hawks uc sunbird
954 replies to this topic
#826 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 28 May 2015 - 07:01 PM
Anyway stuffed around a bit tonight and finally got it started. Tapped the fuel pump to free it up and works like a charm. It wont idle yet though so more work to do but slowly getting closer.
Off the manifolds too about 10 mins ago so the neighbors will be pretty pissed off haha
#827 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 28 May 2015 - 07:51 PM
:spoton: ...they will get used to it :)
#828 _mick74lh_
Posted 28 May 2015 - 09:46 PM
Wicked! Getting close now Steve. I'm guessing you got a belt that fitted?
#829 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 28 May 2015 - 09:53 PM
thanks and no just used the one that's slightly too big. it half spins the alt so I still get some charge.
#830 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 30 May 2015 - 10:06 AM
Video of it running here
https://m.facebook.c...100000516038026
I hope non facebook user can still see it
#831 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 30 May 2015 - 08:28 PM
No we can't.
#832 Holdenbn74
Holdenbn74
  • 152 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 31 May 2015 - 09:45 AM
Good on you for persisting bud👍 looking back in future you will be glad you did😉
#833 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 31 May 2015 - 05:15 PM
Thanks well got back from melbourne this arvo and started mucking with it. Must have pissed off the neighbors more than I thought because someone had changed a couple of leads around while I was gone.
Anyway changed the plugs and got the firing order right and it still runs like a dog. Something still isnt right. I played with the timing and it didnt make a difference.
Dont know what to do next.
#834 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 31 May 2015 - 05:25 PM
Also has new plugs, new leads and plenty of spark. Only thing I can think of is still a timing issue or ive broken something by runnimg it with the leads on wrong when I first got home.
#835 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 31 May 2015 - 05:38 PM
Trespassing and interfering with private property ?
Step by step,,just set the initial timing at about 8-10 at idle, check for any vac lines that might need to be hooked up.,,that might sound stupid but it is easy to miss one.
Is always a bit hard sometimes when the pipes are loud to hear what is going on but even on  an open pipe an 8 should just "blat"
away nicely and evenly...one thing at a time.
for example,re check leads to plugs from dizzy , assume they are new and it is not hard to swap one over while fault finding?
vac leaks
pictures of set up...never know when one simple little thing will catch you out!.....like a lot of others....been there done that...
#836 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 31 May 2015 - 06:01 PM
Thanks pics when its light I have pulled all the leads and will re do them again when I have time. No more buying bits for a while as the bills are stacking up haha
#837 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 31 May 2015 - 06:26 PM
Go steady :) yeah we all know about bills....
just for a change :)
sometimes just need a bit of time to mull things over eh :)
"if it's too loud,your too old" :) :)
#838 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 02 June 2015 - 10:30 PM
Heres the pics of the current setup.
#839 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 07 June 2015 - 03:41 PM
Well done hawk, it's happening :)
#840 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 07 June 2015 - 06:57 PM
In what way is not running right ?
This might be the most stupid idea but make sure the firing order is correct , not hard to get one lead out of whack , done it a couple of times even after a few years and should have known better :)
The vac.takeoff from #4 i think had something to do with the diaphram near the exhaust "hot pipe" for choke and was temp. related?
Block them off till it runs ok....unleaded fuel was the cure to pollution problems  ^_^
The vac. advance port on the carb. will cause a problem with a cam because the butterfly will need to opened up a bit to get a half
decent idle and the port inside the carb. will be exposed causing an "air leak".( lean miss ).
The pipe that leads to the rocker cover  as you have fitted to the PCV valve from the base of the carb. is right, but.. usually had a "breather pipe" that led up to the air cleaner assy. from the opposite rocker cover....without some sort of "vent" it will pull a positive vac. inside the engine which might cause a problem ?
Edited by EunUCh, 07 June 2015 - 07:05 PM.
#841 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 07 June 2015 - 10:19 PM
Cheers I have blocked off all vacc ports orher than the advance and booster.
The other rocker cover vent is open as I cant get anything in it with the heater fan box there.
Had a bit more of a play with it yesterday and get it running better. The timing is way off from the timing cover marks but thats the only way I can get it to run well without pinging.
The carb was throwing fuel in the there way too fast so I gave it a whack which must have released the float.
So it will run and idle enough for now but will need refining once I get pipes on it to hear whats going on.
And also bled the brake and got them to come up.
Still have to wire in the headlights and horn.
Get the flywheel and clutch fork then fit the box and some other small bits. Ill be cutting it close to moving time so it may still be trailered. Got about 6 weeks to go.
#842 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 08 June 2015 - 10:50 PM
Sounds like it's all coming together just nicely, fingers crossed the rest goes well.
#843 Potta
Posted 09 June 2015 - 12:56 AM
Good luck mate you've done well so far.
Just keep on trucking on and you'll get there.
#844 _A9X UC_
_A9X UC_
Posted 09 June 2015 - 10:32 AM
#845 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 11 June 2015 - 09:35 PM
Thanks got the clutch fork tonight. Found one a local guy had and swapped a couple of rough spare doors for it. Hopefully ill also get a flywheel off him tomorrow as well.
#846 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 12 June 2015 - 07:17 PM
Got the flywheel tonight so ill try and get the box in this weekend.
#847 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 13 June 2015 - 07:04 PM
Ok so the box is in. Still need to fit the crossmember and tailshaft. Will do that tomorrow and a few other little jobs.
#848 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 14 June 2015 - 05:35 PM
Spent the day slaving on the torana and got everything done I wanted too and more.
Finished the box install and hooked up the clutch.
Got the headlights wired in
console is in.
And most important IT DRIVES!!!
couldnt resist and took it around the block with it running off the manifolds haha. Still runs like shit and I think its missing a lot.
Clutch will need better adjusting. Will wait till I get engine pipes on it so I can work out why its running like crap.
#849 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 14 June 2015 - 06:27 PM
:clap:  get some pipes on it, at least you won't get tooo many complaints from the neighbors (and others),and it will help in being able to nut out a few teething problems.
Just something that may or may not be worth a mention ?....sometimes when V8's were lifted out of the car the dizzy was not removed because the bolt is such a pleasurable thing to get to, this resulted in the dizzy housing/shaft  getting a bit out whack, hard to spot, resulted in all sorts of
fun??
Edited by EunUCh, 14 June 2015 - 06:36 PM.
#850 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 14 June 2015 - 08:20 PM
Don't know if it's been suggested but have you checked the dissy cap for cracks and the posts inside are clean (no white chalky stuff on them).
