gtr 10/72 brisbane car- need info please
92 replies to this topic
#26 S pack
Posted 14 July 2011 - 08:54 AM
what about the cast aluminum piece in the rack and pinion steering - is it's left un painted alloy
Mine was painted black, 4/73 Brisbane build.
#27 S pack
Posted 14 July 2011 - 09:30 AM
Just had a look at a very original looking 1592 date coded rack housing I have and it has remnants of black paint on the alloy part.
#28 frash da bucket
frash da bucket
  • 1,890 posts
Posted 14 July 2011 - 10:22 AM
Hi Grant,
Mine is a very original rack also,its got the remains of black paint too 1.9.72.
Cheers John.
#29 _Agent 34_
Posted 14 July 2011 - 12:54 PM
great as I painted prior to checking and painted it black.
thanks boys.
#30 _Agent 34_
Posted 01 January 2012 - 04:28 PM
i have a heap of stuff to go to the platers and and also to be re painted and need the following finishes;
1) linkages for M20 - i assume that they are plated - silver , the ones i had were painted gold under the red and i have wire brushed them back to metal and cannot tell if they are plated, they should be ?
2) bumper bar brackets - satin black
3) bumber bar brakets - the small ones that connect to the side of the car on each corner
lastly - the sun visors , parts that screw onto the roof lining and also the mirror stem seem to have a painted as i can scratch it off , is this correct ?
#31 frash da bucket
frash da bucket
  • 1,890 posts
Posted 01 January 2012 - 09:35 PM
Hi Grant,
My Mirror stem,and and the sunvisor brackets are original silver from the factory.
Cheers John.
#32 S pack
Posted 01 January 2012 - 09:46 PM
G/day Grant
1) M20 linkages. (per my original 4/73 LJ) Not sure what the blackish grey finish on the shift rods would be called but not zinc or cad plated. Maybe some form of bluing or sprayed hot metal finish?
2) Front bar brackets (chassis rail ones) - Chassis black so satin should be close enough.
3) All other front and rear bar brackets - silver zinc.
4) sunvisor mounts and rear vision mirror - Painted in a silver colour, but I have no clue as to the name or code for this colour.
Dave.
#33 _Agent 34_
Posted 02 January 2012 - 05:25 AM
thanks Dave\/ john
The linkages rods are a blue grey as you have said and may be i don't need to be plated at all, just some more wire brushing.
I may give one more clean up today with wire brush and also paint stripper and leave outside for two days to see if they start to show signs of rust then make the call.
If not re assemble the box all painted and clean.
#34 _Agent 34_
Posted 05 January 2012 - 01:59 PM
Rear Spares has two consul 's and corresponding gear shift knob's
1) has the "h" pattern indicator on the consul and has a golf ball pattern on the ball and no " h " pattern
2) the other has no " h " indicator on the consul and the ball is smooth with the "h " pattern on the ball
Which one do I need, there is obviously a change over date between the two different one ?
#35 S pack
Posted 05 January 2012 - 10:47 PM
G/day Grant
The H pattern indicator plate on the consul and the Roebuck grain pattern knob (ball)
are what you need for a LJ GTR.
Dave
#36 _Agent 34_
Posted 06 January 2012 - 04:38 PM
Roger that Dave . Thanks .
#37 _Agent 34_
Posted 18 March 2012 - 08:44 AM
head lights and blinker configuration front.
Can someone tells me the right configuration for the blinker and head lights. eg - do i have the parking lights in the headlight and the clear blinker or something else.
Rares has the headlights and need to order the correct one and also blinker covers and assembly
thanks grant.
#38 MONZA1
MONZA1
  • 448 posts
Posted 18 March 2012 - 08:53 AM
Parking lights in the blinkers Grant.
#39 S pack
Posted 18 March 2012 - 08:55 AM
thanks grant.
G/day Grant
Clear indicator lenses (park lights in the indicators). Std headlights (no park lights).
Your indicator bodies should have two wires and take a double filament globe.
The change over to amber lenses and park light headlamps wasn't until mid December '72 (approx).
Dave
Edited by S pack, 18 March 2012 - 08:56 AM.
#40 _Agent 34_
Posted 18 March 2012 - 10:17 AM
Roger that. thanks.
#41 _Agent 34_
Posted 29 April 2012 - 06:45 PM
Dave, and others,
Is the bracket that holds on the rat trap painted black. this is the one that bolts direct onto the chassis
Edited by Agent 34, 29 April 2012 - 06:46 PM.
#42 frash da bucket
frash da bucket
  • 1,890 posts
Posted 29 April 2012 - 08:19 PM
Hi Grant,
The rat trap is painted black grant,assemble it together,put grease on the metal pins,and bag it up,don't forget to do the metal pin on the cluch pedal too,that will be worn also,and check the metal strap what the clutch rod fits into,you will have to repair that too.
Regards John.
#43 S pack
Posted 01 May 2012 - 01:55 PM
Dave, and others,
Yep, black.
#44 _Agent 34_
Posted 30 May 2012 - 07:02 PM
OK - Question
We are getting pretty close to the interior paint code and finishes;
What colour and the type ( satin etc) was the following parts
1) steering column and shroud - satin
2) steering wheel - gloss
3) metal facia across the dash / glove box
Don't stuff up guys as this will be gospel that I tell the shop.
Ps i have no idea
Edited by Agent 34, 30 May 2012 - 07:03 PM.
#45 S pack
Posted 30 May 2012 - 07:27 PM
OK - Question
Ps i have no idea
G/day Grant
40X trim?
If so you need Medium Gloss Black - Dulux (Dulon) paint code 578 04149.
Used for instrument panel (metal part) and glove box lid, steering column, inside upper of front A pillar (beside windscreen), front seat adjuster guard and seat side arms. The LJ GTR steering wheels appear to me to be the same black as the dash and steering column.
Dave.
#46 _Agent 34_
Posted 30 May 2012 - 07:32 PM
Legend Dave Again.
Sweeeeeeeet, 1 more mill
#47 _Agent 34_
Posted 21 January 2013 - 05:23 AM
Can someone tell me if the following bolts are universal to other holden models;
bonnet hinges bolts that fix to chassis and bonnet
boot fixing bolts
thanks
eg like HG etc, they should be the same
Edited by Agent 34, 21 January 2013 - 05:24 AM.
#48 S pack
Posted 21 January 2013 - 08:20 AM
G/day Grant
Can't say with 100% certainty but pretty sure HQ bolts are the same.
#49 frash da bucket
frash da bucket
  • 1,890 posts
Posted 21 January 2013 - 12:20 PM
Hi Grant,
The boot bolts that go boot hinge are the same colour as the car,the bonnet bolts are a bit longer than the boot bolts,i do think HQ are bigger bolt larger because of the larger bonnet and different hinges,than the torana.
Regards John.
#50 _sunburst73-xu1_
_sunburst73-xu1_
Posted 21 January 2013 - 03:58 PM
And the bolts that bolt to the bonnet are different to the ones that bolt to hinge frame in the engine bay.
