STROKER 6 CRANK
#76
_Gunmetal LH_
Posted 24 February 2010 - 07:14 PM
Pictures say a thousand words. Think diff gear set or rotary engine- explain it ALL day, or show me one for 2 seconds- ding! I know the red crank doesn't have counterweights opposing every crankpin so I'm dying to 'see' what you've done.
No secret- I will still go looking for other info elsewhere aswell. That's just what I do with everything. Doesn't matter how much somebody knows, I like to look further as someone else may have a different 'way' of showing something?
#77
Posted 24 February 2010 - 07:57 PM
Edited by xu1kid, 24 February 2010 - 07:58 PM.
#78
Posted 24 February 2010 - 08:14 PM
Posted 24 February 2010 - 08:23 PM
#80
Posted 24 February 2010 - 08:31 PM
It does sound fairly cranky which is why i put it so high.
Notice even though its been on the dyno he says "around".
Posted 24 February 2010 - 08:38 PM
#82
Posted 24 February 2010 - 09:39 PM
Always keep in mind how inaccurate chassis dynos can be, particularly if the person operating the facility isn't doing his job correctly. Could be say 30hp off quite easily, and the bloke posting that comment wouldn't actually be lying, just misinformed.
I'm probably a bit over-skeptical about chassis dynos - they're definitely very useful for tuning etc but as far as getting 'bragging rights' on them I'm just not sold on the whole thing really.
#83
Posted 25 February 2010 - 10:59 AM
#84
Posted 25 February 2010 - 12:45 PM
1hp per cube is reasonably achievable in a red 6. We estimated my stroker at 160 and it was only running a WW and a very mild cam.
If you couldn't make 160-180 on a cranky 202 then you need a new mechanic. That's obviously with a good spark and carb package (and it has been done with small triples and VK dizzy....)
Grant..
#85
Posted 25 February 2010 - 05:34 PM
At the wheels or at the flywheel???
At the end of the day they reckon the 73 XU-1's had 190hp at the fly but it was more like 150-160 (130 ish at the tyres) in the real world...
_Drag lc_
Posted 25 February 2010 - 08:18 PM
#87
Posted 25 February 2010 - 09:57 PM
cheers Blakey
#88
Posted 25 February 2010 - 10:14 PM
hey guys, just to add incase you dont know, that green tory in the video is from adelaide, ive seen it out on some cruises and it looks really sweet under the bonnet. its running EFI injection and coil packs i believe, so it may be 250hp, coz in some of the other videos he has, it seems to keep pullin pretty hard, cant be fenite on those HP figures tho,
cheers Blakey
what type of injection vk style or webber style injection
#89
Posted 26 February 2010 - 07:26 PM
Cheers Blakey
#90
_Drag lc_
Posted 26 February 2010 - 08:10 PM
#91
Posted 26 February 2010 - 08:25 PM
#92
Posted 26 February 2010 - 09:09 PM
hey anthony, its the weber style EFI like sonic injection have for sale on ebay. i did have a photo of it from under the bonnet, but seem to have lost it, heres a pic to give u an idea of what injection it is.
Cheers Blakey
is his sonic injection or some other type or homemade, im making up a 6 44mm throttle body setup for my engine using road bike throttle bodys and a redline 12 port manifold
#93
_Drag lc_
Posted 27 February 2010 - 05:56 PM
#94
_sonic_injection_
Posted 27 February 2010 - 09:27 PM
Weber Style EFI is completely different than my set up. Weber style retro fits are like electronic carbs. The intake is still wet and the fuel still suffers the same drop out problems. It does however improve start up through proper vapourization of fuel at low engine temps and engine speeds.
True MPFI fires the fuel into the head port and is therefore a dry manifold. The less time fuel is in the airstream the better - Hense modern Direct Injection. Mechanical Injected Sprint Cars have used a direct injection for years. Shows the large part Motorosport plays in technoligy for road cars.
How is the new Girdle going. Genuinley interested as development regardless of source keeps the Holden 6 alive.
I think the events of the last week have gotten this thred offtrack a bit, Sorry
#95
Posted 25 April 2010 - 02:40 PM
On that question about breathing capacity of V8 heads....whats the bore centres of a red 6 compared to a v8? has someone got a v8 and a red6 head gasket in the shed to lay over each other? I'm have a crazy and very economical thought.
My old boss used to tell me stories of when they were doing the 70's falcons they used to chop up cleveland heads, section them together and fit them to 250 blocks, went like the clappers but kept cracking them.
wait up, if it fits on a 250 block, it can fit on a 202.
Anyone got some Clevo heads laying around ?
#96
_oldjohnno_
Posted 25 April 2010 - 03:23 PM
Can't see how Clevo heads could possibly go onto either a 250 or a 202 (unless of course you were prepared to cut and shut each individual chamber); the SBF bore centres are very similar to a SBC.
#97
Posted 26 April 2010 - 03:12 PM
Posted 26 April 2010 - 05:41 PM
#99
_Dansthemanow_
Posted 21 October 2013 - 09:01 AM
wheels in 3rd gear without dropping the clutch.So
#100
_Dansthemanow_
Posted 21 October 2013 - 09:09 AM
