206 replies to this topic
#1 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 06 September 2011 - 12:55 PM
Hi all
Have wanted to do this for a while now. I know there has been a few 308 build threads of late, and I have truly loved reading all the info in these threads, but as I am an avid fan of the "ol 308" I just wanted to share others peoples experiences with building 308's and the horse power figure you have achieved.
I am not interested in stroker combos at all as I am purely keen to see what people do to their 308's and what sort of power they achieve.
My first combo was a totally stock bottom end, standard compression, standard bore 308 which I fitted a Crane 286 hydrualic cam, new lifters, very well ported Red heads with Yella Tearra shaft mounted rollers, Edelbrock Performer manifold, 670 holley and Roll Master timing gear set. The exhaust was a set of 1 5/8 extractors, into a dual 2 1/2 inch engine pipes and through into a single 3" system. From this combo I achieved 238 RWHP. The car flew for such a simple combo.
As a result of a rear main oil leak, made worse from the drive to and from Toranafest last year, I decided I would pull out the engine and fix the dreaded leak. As you do in this situation, you check everything out and decided to refreshen the whole lot up. This brought about my next combo.
I maintained the red flowed heads and rollers as they were really well done, changed cam to a Crane 304 hydraulic, bored and honed the engine and fitted a set of 30" Flat top pistons with new rings. As well all new King bearings, A9L rods, ARP rod bolts, ARP studded Main kit and balanced the whole bottom end assembly. I also kept the Edelbrock Performer maniflod and 670 Holley. From this combo I got 265RWHP. I was pleasantly surprised given the engine has only traveleld 400kms since I have built it so there should be a little more in her when it is properly run in and has loosend up. Needless to ay the car goes heaps better!
So let me know your combos so we can share the info for future references. I don't mine if you have fitted alloy heads etc, just not interested in stroker combos as it doesn't typify the true results for a 308 CI motor,
Cheers, Gerry
#2 _Liam_
_Liam_
Posted 06 September 2011 - 06:45 PM
Cool mate. Nice idea for a thread.
#3 _Mint_
_Mint_
Posted 06 September 2011 - 07:35 PM
ok Gerry..heres mine
304 stock stroke x rods
30 over flat tops w/ file back moly rings
decked about 30 thou to get 10:0.1 comp
ARP head,mains and rod bolts
KING bearings
ASR street pan
POWERBOND balancer
early red heads,bowl job,port matched inlet an exhaust
1.94x1.60 valves dble springs,screw in studs,roller rockers,moly pushrods 3 angle valve grind
ACL RACE SERIES head gaskets
MAXITORK manifold w/ 1" supasuka
650 hp holley d pumper
old bosch dizzy with LUMENITION(breakerless conversion)
MSD6AL box
extractors with full twin 2" exhaust
cam crow 5690 hyd 524 lift 296 309 dur
balanced..deburred block..............................it made 185 rwkw @6250 rpm at its only dyno run with wheel spin crappy ta's..probly got 215- 220 kw in it?(260-275hp)
Edited by lxssv8, 06 September 2011 - 07:38 PM.
#4 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 06 September 2011 - 07:45 PM
Very similar sounding combo to mine so you should get around about the figures you anticipate. Mine was a 198 RWKW from memory.
Also hoping to hear from some on the old skool boys who have built many 308 combos over the years....
Thanks for puttimg yours up lxssv8.
#5 _Mint_
_Mint_
Posted 06 September 2011 - 08:02 PM
no probs mate..probly a big head..err port job would have done wonders..but the thing flies as is..ya gotta love 1200 kgs cars ay?:)
#6 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 06 September 2011 - 10:24 PM
Hi Gerry
I think you can get a lot of information out of the stroker combos.
The power you get out of any engine come from the heads (as long as all other part support).
The problem is the revs. The smaller the cubes the more revs. So your 396 making 500HP @ 6500 would = roughly 355 500HP @ over 7000 and 308 500HP @ 8000 or over.
So the part needed to pull 8000 revs would brake most budgets.
But still if you see a stroker you like, take not and with more rev you can be in the ball park. More important there part list will give you a good idea on what you will need.
Nice work, you have a good combo and a lot of fun to come.
#7 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 07 September 2011 - 08:01 AM
Good point Adam. I am certaninly not apposed to strokers, just wanted to see what sort of combos others have and what sort of power they have gained from the trusty old 308's. I am keen to see cam and head combos i.e VN heads with a solid cam etc. I have built several 308's over the years but only ever done smaller stage 3 type motors with around 200RWHP mainly as they were daily dtivers at the time. The last two combos have been fun and retuned my mechanic skills a little as I have been off the tools for over 12 years now....
Thanks for your input though!
Gerry
#8 76lxhatch
Posted 07 September 2011 - 08:49 AM
Interesting thread, I'm reasonably happy with mine:
Standard 308 crank, spike rods and 30 thou over flat top pistons
Yella Terra/L34 style big valve HQ heads, around 10.2:1 compression
Edelbrock Performer manifold, modified Quadrajet on 1" spacer
Accel billet dizzy and MSD 6A/blaster ignition
Pacemaker 1 5/8" tri-ys with twin 2 1/4" exhaust
Cam is a baby solid 228 deg @50 thou, around 450 thou lift
High volume sump, Romac steel balancer, Yella Terra roller rockers
There is no dyno here so I don't have much idea what the power output is. I've run it down the drag strip a few times but no traction - started at mid 14s before a lot of changes and hasn't got any faster, just spins the wheels more (not only difficult to get off the line but spins them quite badly into third gear now)! Got a pair of Hoosier Quick Time Pros to have a play around with when the season starts again later this year, should be interesting.
It does what I want it to do at this stage, next step would probably be a stroker with similar configuration and probably a bit bigger cam.
#9 _LH8VD69_
_LH8VD69_
Posted 07 September 2011 - 10:46 AM
I can feel a sticky coming on !!! Edit out comments of course. I just want to throw a few things in here feel free to edit out if we turn sticky :) My old VH Commy had a 308 red which I spent alot of coin rebuilding unfortunately can't remember all the combo as it was the late '90's so I won't start but it made 189 rwk which I think is great for red head 40 thou over donk. I took it to an old guy at a local dyno shop for fine tuning and he fitted a 1" spacer under the 650DP carby and then proceeded to roll off a flat 200 rwk ! On the road it was very noticeable. Has anyone heard of this kind of gains from such a small add on?
#10 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 07 September 2011 - 12:32 PM
Wow that is a good power gain. I have heard that the spacer can work. I wanted mine all under the bonnet so won't be trying a spacer. 200RWKW is pretty quick anyway in a torry :-)
Good combos lads, keep them coming fellars.
#11 jason365
jason365
  • 58 posts
  • Name:jason
  • Car:76 lx ss racer
Posted 07 September 2011 - 01:59 PM
spacers can work if the combo needs it, ive seen as much as 20rwkw from just adding a 1'' open spacer.
#12 76lxhatch
Posted 07 September 2011 - 06:22 PM
My spacer is mainly there because the throttle linkage gets stuck (wide open!) on the manifold without it...
#13 _LH8VD69_
_LH8VD69_
Posted 08 September 2011 - 02:32 AM
The engine was in a VH but was pretty quick all the same.Would have been great in a Torana for sure :)
#14 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 09 September 2011 - 07:42 AM
Common lads. I am sure there are plenty of good combos out there that people have built. This is a not a pissing into the wind comp, just a good thread so that people can see what has worked for others to base their project off. Struggler??? Old Johhno?
#15 mr5000
mr5000
  • 3,460 posts
  • Car:77 lx 4door
Posted 09 September 2011 - 08:15 AM
i havent had my car dynoed yet but the lil 308 slap job goes alright
red 308 standard bore flat top high comp pistons crow 5603 cam i think
red pre pollution heads and manifold all matchported at home slightly tweaked quaddy shitbag extractors with twin 2 1/4 system bosch hei dizzy with summit 6al style ignition
with the old banjo and the 13s it ran a best of 14.7 @98mph with heaps of wheel spin having open centre and 205s
plannign to get back to the track as soon as i get some big wheels now its got a 9 inch 3.5gears truetrac
#16 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 09 September 2011 - 12:10 PM
Good to hear. A 14 second pass is nothing to sneeze at! I haven't run mine down the quarter but will in the near future. Not sure on what sort of time I would achieve...
#17 mr5000
mr5000
  • 3,460 posts
  • Car:77 lx 4door
Posted 09 September 2011 - 07:19 PM
i was pretty happy considering the whole build including parts machining and buying the block topped in at 1200 have had the dizzy graphed and added the 6al since and had carby tweaked more feels like it has alot more power so looking forward to its next outing aiming for a mid 13
#18 _oldjohnno_
_oldjohnno_
Posted 09 September 2011 - 08:17 PM
I haven't had much to do with Holden V8s so I'm afraid I can't help. Tony Knight in Adelaide has done some very impressive work with HQ headed 308s though, and he posted details and dyno figures of a very successful build on some other forums a few months back (I think you'd find it on the aussiev8 forums, possibly pf as well). It was a basic but very effective combo and I think his path would be a very good one to follow. As with any engine good headwork will be essential.
#19 ozyozyozy
ozyozyozy
  • 953 posts
Posted 09 September 2011 - 08:47 PM
i can get in on a bit of this action.
been using 308`s for years.
current engine is 308
vt heads, 2.02 valves
platinum roller rockers
big valve springs
solid roller cam, 560 thou lift, cant remember rest of the specs.
bronzed lifter guides
4 bolt mains
standard crank, prepped
scat h-beam rods, standard holden length
srp forged pistons 10.5 to 1 comp
inner active single plane manifold
barry grant 650 double pumper, made a cold air tray to sit on top of carby
trend pushrods.
acl race bearings
uuummm cant remember much else at moment
346rwhp, i spin it to 7000rpm.
id like to go back to a standard vn rod with bushed little end or go to a 6 inch manley conrod, something lighter than the scat rods(there a fairly heavy aftermarket rod).
and future goal want 7500rpm, love the sound.
#20 _Liam_
_Liam_
Posted 09 September 2011 - 10:29 PM
big valve springs
4 bolt mains
trend pushrods.
acl race bearings
More power than you can poke a stick at. Impressive.
Edited by LX Torry Freak, 09 September 2011 - 10:30 PM.
#21 AbsynthHatch
AbsynthHatch
  • 765 posts
  • Name:Mark
Posted 09 September 2011 - 11:09 PM
Oldjohnno do have a links to that build thread on those forums you mentioned please mate
#22 _oldjohnno_
_oldjohnno_
Posted 10 September 2011 - 08:26 AM
This one is a detailed look at a 365 stroker with HQ heads for a hillclimb car. It made about 400rwhp and ran 13.1 with no traction.
This thread is an interesting rundown on the HQ heads for the engine above. An absolute work of art.
This thread is probably a bit more on-topic, it's about dyno testing a TP dual-plane manifold when they were first released. It lists the engine specs of the quite mild HQ headed 355 which ended up making 356rwhp.
A ha! This is the one I was thinking of. A stock stroke 308, quite a basic build but made 488fwhp.
There's probably more out there if you search for it. He does some great work (particularly head porting) but unfortunately injured his hand pretty badly and was off work for a while. So now he's in catch-up mode and won't be taking on any new work for some time.
#23 TerrA LX
Posted 10 September 2011 - 08:40 AM
Actually the topic states no strokers please.
#24 _oldjohnno_
_oldjohnno_
Posted 10 September 2011 - 09:01 AM
Watch out, the Off Topic Police are on patrol... I'm just gonna act natural and try to delete the top three links while they aren't looking... :)
#25 TerrA LX
Posted 10 September 2011 - 09:12 AM
Spammer.
