I hope you don't need to use the put me back on my wheels button next to the Alarm Reset
IPRA 4 Door LX
#1426
Posted 17 July 2016 - 02:48 PM
#1427
Posted 17 July 2016 - 03:57 PM
It's a Motec key pad. It performs all the functions I need from the car, like the lights, indicators, starter motor etc. I have 2 spare spots for any other function I might add to the car, such as driving lights for instance.
Don't forget the air con!, looking fantastic must be killing you for a drive.
#1428
Posted 17 July 2016 - 06:14 PM
Very cool !
Cheers Jeff
So do I, lol.
I am getting past the point of crazy, wanting to push the start button and turn it over.Don't forget the air con!, looking fantastic must be killing you for a drive.
#1429
Posted 17 July 2016 - 06:41 PM
#1430
Posted 17 July 2016 - 07:06 PM
Motec is cool stuff, can do so much with it, limit is usually what you can think of.
Haven't had the opportunity to explore it yet, can't wait to plug a laptop in when it going to have a play.
#1431
Posted 17 July 2016 - 07:34 PM
wow...what a build......very impressive mate.
#1432
Posted 17 July 2016 - 07:49 PM
Cheers Col, appreciate it. It's certainly been a long build of the car.
#1433
Posted 17 July 2016 - 09:36 PM
Just a very small example.
The dash and keypad look awesome and racey.
#1434
Posted 17 July 2016 - 09:38 PM
Sounds good Daz, better get the bastard done so I can muck around with it, lol.You can do stuff like having 3-4 even more switchs on one wire, with a different resistor on each switch, then program each switch for a different function.
#1435
Posted 17 July 2016 - 10:28 PM
We want to hear the sweet noise haha
#1436
Posted 22 July 2016 - 07:35 PM
The rules allow me to attach it to the door. The size of the net is to big so I have folded it over and shortened the rod.
Welded the brackets to the window frame.
The net hung in the right spot, just need a way of fixing the lower section.
Took the door card off and bolted 2 brackets the door which a rod will thread through.
All sorted and happy with it.
#1437
Posted 23 July 2016 - 10:41 PM
#1438
Posted 25 July 2016 - 07:32 PM
Got radiator hose and oil filter sorted.
Also got the stepper sensor in on the throttle body.
Pretty boring items, but another step closer.
Edited by eyepeeler, 25 July 2016 - 07:33 PM.
#1439
Posted 25 July 2016 - 07:37 PM
#1440
_LS1 Taxi_
Posted 25 July 2016 - 08:22 PM
So long as it screws up and seals it should work.
One thing to check is that you have the remote filter plumbed correctly as most filters have a drain back valve and if plumbed backwards it will starve for oil.
#1441
_LS2 Hatch_
Posted 25 July 2016 - 08:39 PM
Keep up the god work!
I use a Z9 filter with an inbuilt magnet in the bottom
Daz, you could have told me about the flow direction!
#1442
Posted 25 July 2016 - 09:47 PM
I run the Z418HE on mine.
Thanks for that Daz, will check flow just to be sure, will do that tomorrow night.
Cheers Grant, so f*%kn close now it's not funny. The magnet sounds like a good idea.It's coming along a treat.
#1443
Posted 25 July 2016 - 11:42 PM
Looks good mate, have you worked out what sort of aircleaner you will be running yet?
Bits and shits.
#1444
Posted 26 July 2016 - 12:32 AM
Hey Sam, was thinking of a KN cone filter directly onto the throttle body or off a 90 degree silicone elbow. Longer term I will probably make a plenum mounted under the bonet to a A9X hole in the bonet.Looks good mate, have you worked out what sort of aircleaner you will be running yet?
What do you think of the window net? See any issues with it?
#1445
Posted 26 July 2016 - 02:37 AM
The Z160 has a 13/16-16 (UNF) thread, it was used on LS engines up until 2006 when they changed to a M22 x 1.5 thread (Ryco Z663).
Does your remote filter system have a built in bypass valve? If not then you should consider using a K&N HP-3003 which has a built in bypass valve.
If it does have a bypass valve then I would use the largest filter you can find. The K&N HP-3002 should fit.
#1446
Posted 26 July 2016 - 08:41 AM
Thanks for the info Andy. Daz mentioned a drain back valve which would be a non return valve and you mention a bypass valve. Which is better or are they the same thing? Bypass and drain back mean different things so I would think they are not the same.
What is the main disadvantage to not have either feature?
#1447
_LS1 Hatch_
Posted 26 July 2016 - 08:46 AM
The plenum idea sounds good...the filter right on the throttle body just tends to suck up a lot of hot engine bay air...cool outside air is better when you can of course.. ![]()
#1448
Posted 26 July 2016 - 08:47 AM
Agreed Jeff, the KN will be just to get me going. Plenum in the development of it.
#1449
_LS1 Hatch_
Posted 26 July 2016 - 09:04 AM
Looking good of course by the way as well !
#1450
Posted 26 July 2016 - 10:23 AM
