Are those % for normal air Shane? Does it depend on the temperture of the ignition source?The lower explosive limit of petrol fumes (LEL) is 1.4% by volume and the upper explosive limit (UEL) is 7.6%. This means that in a fuel tank, the percentage of petrol fumes need to be within those two %ages to cause an explosion
The LEL for diesel fuel is typically 3.5% by volume and the UEL is 6.9%; ie, a higher LEL and a smaller range than petrol
So both are quite limited when you really look at it
Maybe it looks a narrow range, but how often do those particular mixture ratios occur in a typically closed container that has still has small amounts of liquid petrol changing state?
