Advice for single phase TIG
51 replies to this topic
#51 Rockoz
Posted 06 April 2014 - 11:21 AM
If you are going to be doing a fair bit of welding in the shed consider paying extra for a heavier sub main from the meter box to the shed.
Usually 4mm2 will suffice for a normal shed, but consider upping the cable size to 10mm2.
Will reduce the voltage drop significantly and your welding will be better for it.
#52 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 10 April 2014 - 12:16 AM
thanks rob.had a heap of the 4mm2 cable what my brother had left over from his shed.will definetly be getting the 10mm2 size now
thanks again...Maz
