch wheel base. i forgot to mention we have a MSD 7AL with a 2 step rev limiter with a 9000 rpm chip in it. just got the new little m block and some lunati roller lifters so engine should be back together soon. as soon as my lh is back from the painters i will be slinging my 355 sbc in and see what it does. wife is sick of the trans behind the bar,its been there 2 years!!
#28 Tiny
Posted 14 April 2006 - 09:32 AM
Thanks Wombat! Great stuff :)
#29 _bones_
_bones_
Posted 14 April 2006 - 10:25 AM
Cheers :D
Hi LXCHEV,
I have a Edelbrock RPM dual plane manifold. A Hydraulic cam 244 Dur @ .050 and 510 lift. The convertor was supposed to be 3800, but if I load it up much over 2000 the car will push forward and break the beam. So 2000 off the line it is. It has a set of Tri-Y's that have been modified to fit, they are very poor looking and not the best set of pipes. It is not a big revver, I change at 5500 through the gears and let it rev in top. It is doing 6400 in top gear over the line. I have tried revving it a little harder through the gears with no difference. 3.89 gears seem to suit it well. You are right about laying over around 6000 or more.
I would say it is very tame and quite drivable. It has been a very reliable combination that has done around 150 passes in less than 2 years with no drama's. Having it on pump fuel it is handy just to go down to the BP for fuel.
Bones
#30 LXCHEV
Posted 14 April 2006 - 10:55 PM
Cheers bones! Our combo's are so similar it's not funny! Yet I'm no where near running the numbers you have. Mine is 10:1 comp. Edelbrock RPM Air-Gap dual-plane. I did have a hydraulic - pretty much identical to the specs you listed (242 and 0.518). Iron Pro Lightning heads, 3200 hi-stall and 3.7's with a 26" tall tyre. Also runs solely on pump fuel (Mobil 8000). Ran 11.77 @ 115mph.
Now I have a solid cam, up around the 260 duration @ 0.050 now, also a bit more lift, and a tiny bit more head work. Was hoping to get right down into the 11's, yet best time so far with this combo is 11.91 @ 114mph. I seem to cross the finish line at around 6000, maybe I should go for some shorter gears.
Can anyone tell me what is the general rule of thumb for rpm over the finish line? Are you meant to cross at peak power? Or higher? Thoughts?
One more question bones - what spark plugs are you running? 6's or 7's and what kinda gaps? I've always run 7's in my chev, but have recently started playing with 6's. Big thanks!
#31 LXCHEV
Posted 14 April 2006 - 11:39 PM
Ok thought I should do this properly, here is my combo:
Car: LX Torana sedan
Weight: 1480kg's with me in it
ORIGINAL SETUP
Engine: 383 SBChev, 2-bolt 350 block + .030" with ARP stud kit, 400 crank (3.75" stroke).
6" Chev I beam conrods.
Keith Black Hypereutectic pistons. 10:1 compression.
Hydraulic cam - 241 @ .050, .516 total lift.
Iron Pro Lightning heads (200cc intake runners). 2.02 & 1.60 valves. Yella Terra 1.6 ratio roller rockers. 7/16" Screw-in studs and guide plates.
Edelbrock RPM Air-Gap dual-plane manifold (port-matched). Barry Grant 825 Mighty Demon.
ICE Compu-Curve digital ignition system & rev-limiter. ICE 2000 series leads.
Romac Steel balancer.
Exhaust: Custom made 4-into-1's (1-7/8 into 3"). Twin 3" straight-through system, balance pipe, dumped at diff sounded ACE.
Fuel Delivery: Brown Davis droptank with built-in 1/2" pickup and swirlpot. Carter electric fuel pump, 1/2" fuel line to Holley reg, twin feeds into carby. Runs on Mobil 8000 premium unleaded pump fuel (Never tried anything else).
Trans: TH350, heavy-duty clutches etc. 3200 hi-stall. Megashifter (standard shift).
Diff: Ford 9" 3.7:1 mini spool. 28 spline standard Holden axles.
Wheels/Tyres: Convo Pro's - 15 x 4 & 15 x 8.5's. 165 Hankooks & 275/50 MT ET Street Radials (26" tall).
Suspension: Pedders Sports Ryder shocks all corners. A9X-Spec King Springs front, Pedders lowered rear springs. Boxed trailing arms. Rubber bushes through-out.
Performance: 11.77 @ 115mph. Calder Park, cold night, perfect traction.
NEW SETUP AFTER RECENT CHANGES
Same as above, with following changes:
Engine freshened up, taken to 0.035". SRP forged pistons.
Solid cam (flat tappet), 251/254 dur @ .050, 0.544/0.563 total lift.
High volume oil pump. Oil restrictors.
Custom Tri-Y's - 1-3/4" prim -> 2" sec -> 2-1/2" coll. Twin 2-1/2" straight-through system with balance pipe.
Performance: 11.91 @ 114mph. Heathcote, pretty warm day, perfect traction. My best 60ft times are high 1.6's, with both my old and current setup.
Something is holding me back!
Edited by LXCHEV, 14 April 2006 - 11:41 PM.
#32 _bones_
_bones_
Posted 14 April 2006 - 11:45 PM
LXCHEV,
If you think your car is a few hundred kgs heavier that maybe most of the difference. I have heard that 100kgs is around 0.25 of a second.
A slide rule can give you an idea on changes in weight, power, and its effect on ET's etc.
There is a few handy calculators on
www.wallaceracing.com/Calculators.htm
Remember to use pounds not kilograms and have an accurate weight of the car.
I will have to check on the plug info.
#33 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 15 April 2006 - 07:59 AM
That is about right. For cars running 10-15 sec quarters 100 lbs is about 1 tenth and 1 MPH.
When I removed my 200kg tray from my Tonner I picked up 4 tenths and 4 MPH.
1 Kg is 2.205lbs.
For best ET try to cross the finish line at about 300 rpm over peak power.
If you watch some vehicles they will be on the shift light from half track !!! This makes for a great ET with comparatively low MPH, very hard on valvetrain though.
Edited by Struggler, 15 April 2006 - 08:06 AM.
#34 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 14 September 2006 - 09:22 PM
Have been busy knocking up a new combo after my old 350 reringer got a bit too loose.
Now using a 040 over 400 block with my old 350 crank for 377 CID
Sportsman II heads ported at home, Lunati solid (249,254 @ 050), KB flat tops .005 down from the deck. Victor Jnr and my old 750 vac top it off. Some Pacemaker 1 3/4" 4:1s hang off the side. Same convertor etc as before. Got it together and ran the cam in at home, on to the trailer and straight to the dyno to check mixtures and bed in rings (car is unreg atm). After some minor jetting changes it rattled off 262RwKw with an aircleaner and thru the mufflers. I couldn't believe it.
Last night I took it to WSID and got 2 passes in, 11.6 and 11.5 @ 118. Very happy with it. It really could use a looser convertor now and I have some other things that might squeeze another tenth or two out of it yet.
If anyone is interested I could maybe post some in the build pics.
#35 _MAWLER_
_MAWLER_
Posted 28 September 2006 - 07:26 PM
Sounds pretty good there Struggler, from the couple of combo's you've put up before you seem to be able to get big numbers out of what seems to be a fairly simple combo/setup.
Tell me, whats the benefit of using a 400 block but the 350 crank for a smaller displacement than a stroked 350?
#36 TerrA LX
Posted 28 September 2006 - 07:32 PM
^^ saves paying for a stroker crank.
#37 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 28 September 2006 - 07:51 PM
The 400 block has a larger bore, 4.125" as opposed to 4.000 for the 350.
A larger bore is handy for unshrouding valves and improving the bore to stroke ratio.
As ALX76 said, it got me some more cubes without having to buy a new crank, and the 400 block was gathering dust.
Also FWIW the 308/355 combo I posted a while ago went 11.20 @ 119 in the VK Calais last week. Only change was a new fuel pump and a bonnet scoop.
Like you said, its all in the combination. If you get all the details right the rest will take care of itself.
#38 _MAWLER_
_MAWLER_
Posted 28 September 2006 - 10:39 PM
What are those important details to get right in your opinon?
I was fairly disappointed when my 308/333 only made 200rwkw with what I thought was a reasonable combination. I'm nothing close to being made of money, but I might be able to make some modifications in key, big gain, areas.
#39 _LX8VD69_
_LX8VD69_
Posted 28 September 2006 - 11:00 PM
does that mean that going by some of these times, with my 308 stroked out to 334, fully balanced, crower cam with 289 degrees duration, stock heads with a fair bit of porting but stock valves, crower valve springs matched to the cam, redline torker inlet, 2inch mr gasket spacer and 650 vac sec holley. pacemaker try ys going into twin 2 inch pipes, straight flow mufflers and twin 2 1/2 tail pies. aussie 4 speed and 3.08 bango i should be looking at low 13s? and if thats true imagine if i went to a 3.9 diff and 2 speed power glide, mmmmmmmmmmmmm
also can any one tell me if i go to the drags, will i hook up better if i put in a set of racing slicks and to make sure i dont blow the diff i would be better to run more air in the tyres wouldnt i?
#40 TerrA LX
Posted 28 September 2006 - 11:56 PM
^ yes, and more pressure will give less traction with slicks and the opposite for street radials.
#41 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 29 September 2006 - 05:10 PM
200rwkw isn't too bad, depending on the dyno, trans, converter etc that could be a real grunter.
My old engine that ran up to 11.8 only made just on 200 rwkw, it was only minor changes that took it from low 13's to high 11's (jetting, timing, converter and chassis changes).
Take it to the strip and see what it runs, then start your development program.
#42 TerrA LX
Posted 29 September 2006 - 11:31 PM
^ you picked up 2 seconds from fine tuning things, well done. :spoton:
Edited by ALX76, 29 September 2006 - 11:31 PM.
#43 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 30 September 2006 - 05:47 PM
Like I said it was more than fine tuning.......
............it was only minor changes that took it from low 13's to high 11's (jetting, timing, converter and chassis changes).....
The actual engine didn't get changed, just the stuff around it.
And 13.3 to 11.8 is only a sec and a half !! ;)
#44 _MAWLER_
_MAWLER_
Posted 02 October 2006 - 06:12 PM
Well, on that good advice I will get it down to the track and start the fine tuning. i know the suspension needs some work so I can even do that before I run it down. I already have 50/50's in the rear and a set of 4 6cyl springs in the shed, all I need to find are front shocks to round out the treatment.
#45 _LXXX308_
_LXXX308_
Posted 03 October 2006 - 02:47 AM
Another combo to the list..
LX sedan 3100lbs
308 (326ci) off set ground crank, Chev rods. 10.6 : 1 comp
VN heads (pretty standed) torque power inlet manifold & pacemaker tri y's
competion solid cam, holley 650dp carb.
dyno 444hp (flywheel)
First trip to wsid with full manual powerglide, 3000rpm dominator converter street tyres and 3.9 diff gears 1.8 60ft 11.7 @119mph
for the engine being pretty small and weight of the car it was recomended a three speed box and a looser converter, so we tried it..
TH350 and 5000rpm Art Carr conveter. also a set of MT semi slicks slightly taller then my street tyres @26inch.
results - only 1 pass out of 4 without wheel spin 1.7 60ft 11.6 @115mph.
The following week 4.3 diff gears and a full slick 26inch, every pass it ran 11.6 @ 116mph.
Car was driven to the track every meet with full exhaust and pump fuel.
Still think i lost the mph through the converter.. would love to get it back!!
#46 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 03 October 2006 - 04:11 PM
Hi LXXX, great combo and good work.
Personally I reckon the 3 speed ate your MPH, not the converter.
Let us know next time your at WSID, and say hello.
#47 _LXXX308_
_LXXX308_
Posted 04 October 2006 - 12:01 AM
Thanks Struggler,
sounds like you've built an engine or two!!
I' ll let you know next time i'm at the track..
You maybe right about the loss of mph, I did keep the powerglide just incase, but the three speed is much nicer on the street
We were expecting to to run 11.1 @ 120mph with the three speed and 8inch converter, flash stall to 5000rpm, can't seem to hold it on the line when trying to bring the revs up, so i launch from idle and it goes 1.67 60ft
With your timeslips your 11.534 @118mph is almost identical to my 11.611 @116mph, (I haven't posted it yet) What converter did you run that night? and what did you change too when you ran 11.0??
#48 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 04 October 2006 - 10:15 AM
Thanks Struggler,
The 11.5 was run with my old converter, about 3800rpm.
The next week was run with a mystery stall (Dominello, was supposed to be 4500 but my combo pushes it closer to 5K) and netted 11.1's.
For the next week I fitted 1.6 rocker arms on the intake only, got 11.0's.
Now sitting at home wondering if I should fit a cage (got worded up by ANDRA officials after a string of 11.0's) or buy/build a dedicated racer.
FWIW I always leave from idle, or no more than 1500rpm. This maximises the torque multiplication of your converter. And three speeds always feel faster, and I must say are zippier on the street, but 'glides are almost always faster (MPH) and usually quicker (ET).
#49 _LXXX308_
_LXXX308_
Posted 05 October 2006 - 07:15 PM
Thanks for the info..
your right about the three speed feeling quicker, first pass with it I thought I had shaved a whole second off my time.
As for your roll cage, wish i had the same problem from those ANDRA officals!!
I would put a cage in my torana and try keep it for the street too.
#50 Tiny
Posted 05 October 2006 - 09:36 PM
Trust me you wont ( have a cage and keep it for the street)... NSW roll cage laws are now so strict that basically you cant rego or engineer a caged car!!
So it looks like i'll be aiming for 11.0 all me life!
Cheers!
