painting 2pac or acrylic
#26
_Eddie_
Posted 30 April 2006 - 09:13 PM
I'd rub it back gently before recoating if it's been sitting a week. Be careful not to go through the paint (go easy on corners and lips etc.) And lastly make sure you prepwash with clean rags (get your son to go behind you with a dry rag to remove excess residue.) Try not to use rags that have lint falling off
#27
_LoneOranger_
Posted 30 April 2006 - 10:08 PM
More good advice.
Will take it all on board.
Thanks, John.
#28
_1QUICK LJ_
Posted 30 April 2006 - 11:57 PM
#29
_LoneOranger_
Posted 01 May 2006 - 05:31 PM
Should we leave it for 5 or 6 weeks for the paint to harden before rubbing the paint and applying the clear? We're in no rush.
#30
_1QUICK LJ_
Posted 01 May 2006 - 07:13 PM
#31
_1QUICK LJ_
Posted 01 May 2006 - 07:34 PM
when cutting dont cut the panel edges or bodyline edges leave about 1-2mm either side of the edge or line these will buff in fine and you wont cut through that way, when buffing stay away from the panel edges and make sure the buff pad is spinning in a direction off the panel edge not towards it, just work up to the lines and edges dont buff across them.
its also a good idea to spray a little water from a squirty bottle on the panel when buffing this will keep the buff pad cool and stop it from burning the paint, just keep the buff moving constanly at a reasonably slow pace on low speed around 1800 rpm do not use a 9 inch grinder they spin way too fast, it must be a buff machine.
with black its best to then wash the car then buff the car again with 2k fine compound this will bring it up alot better and delete alot of swirl marks wash the car again to get rid of compound residue, then use meguires swirl remover by hand then use meguires wetlook polymer sealant polish applied by hand, if you follow these steps you will blow yourselves away with the finish you will achieve.
Edited by 1QUICK LJ, 01 May 2006 - 07:42 PM.
#32
_LoneOranger_
Posted 01 May 2006 - 09:21 PM
Thanks.
#33
_1QUICK LJ_
Posted 01 May 2006 - 11:28 PM
#34
_gtr161s_
Posted 02 May 2006 - 08:24 AM
Thanks to everyone for all there inputs, Kev
Edited by gtr161s, 02 May 2006 - 08:24 AM.
#35
_gtr161s_
Posted 03 May 2006 - 10:38 PM
What is the procedure for preparing a panel which requires part body filler on one section only and the rest is ok.
From what i was told it must be stripped back to bare metal,cleaned, then apply the filler to section needed then im not clear which should be done next to the clean straight part of panel. Does this make sense?
#36
_1QUICK LJ_
Posted 03 May 2006 - 11:45 PM
#37
_gtr161s_
Posted 04 May 2006 - 10:16 PM
Also you say to apply etch primer over the rest of bare metal once ive finished sanding the bog, does this include going over the bog with etch??, then start with the undercoat??
This is the part where ive been getting different advice.
#38
_1QUICK LJ_
Posted 06 May 2006 - 01:42 AM
#39
_LoneOranger_
Posted 18 May 2006 - 10:06 PM
Car looks good (well the paint anyway)
After we cut it back (acrylic) and buff it , I'm sure He'll be very happy.
Regards to all, John.
#40
_LoneOranger_
Posted 27 September 2006 - 10:36 PM
The car is finished now and looks pretty good.
If some one can post pics for me I will e-mail them
Thanks to all who gave advice.
Regards, John.
#41
_LoneOranger_
Posted 27 September 2006 - 10:38 PM
Regards, John.
#42
Posted 27 September 2006 - 10:53 PM
