There will be a couple of us southerners looking for something to do on the Saturday night.
IPRA 4 Door LX
#876
Posted 27 September 2014 - 09:43 AM
#877
Posted 27 September 2014 - 10:23 AM
#878
Posted 27 September 2014 - 10:28 AM
I guess we can't be too far from Welbys shed as the cars will be left there and we may also be swagging there as well.
#879
Posted 27 September 2014 - 10:30 AM
#880
Posted 02 October 2014 - 07:45 PM
#881
Posted 02 October 2014 - 08:16 PM
#882
Posted 03 October 2014 - 07:14 PM
You get the idea anyway.
#883
Posted 03 October 2014 - 07:40 PM
Maybe just a dampener to lengthen the coloumn and then a single uni to join ?
#884
Posted 03 October 2014 - 07:41 PM
#885
Posted 03 October 2014 - 08:16 PM
#886
Posted 03 October 2014 - 10:07 PM
On the LS1 conversions I have worked on it was best to put a longer steering rod between the two knuckles, also for the rear pipe coming out of the head we shortened the outside of the column and just let the steering shaft untoched for more clearance. Made it much easier for extractor clearance.
Edited by myss427, 03 October 2014 - 10:08 PM.
#887
Posted 04 October 2014 - 12:03 AM
I would definitely try to get the bottom uni closer to the steering rack for maximum header clearance/space if at all possible
Might try it with the extension on the column side instead of the rack side. Good point fellas.On the LS1 conversions I have worked on it was best to put a longer steering rod between the two knuckles, also for the rear pipe coming out of the head we shortened the outside of the column and just let the steering shaft untoched for more clearance. Made it much easier for extractor clearance.
You have any photos of what you did?
#888
Posted 04 October 2014 - 12:05 AM
There is quite a bit of difference in the alignment of the 2 shafts. I need 2 uni's for that reason.Are you sure you need a double?
#889
_LS1 Hatch_
Posted 04 October 2014 - 01:14 AM
And make sure you use high-temp duct tape on it around the headers.
#890
_LS1 Taxi_
Posted 04 October 2014 - 07:57 AM
Also for pipe clearance purposes, a few guys have redrilled the steering column plate which bolts onto the firewall to shift it towards the rail 10mm or so...
Sometimes it makes all the difference ![]()
I love this project.
#891
_greg2240_
Posted 04 October 2014 - 11:38 AM
if anyone can get the pipes thru there I'm sure you can by the quality of your work so far, keep it up.Greg
#892
Posted 04 October 2014 - 02:42 PM
#893
Posted 04 October 2014 - 02:47 PM
#894
Posted 04 October 2014 - 03:11 PM
If you are not happy with the setup then it may be worth considering revising the engine mount design. You could unbolt and flip the lower half of the engine mount then move the mounting point on the k-frame away from the steering shaft.
Edited by ls2lxhatch, 04 October 2014 - 03:13 PM.
#895
Posted 04 October 2014 - 03:44 PM
#896
Posted 04 October 2014 - 08:25 PM
Cheers Greg, looks like what I did today will help with pipes getting down and past the column and starter motor.
#897
Posted 08 October 2014 - 07:05 PM
#898
Posted 08 October 2014 - 07:30 PM
#899
_LS1 Hatch_
Posted 09 October 2014 - 02:02 AM
And good having new wipers in case a storm moves through the shed.
#900
Posted 09 October 2014 - 05:35 AM
Really good to see your ingenuity with the watts link on the rear end.
Keep going
