703 replies to this topic
#451 _AD_75_
_AD_75_
Posted 05 July 2013 - 03:45 AM
Awesome job anton! im glad you went with 2K! its a bit toxic to work with but you cant beat the shine you can get right off the gun if you prep and spray it right! the car looks fantastic mate so jealous! :spoton:
#452 TerrA LX
Posted 05 July 2013 - 12:03 PM
Great work out of a garage.
#453 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 08 July 2013 - 08:41 AM
Great work Anton, looks fantastic.
#454 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 08 July 2013 - 08:45 AM
Awesome stuff! Looks a lot different to when i saw it lol!
Paint looks fantastic! Well done.
#455 notna
notna
  • 706 posts
  • Name:Reverse of username
  • Car:1976 LX L32 SL/R
Posted 16 July 2013 - 12:06 PM
Yea Mitch... it's come a long way huh! :D
Been working on some smaller things now. Trying to finish off parts that will bolt up to the body with ease, and free up some shed space, so I can progress the swinging panels.
Here is my grotty, but nicely sealed and reco'd on the inside, fuel tank.
Attached File  IMG_20130711_141121.jpg   153.48K   1 downloads
Stripped the outside...
Attached File  IMG_20130712_130731.jpg   167.94K   0 downloads
Had a few small dents to skim fill and block back, then gave it an etch prime...
Attached File  IMG_20130712_133008.jpg   155.92K   0 downloads
The local wildlife approved :)
Attached File  IMG_20130712_141634.jpg   183.27K   1 downloads
Then I 2K hi-filled it and blocked it back. Didn't snap a pic of that. A couple of days later, gave it a few coats of some silver I had already. Colour is called "Aluminium" and is a Leyland Australia colour from 71/2, that was used on wheel rims for one particular model. I had this left over from my Mini Clubman GT resto. Page #1 of this thread shows that car :)
Attached File  IMG_20130714_161747.jpg   120.92K   0 downloads
Then I gave the retaining straps a clean and paint in satin black. I lined the underside with cork, as I'm not a fan of metal on metal, especially on a fuel tank!
Attached File  IMG_20130716_105759.jpg   59.91K   1 downloads
And then, in the car, I guess it will look like this... upside down of course! :D
Attached File  IMG_20130716_105713.jpg   156.04K   0 downloads
Will bolt it up this week. Nothing goes in between the tank and the car does it?
#456 hanra
Posted 16 July 2013 - 12:18 PM
Anton you may need to ensure you have a good GND from your fuel sender to the chassis. All that paint may have insulated things. I soldered a wire onto the sender body and attached to the body.
#457 notna
notna
  • 706 posts
Posted 16 July 2013 - 12:27 PM
Oh yea? Never would have thought of that. Cheers Brad! Electricals have always been my downfall! :D
Edited by notna, 16 July 2013 - 12:27 PM.
#458 _j.e.d._
_j.e.d._
Posted 16 July 2013 - 12:53 PM
Looks purdy! Hope I can get my car to look as good as yours! (doubt it though)
#459 hanra
Posted 16 July 2013 - 03:17 PM
To easy mate. Get your self a multimeter and measure the resistance from the sender body to the body once its fitted it might be ok??? But all that paint and cork might insulate it Id imagine!!
I took the precautionary measure and solder a GND wire to the sender body whilst the sender was out of the tank.
Im in Sydney this Saturday for Motorex, do you live any where near town?
#460 notna
notna
  • 706 posts
Posted 17 July 2013 - 10:48 AM
Hey Brad, if Motorex is still at the Sydney showgrounds, I'm about a 20 minute drive north from there. You coming down just for that?
#461 hanra
Posted 17 July 2013 - 12:41 PM
Its at Olympic Park Homebush?
Yep, fly in Saturday morn, go to Motorex, then home Sunday morn first thing.
#462 notna
notna
  • 706 posts
Posted 17 July 2013 - 01:41 PM
You're keen mate. Anything in particular of interest? And yep... i'm 20 mins from there.
#463 hanra
Posted 17 July 2013 - 02:04 PM
No decent car shows this side of Brisbane mate so have no choice.... Want to see decent quality stuff so hopefully Motorex will have it? Summernats was ok, but the show hall was away to packed to get a decent look at anything.
Ill have to see how Im traveling for time on Saturday but would be pretty cool to drop in and check out your car!
#464 notna
notna
  • 706 posts
Posted 24 July 2013 - 06:13 PM
Some progress, pointers, and problems... :/
Been working on the front guards over the past week, getting them ready for colour, and then today, COLOUR! They are both the original guards, but did need a lot of work. I had previously worked them over and primed them and thought they were pretty damn spot on.
Recently I bought myself a set of really good sanding blocks, after reading some advice from others, in this thread I think! They are magic! And as you can see below, my "perfect" guards weren't so!
Guards, primed and guide coated, with long block....
Attached File  IMG_20130718_125911.jpg   184.23K   4 downloads
And now... after only minor wet sanding with 800 and the long block, you can totally see those low spots! I had no idea! I did think it was fine, after sanding it using a small cork block.
Attached File  IMG_20130718_130321.jpg   125.24K   2 downloads
After that block back, I did have to prime again, which I didn't take pics of. I again wet sanded with 800 and then..... COLOUR, in my makeshift bubble booth, which really does work well!
Attached File  IMG_20130724_172716.jpg   95.02K   2 downloads
So there you have my progress, and a pointer about blocking back... now comes... the problem! :( I put a run in one guard. I'd classify it as, a bad one :( Fortunately it's in a good spot to fix, so... how do I? I'm an ace with removing runs from acrylic, and buffing, but I'm sure 2K isn't the same.
So... what technique would be best to remove the run, and buff the paint back to a shine? Once in the past I tried this, but couldn't buff the paint back to a decent shine. It remained dull, and looked shite. Tips, advice, is appreciated.
#465 _DomDom_
_DomDom_
Posted 24 July 2013 - 07:44 PM
Wow. Those guards look nice.
Great work Anton.
#466 _sting_
_sting_
Posted 24 July 2013 - 08:04 PM
Hi where it you get the long block from.
cheers sting
Edited by sting, 24 July 2013 - 08:05 PM.
#467 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 24 July 2013 - 10:24 PM
You can get them from here:
http://www.melomotiv.../sanding-blocks
#468 TerrA LX
Posted 24 July 2013 - 10:40 PM
What sort of figures are we looking for?
Hey Anton, how do you find the duro blocks compared to the old long board etc?
#469 hanra
Posted 24 July 2013 - 10:50 PM
A dead short. 0 ohms. From the sender body to the body of the car.
#470 TerrA LX
Posted 24 July 2013 - 10:54 PM
^ Ahhh, thanx, anything higher than zero means resistance, giving a false reading, the the higher the number the worse the effect.
#471 notna
notna
  • 706 posts
Posted 25 July 2013 - 12:08 AM
Pretty sure it was you that got me onto those, and yea.... they are brilliant! I bought a set, which has 8 different shapes. Wish I had used these years ago!
#472 hanra
Posted 25 July 2013 - 07:56 AM
If you do not have a good low resistance GND for your fuel sender, it will be in-accurate.
#473 notna
notna
  • 706 posts
Posted 25 July 2013 - 05:31 PM
I love it when you come back to something the next day, and it looks BETTER than what you had first thought. The gloss and finish on these blew me away. Very proud :D
Attached File  IMG_20130725_120800.jpg   299.64K   2 downloads
Also sprayed the door hinges yesterday, and today I blocked and primed the front apron. Will hit this with colour tomorrow, then pack things up for a while. Start a new job next week and we all know how full-on that can be in those first few weeks! :o
#474 notna
notna
  • 706 posts
Posted 26 July 2013 - 06:25 PM
Last update for a little while. I was going to pack-up all my stuff today and give the garage back to the Minister of Complaints, but I figured... just one more day! :D
Primed, blocked, and primed the front apron yet again, then set it up overnight, ready for colour today...
Attached File  IMG_20130726_091030.jpg   110.15K   1 downloads
Got up early, heated the garage nicely, then hit it with some Papaya goodness. Let it set under heat lamps, then packed up EVERYTHING :(
Attached File  IMG_20130726_151111.jpg   154.89K   1 downloads
To save on storage space, I have loosely hung both guards and the front apron on the body. You can see it all coming together now. LOVE IT!
Start my new job on Monday, so will be focussed on that for a while now.
Cheers guys :spoton:
#475 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 26 July 2013 - 07:02 PM
Someone's been a busy boy. :)
Great work as usual and good luck with the new job.
