Berro's Rusty UC to A9X HATCH
#201
_berro59_
Posted 19 April 2012 - 09:48 PM
76lxhatch- Im going to alliance rim repairs to get the outers changed to 16*11 inch or 16*10.5 to fit 295's plus. I wll have to change the rear axles to HQ.
Hey tyre biter- i was lost in the wilderness so I was trying find my way back to my torana mojo!
My compessor blew up (3rd cheap one) so i have saved up to by a 17 cfm 100litre unit. It rips!
I have done most of the blocking down and need to do some fibre glass work on my rear spoier and bonnet scoop. I not happy with the lines.
Post pics soon.
#202
_berro59_
Posted 24 April 2012 - 04:10 PM
Did some work on the scoop today!
Cut it down to 4 inches and started the fibre glass work. Post pics soon.
My Torana mojo is slowly returning.
#203
Posted 24 April 2012 - 07:35 PM
Good to hear Berro and even better to have you back in the game - post pics when you can please - very keen to see you efforts.My Torana mojo is slowly returning.
Cheers, TB
#204
_geepee_
Posted 24 April 2012 - 07:38 PM
you are a dead set genius !
talk about testing the patience of the Pope !
you should paint it tuxedo black - the body is dead set straight and aligned with the stars !
#205
_berro59_
Posted 08 May 2012 - 09:21 PM
Black would be mad but Velocity red is locked in! I have a few other little ideas in my head but you will have to wait and see.
Got picks!!!!!! These are the simmons B45's 16 inch with 235s.
#206
_berro59_
Posted 08 May 2012 - 09:26 PM
_berro59_
Posted 08 May 2012 - 09:29 PM
_berro59_
Posted 08 May 2012 - 09:35 PM
Still need to change to HQ stud pattern.
They are going to be a tight fit.
Faaaaaaaaaaaaaaaaaaat!
Posted 08 May 2012 - 10:00 PM
#210
_berro59_
Posted 08 May 2012 - 10:14 PM
These are the wider a9x flares.
#211
Posted 08 May 2012 - 11:13 PM
#212
_berro59_
Posted 08 May 2012 - 11:17 PM
I only like the polished ones on the FR series. (like on porche)
#213
_berro59_
Posted 08 May 2012 - 11:29 PM
Using an old bonnet as a guide i cut the edges of the scoop to get the height to 100mm. I used the edge of the bonnet as a guide to get the shape right.
I will extend the tip to meet the nosecone.
_berro59_
Posted 08 May 2012 - 11:32 PM
Good for street look. But also looks semi drag!
I like it!
_berro59_
Posted 08 May 2012 - 11:39 PM
I left the end with out resin/loose so i can flip over later and better mould it to the bonnet one dry.
_berro59_
Posted 08 May 2012 - 11:45 PM
Then cut the edges off with a grinder. Sanded it flat and added a light skim of filler.
Now need to block back and smooth.
Post more picks soon.
_berro59_
Posted 09 May 2012 - 08:42 PM
17 cfm at the nozzle. 100l tank!
This gets my air tools cranking. and good enough to spray a car!
Chinese one $600 new!
_berro59_
Posted 12 May 2012 - 08:32 PM
I am going to use L brackets to hold the bonnet scoop down.
Put a few more layers of fibreglss where the brackets will meet the scoop. Added a few more layers to the tip to make it stronger.
I will counter sink rivets at these points and then skim over the top of them with filler.
_berro59_
Posted 13 May 2012 - 08:17 PM
Its ready to be painted and joined to the bonnet.
Posted 13 May 2012 - 10:49 PM
Just looking at it though, will the back end of it definitely clear the windscreen, wiper arm and plenum cover with the bonnet raised? I don't mean to sound like a smartarse but just thought I'd mention it, just in case.
#221
_berro59_
Posted 14 May 2012 - 07:40 PM
I have checked with the bonet raised and yes it clears the windscreen and plenum cover but didnt think about the wiper arm.
Oh Sh@t!
I will check tonight.
#222
_berro59_
Posted 14 May 2012 - 10:01 PM
#223
_LS1 Hatch_
Posted 15 May 2012 - 09:22 AM
_berro59_
Posted 15 May 2012 - 08:38 PM
Thanks for your help.
Your car is a beast!!! Love the new AMG brakes!
#225
Posted 17 May 2012 - 09:29 PM
