IPRA 4 Door LX
1678 replies to this topic
#451 eyepeeler
eyepeeler
  • 1,963 posts
Posted 24 October 2013 - 11:43 PM
Diff looks sick.
Re the paint, yes you have to much fluid. Depending on yoru tip size and how much thinner your running, a general starting point is 2 1/2 turns out from fully in.
As far as tight areas with a pot type gun, rip the pot off, get a fitting to screw on where the pot goes from the paint shop with a bit of line, and run the line to the pot remotely, hold one in each hand....Its a talent but its worth learning :P
Wow that diff looks tuff... Dont forget to run the orbital over the parts you have wire wheeled with around 60 grit... The wire wheel will polish the metal too much and depending on the primer it wont stick too well.
Hey Bomber, yeah just a bit to much paint brought the gun! Will set the gun to 2.5 turns to start with next time. Good tip, cheers.
Clint, will give you a call tomorrow, will rub the parts down for sure, don't need what happened to the sub frame when I painted that.
#452 _LS1 Hatch_
_LS1 Hatch_
Posted 25 October 2013 - 12:51 AM
That diff makes me tingle down in my special place... :D
#453 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,429 posts
  • Name:facebook dave
Posted 25 October 2013 - 11:40 PM
you need to get out more! haha!
#454 _LS1 Hatch_
_LS1 Hatch_
Posted 26 October 2013 - 12:48 AM
Ha Ha...
#455 eyepeeler
eyepeeler
  • 1,963 posts
Posted 26 October 2013 - 07:19 PM
I had a day of wire wheeling, cleaning then painting. I even had time to get out the home style sand blaster to clean up the door hinges. I haven't used that since I did the drivers side front wheel tub back a couple of years ago. They came up good enough.
I put the rotisserie frame to good use again and used it support both doors this time.
Attached File  01.JPG   137.01K   7 downloads
Attached File  02.JPG   104.08K   6 downloads
Attached File  03.JPG   90.4K   7 downloads
Next week I will clean up the bonnet hinges and the bonnet latch. Prime all the hinges and hang all doors and panels. Time to get the body straight.
#456 A9X
Posted 26 October 2013 - 11:57 PM
moving along,
#457 eyepeeler
eyepeeler
  • 1,963 posts
Posted 02 November 2013 - 08:05 PM
Got a few a few hours this arvo to work on getting the hinges and a few other things primed. Work has ramped up a bit and I didn't have a chance all week to work on the car. The painting skills are getting better. I turned down the amount of paint coming out the gun and it's working heaps better. Thanks to the tip givers, Bomber and Viper. The diff arrived on Thursday, had a sneak peak at it, I am stoked to have a diff like that.
Before paint.
Attached File  01.JPG   138.49K   3 downloads
I made this jig up to clean and paint the bonnet springs. This way I could rotate them to clean and paint, also put the spring under tension to get between the coils.
Attached File  02.JPG   97.6K   6 downloads
After paint
Attached File  03.JPG   124.1K   3 downloads
Attached File  04.JPG   91.33K   3 downloads
Sneak peek of the diff after it arrived.
Attached File  05.JPG   136.01K   6 downloads
Tomorrow I'm looking forward to the Forum run that Gene has got organized, gonna be a good day, might be hot as well. I heard it was going to be 36!!
Bring it on though, all those Torana's.............
#458 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 03 November 2013 - 09:53 AM
Great work getting done here progressing nicely
 That diff sneak peek is pure porn  :clappin:
#459 eyepeeler
eyepeeler
  • 1,963 posts
Posted 09 November 2013 - 07:43 PM
Cheers Garth, bit by bit at the moment.
I was a work this morning and got a couple of hours to hang the front doors and front panels and bonnet.
Working to the point where I can begin using the body filler to make it straight.
Attached File  06.JPG   106.63K   3 downloads
#460 eyepeeler
eyepeeler
  • 1,963 posts
Posted 16 November 2013 - 07:30 PM
With work still really busy, Saturday is the only day to get stuff done.
Got the flares on and started work on the body filler. Funny thing happened, the first batch of filler I mixed up went hard in just over a minute!!! To much hardener.
I also had my 39th birthday during the week. The wife made a top birthday cake, a HDT Torana cake.
Attached File  07.JPG   115.3K   5 downloads
Attached File  08.JPG   110.96K   3 downloads
Attached File  09.JPG   108.78K   4 downloads
Attached File  10.JPG   115.14K   3 downloads
#461 _LXSS350_
_LXSS350_
Posted 16 November 2013 - 10:26 PM
The cake looks finished ...... the racecar .....not so ! ..... LOL
You do know that work is taking up hours that you should be spending completing the racecar?
What happened to older and wiser?
Happy Birthday.
#462 _Bomber Watson_
Posted 16 November 2013 - 10:31 PM
Ah the fine art of squirting MEKP into polyester....
The only thing more irritating than to much is not enough....
LIttle tip with the bog, its easyer to cover a larger area, like that back door, instead of filling the several spots like you have i would just wipe the whole half of the door that needs it, far easyer when it comes to sanding it back again and getting it straight.
#463 eyepeeler
eyepeeler
  • 1,963 posts
Posted 16 November 2013 - 10:47 PM
Hi Bomber,
Yeah I worked that out after a while. I have taken that door off again, and working on it on a bench. I wiped a much larger area as you suggested, but what I did still needs more.
#464 _Bomber Watson_
Posted 16 November 2013 - 10:51 PM
Always needs more hehe.
Dont feel bad putting half a tin into one door, at the end of the day you will block 1.8kg off for every 2kg you put on.
#465 eyepeeler
eyepeeler
  • 1,963 posts
Posted 16 November 2013 - 10:54 PM
Happy Birthday.
My wife said pretty much the same thing, about the cake and my project!
Yeah, it's a bit frustrating, I was making some good headway a couple of months ago, it's slowed up a bit.
Cheers for the birthday wishes.
#466 Ice
Posted 16 November 2013 - 11:02 PM
If you need a couple of trowels for that bog craig just let me know
just kidding of coarse
#467 _LXSS350_
_LXSS350_
Posted 16 November 2013 - 11:03 PM
You where flying for a while. I was starting to feel lazy, but now your back to my pace. Lots of talk and not much action ..... LOL
Its the age thing as the birthdays tick by so does the go get em drive. .... Haha
Mind you we have gone from drowning to sweating. Hard getting down the shed with the sudden change in weather.
Edited by LXSS350, 16 November 2013 - 11:05 PM.
#468 eyepeeler
eyepeeler
  • 1,963 posts
Posted 16 November 2013 - 11:04 PM
Funny you should say that Gene, I was actually thinking that when doing it LOL.
#469 Ice
Posted 16 November 2013 - 11:10 PM
You get more on with a trowel craig ha ha
#470 _Bomber Watson_
Posted 16 November 2013 - 11:38 PM
Just use a mudflap :D
No, im not joking....
#471 eyepeeler
eyepeeler
  • 1,963 posts
Posted 23 November 2013 - 04:31 PM
I had to go into work today as the boys were in and I had to be there, I didn't do any thing to do with work so I did a bit more on the car. Would have been good to give  Datto a hand with the shed stuff. FB has given updates and sounds as though its all going well.
I worked on the roof again today, it's starting to take shape and look good.
Attached File  11.JPG   110.25K   7 downloads
Attached File  12.JPG   114.76K   6 downloads
I didn't try the mud flap Bomber, would have if I had one though just for fun and a picture to show you LOL.
#472 _Bomber Watson_
Posted 23 November 2013 - 05:52 PM
Nice stuff. Its about that point where its looking "close" that i would re epoxy it and start again, amazing how much easyer it makes it when its all one color again.
#473 _LXSS350_
_LXSS350_
Posted 23 November 2013 - 11:34 PM
What NO CAKE this week :stirpot:
#474 eyepeeler
eyepeeler
  • 1,963 posts
Posted 23 November 2013 - 11:54 PM
Diet this week,
I have been working on weight transfer within the driver / car combination as well. Less body weight for me, more weight in body filler on the car!
#475 _LXSS350_
_LXSS350_
Posted 24 November 2013 - 02:19 AM
Diet this week,
Now your onto it - Less Cake = Less Weight = More Fast
How simple is life.
