VS Commodore issues.
#26
_beergut_
Posted 12 March 2010 - 10:53 PM
#27
Posted 12 March 2010 - 11:11 PM
#28
_mello92_
Posted 14 March 2010 - 08:04 PM
But the C.A.S. cost us $80.
Sooo......lets give it to someone else to fix, eh?
Cheers for the help fellas, that 'cool it down with water' trick works a treat.
#29
Posted 14 March 2010 - 09:45 PM
$80 for a CAS? Faaarrrrk....
#30
_mello92_
Posted 14 March 2010 - 09:55 PM
#31
Posted 14 March 2010 - 10:06 PM
Just make sure it's on the correct side of the engine bay to undo the bolt, not tighten it...
#32
_mello92_
Posted 14 March 2010 - 11:08 PM
Oh wait! I did!
Dont diss the SWG stuff though. That 1/2" socket set has been through hell and the only thing that has broken has been the bar. Maybe because there was a piece of pipe on it.........
I still use my Sidchrome anyday.
#33
Posted 14 March 2010 - 11:52 PM
#34
_robrenjus_
Posted 15 March 2010 - 01:18 PM
[/quote]
no matter which way you put the breaker bar you cannot tighten the crank bolt unless you can get the motor to spin backwards lol. but if you face the handle toward the drivers side you may risk it flying off and hitting the bonnet or something. plus ive replaced a bazzillion of those C.A.S and sometimes those bolts are very very tight (rattle guns often struggle ).good luck
#35
_wayneo_
Posted 15 March 2010 - 02:01 PM
#36
_mello92_
Posted 15 March 2010 - 03:21 PM
I did have a go with the rattle gun first, it obviously didnt work either.
#37
_wraith75_
Posted 15 March 2010 - 09:27 PM
#38
_mello92_
Posted 15 March 2010 - 09:33 PM
You need the part.
You dont care what it costs.
Its that simple.
#39
Posted 16 March 2010 - 12:06 AM
[/quote]
[/quote]
Good point. That's just me not thinking.
#40
_Gunmetal LH_
Posted 17 March 2010 - 05:32 PM
DO NOT get a mate to hold it in position!
#41
_mello92_
Posted 17 March 2010 - 07:45 PM
#42
_robrenjus_
Posted 17 March 2010 - 08:56 PM
LOL, easy fellas, its been fixed!
AND.... WAS IT THE CRANK ANGLE SENSOR??
#43
_mello92_
Posted 17 March 2010 - 10:06 PM
MY BROTHER SAID THAT IT WAS FINE WHEN HE DROVE IT HOME!!
hahaha, enough caps for one night!
#44
_mello92_
Posted 25 March 2010 - 04:17 PM
Didnt start again, when hot.
#45
Posted 25 March 2010 - 06:45 PM
#46
_Woodsy_
Posted 25 March 2010 - 07:03 PM
#47
_beergut_
Posted 25 March 2010 - 07:12 PM
although a match and a rag works on every crummydoor i've ever seen lol
#48
Posted 25 March 2010 - 07:18 PM
#49
_mello92_
Posted 25 March 2010 - 07:37 PM
Kev - I dont know, I didnt replace it, on the check list though.
Will have a poke around this weekend. Have got some time, I think.
Thanks again lads.
#50
Posted 25 March 2010 - 07:49 PM
http://www.gmh-toran...=0
A couple of other things to try are swapping the fuel pump and e.f.i relays with ones that have done less work (e.g horn relay) if every thing in the c.a.s. circuit is o.k.
