206 replies to this topic
#51 _Mint_
_Mint_
Posted 13 September 2011 - 08:06 PM
i reckon.....240-250 rwkws about 330 clidesdales at the treds
#52 retired308
retired308
  • 187 posts
Posted 13 September 2011 - 08:21 PM
back in 1988 i had a chev offroad engine machined up it had
stock 308 crank all crack tested and balanced
l34 rods arp bolts
plus .30 trw forged pistons 10.5 to 1 comp
high energy pan
steel balancer
hei ignition
perry extractors single 3 inch with resonator only
bert jones 37-70 solid cam
torker manifold port matched
750 dp holley, blue pump holley
brookfield hand finished heads
rrockers 1.65 screw in studs l34 valves brown springs
very heavy steel flywheel -hv oil pump, 3core radiator, penrite oil 25w50
hand made clutch
toploader and 3.50 lsd 9 inch with steel hemisphere- 26 inch mickey t slicks it ran 12.7- went 13.0 on 13 inch circuit slicks
with a 60hp nitrous kit it went 11.715 at 117mph.
after getting a thrashing at the drags and driven everyday on the street a rebuild went like this-port matched exhaust-
hand finished dave baines a9l rods with 7/16 bolts-scattershield- redone hei system- 7/16 studs and new 7/16 rrockers-stock oilpump put in,
trw hand finished trw forged pistons- 2 holley blue pumps and 1/2 lines all thru, les heintz special clutch- 288 solid cam, flowed same red heads- with 4.56 gears went 12.4 then
the first run using nitrous killed the clutch on first attempt in c1990-91 at drags. tried to fix it but gave up racing after that.
john brookfield told me stock 308 had 140-160 hp, the l34 had 240 270 and the race cars l34s he did had around 340-360 in early 70s.
chev offroad thought mine had around 360 at flywheel plus 60hp nitrous kit added on. have some videos on vhs must find them all.
#53 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 14 September 2011 - 07:50 AM
Yep, love the old sckool stuff. I think 350 FWHP is pretty good out of a 308 especially in a Torana....
#54 ozyozyozy
ozyozyozy
  • 953 posts
Posted 18 September 2011 - 01:56 PM
im keen to improve on my numbers, i want alloy heads, and if i get them comp is going to 11 to 1, and with that,want a cam change also to get some more rpm. dont want to do this unless we can make it relatively reliable. all the holden powered targa cars here are needing engine rebuilds at about the 4000km mark, dosent sound like much, there only getting used a few times a year, and when they do the poor engines are hurt.
#55 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 19 September 2011 - 05:03 PM
Alloy heads are a big improvement from what I have seen and experienced. A good cam to suit them will produce good power. Be interested to see how it goes for you...
#56 mr5000
mr5000
  • 3,460 posts
  • Car:77 lx 4door
Posted 12 November 2011 - 02:49 PM
i havent had my car dynoed yet but the lil 308 slap job goes alright
red 308 standard bore flat top high comp pistons crow 5603 cam i think
red pre pollution heads and manifold all matchported at home slightly tweaked quaddy shitbag extractors with twin 2 1/4 system bosch hei dizzy with summit 6al style ignition
with the old banjo and the 13s it ran a best of 14.7 @98mph with heaps of wheel spin having open centre and 205s
plannign to get back to the track as soon as i get some big wheels now its got a 9 inch 3.5gears truetrac
had it thrown on the rollers today made 148rwkw would have liked more on the way home gave it a bit of stick and noticed it was pining at wot probably should have checked the timing before i put it on haha
#57 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 13 November 2011 - 06:58 AM
This is the first time I have seen this thread (was overseas all of Sept.)
Back in the day we would turn out heaps of flat top, HQ headed, standard stroke, Crane 286, Performer based combos. Depending on how much money you had you could also get big valves and roller rockers. Often we would rering the short, tidy up the standard valved heads, fit LT1 springs and a timing set, tweak the Q jet and slide in a 286 and these things would go really well for the minimal $$$ spent. People still remind me of these $1500 stormers today !
One of the 308's I built for myself back then used 327 lumpy top pistons and heavily cut heads. It ended up with almost 12:1 comp. The cam was a Crow grind, the same one Alan Grice used to set the top speed record at Mt Panarama in 1984. It was in my old Group C A9X when it was still road registered, 4.44 gears and a Super T10. Stuck with the Performer and an 850 Holley ! Well it had no torque at all and was hard to get going but once it got to about 4500rpm it would start to move and at 5500rpm it was singing ! Once they pulled the lead out of petrol it pinged like a demon and I had trouble keeping head gaskets in it. A customer ended up buying it (I have never heard a better sounding engine and it was the major selling point !) once I pulled the lumpy top pistons and fitted flat tops. I don't know where it ended up from there. I did have it on a chassis dyno but this was 18 odd years ago and I can't remember what it made. I do remember it was the highest HP from a stock stroke engine they had seen at the time. I later rebuilt the genuine L34 race engine that came with the car (it had a much smaller cam and flat tops) and it was a better mannered thing all round but had nowhere near the top end of the Grice combo.
These days I can't remember the last stoke stroke HQ 308 I did for a customer that wasn't a turbo engine. The cranks are so cheap and VN heads are everywhere. I beg those with VN heads to use a stroker crank to get the air flowing quicker.
The engine I did for my own VH SL/E is super low budget..... its a standard bore, dish top VP 304 short, honed, new rings and bearings. I used a pair of HQ heads that had the bowls throated by the machine shop and I blended them in by hand. Waggott 239 @ 050 single pattern solid, Performer and Q jet. The only new parts were the cam, lifters, gaskets, rings and bearings. Everything else was second hand. Exhaust is 1 5/8" tri Y and a single 2 1/2". Its a lot of fun with the T5 and sounds great but I haven't got it onto the dyno yet.
#58 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 13 November 2011 - 06:34 PM
Bout itme you posted up mate :-). Your experiences are always worthy of hearing!
Your first combo is similar to what I had before my current combo bar the flat top pistons and it produced 240RWHP. It really went well considering it was a totally stock bottom end. The new combo is just getting better and better as I get k's up on it. Can't wait to run it down the quarter. I now swear by the Crane 304 hydraulic, fantastic cam. The 286 was great too but no where near as much mid range power as the 304.
Hopefully others will continue to share their combos..
#59 ozyozyozy
ozyozyozy
  • 953 posts
Posted 20 November 2011 - 11:33 AM
well, an update with my 308.
recently been having some oil pressure issue`s. started with oil surge, my light blinked at me during an event, then during cold starts pressure would go up and down, for about 30 secs to a minute, never done this before.
tried mucking around with everything i can externally to no succes, bugger.
pulled engine apart, main bearings have been hurt. we think, difficuilt to be 100% sure, oil pickup gasket is at fault.
also found oil pump drive gear, after 700kays is stuffed.
we`v tried both type of oil pump drive gears, coated steel and bronze, both crap. yes i no bronze you have to replace periodically, but to be half to 2/3rds worn after 700km`s, some of our events you travel 1000km`s in a weekend.
so after lots of talks alot of research im biting the bullet, dry sump it is.
#60 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 23 January 2012 - 07:26 PM
An update for those interested.
Took the hatch in for a dyno run today after upgrading my carby from a 670 to a 770 Holley to see what was happening. I gained 8 RWHP but the fuel mixtures were hugely too rich. Running around 10-11:1 air fuel ratio. Will have to get it properly jetted and should pick up another 10 or so RWHP. Ended up with 273.4 RWHP. Anyway it is nearly at its potential which is good news. The standard fuel system seems to be keeping up too.
Cheers, Gerry
#61 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 23 January 2012 - 08:09 PM
Hey Gerry, what dyno do you use ?
#62 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 24 January 2012 - 11:14 AM
It was done on a dyno dynamics one. Jake Sanderson owns it.
Dave at Gastune is re-jetting my hatch on his dyno tomorrow. His is an old school one. Will let you know what figurs I get off his too.
Edited by Redslur, 24 January 2012 - 11:15 AM.
#63 _V6 UC_
_V6 UC_
Posted 26 January 2012 - 12:08 AM
Be interesting to see how much it varies. We have seen some big variations here on dyno days at other places
#64 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 26 January 2012 - 05:48 PM
Yep would have to agree with you V6 UC. From what I have heard several people that placed their car on the Summernats dyno this year said their figures were down a fair bit from the previous years Summernats. Just goes to show that they all seem to differ.
Unfortunately I didn't get dyno figures yesterday. I asked him for them too but he said most of the tunning needed was in the low to mid range and he only ran it to 4800rpm on his dyno. The car goes really well now and seems to rev a lot more freely. I will take it back to the place I got the figures checked orignally to see if it made any diference to overall figures. At the end of the day it is now runing at its potential and that was the aim and the stock fuel system seems to be keeping up.
#65 _torrymatt_
_torrymatt_
Posted 08 February 2012 - 12:24 AM
Five years ago i raced my LH 308 down the quarter before i pulled it down for a full resto..Mainly just to get before and after times. Basically the motor was stock with a elderbrock dual plane manifold and a 600 vac holley she ran a 14.5..motor was tired, trimatic was sludgy and it had a 1 wheeler banjo lol..
Now im a thew weeks away from having her back on the road FINALLY!
New Engine combo:
Holden 308 40'' thou o/s
acl race flat tops
acl bearings/gaskets
full arp kit
standard crank
'X' rods
VN heads s/s valve 2.02/1.60 massively ported(flows 565hp on bench)
1.60 ratio yella terra platinum rockers
286 heatseeker hyd cam
h/e sump
jp performance std vol oil pump
harrop single plane high rise manifold
750 dp holley HP
holley blue fuel pump
Turbo 350 stage 2 shift kit/b&m 3000rpm stall
9'' 3.9 ratio, 28 spine axles
15''x8's rear and 15''x7's front using Mickey Thompson sportsman s/r street slicks on the back!
Not 100% on hp figures or 1/4 mile but if it didn't do 12's i would be disappointed!
#66 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 08 February 2012 - 06:55 AM
Sounds like 12's are quite possible with your set up.. Let us know how you go when you do run it down the quarter and also if you do get it dynoed.
I am taking my hatch back to be rechecked on the dyno this afternoon after having the carby proffesionally rejetted. Be interesting to see if it makes a difference to overall HP figures. I will be hopefully running mine down the quarter in the next 2 months.
Cheers, Gerry
#67 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 08 February 2012 - 07:24 PM
Took my car back for a dyno run and check this afternoon after having the carby rejetted. I ran it in both shootout and non shootout mode just to get a comaprison on figures. In non shootout mode it ran 272 RWHP and in shootout mode ran 281 RWHP, which is up 8 RWHP after jetting the carby. Pretty respectable figures form a fairly tame to drive non stroked 308.
The air fuel ratios are now spot on across the range running around 12.5:1 so the tuner did a top job. Anyone in Canberra after a good carby tuner I am happy to provide his details.
The car definitely goes harder now and since my fuel log upgrade and 3/8 fuel line mod from the fuel pump to the carby have seemed to sort out all fuel starvation proplems in the top end. I am a very happy camper.
Cheers, Gerry
#68 _Liam_
_Liam_
Posted 08 February 2012 - 07:45 PM
Good stuff Gerry, bet you're stoked! Should chuck a vid up of it running!
#69 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 08 February 2012 - 08:16 PM
A mate of mine did film it and will send it to me. Knowing him he will chuck it up on Youtube anyway.
He ran his RT E49 replica at the same time. Managed 223 RWHP which is rerally good for a 6 pac...
#70 _LH SLR 3300_
_LH SLR 3300_
Posted 09 February 2012 - 04:55 PM
If you're interested, this the specs of my orange LH.
304 30"thou pistons, standard rods
Camtech solid cam
VN heads, Crane rockers
MSD ignition
Harrop dual plane manifold, 650HP Holley carb
Standard fuel line, standard mechanical pump
Tri-matic full manual valve body, 3000rpm convertor
Detroit locker 9" 3.7 gears
Pacemaker headers, dual 2 1/4" exhaust.
Has run a 12.5@109mph on 205x65x15 street tyres, planning to run it on radial slicks soon & hopefully better that time.
#71 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 09 February 2012 - 07:24 PM
Nice set up. Any horse power figures? Should probably be similar to mine. I think the thing that will rob my car of a good quarter mile time is that the diff ratio is only 3:36.1.
#72 _ooLo31_
_ooLo31_
Posted 14 February 2012 - 10:36 AM
hi struggler just a quick question how do you avoid the valves hitting the lumpys ,im thinking about doing a similar combo
#73 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 14 February 2012 - 03:18 PM
Valve to piston clearance wasn't a problem. I think I laid the lump back a bit to match the 308 valve angle but it wasn't too much.
Build it !
#74 _ooLo31_
_ooLo31_
Posted 14 February 2012 - 03:59 PM
Build it !
thanks mate i,m looking at a couple of options but i dont want to go the 355 way
#75 _AD_75_
_AD_75_
Posted 15 February 2012 - 12:14 AM
I dont have any HP figures for this engine but it was a high 12, low 13sec motor out of my LH L31.
Block: Red HT cast SL/R block 30 thou over fitted with HV oil pump and stock sump
pistons: Cast flat tops +30
rods: L34
Heads: Genuine L34 fitted with Crane roller rockers/retainers/guideplates/double valve springs
Cam: Crane Solid (cant remember exact grind but fairly big)
Carb: Holley 780vac sec with L34 HO style Velocity stack and L34 fuel pump. (wish i had a pic of the stack it was pretty cool looking and cant find one anywhere!)
Ignition: L34 twin point dizzy
Inlet Manifold: Performer
Exhaust: Full Genie dual 2.5 inch system (This system sounded great)
Gearbox: Ford Top Loader fitted with hurst indy shifter
Diff: Ford 9inch 2.72 and 3.7 LSD gearsets
The sad thing is i ripped this engine out of my L31 and sold it off to another guy with an aqua LH SL/R 5000 replica so i could fit a 350SBC because i wanted more power..we had no idea back in the day that the original HT engines would be sought after by L31 restorers or that real SL/R 5000s would go up in value so much.. :cry:
Wont post my other 308s as they are strokers.. :P buuut i will say that the 308 im building atm is a 355 stroker and i think if you want ultimate power out of a 308 stroking is the way to go, even though the purists will probably consider it cheating!.. :tease:
Edited by AD_75, 15 February 2012 - 12:23 AM.
