I'll show you how to cut hatch back guards from start to finish
108 replies to this topic
#26 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 16 October 2011 - 09:18 PM
What are you using to do the cuts Ruts?
This
Attached File  cutting guards 043.jpg   99.85K   3 downloads
#27 rodomo
Posted 16 October 2011 - 09:19 PM
O.K.......................continue.............................
#28 rodomo
Posted 16 October 2011 - 09:22 PM
I call mine Excalibur! :D
#29 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 24 October 2011 - 06:42 PM
Ok back on this again, I did a bit over the last few days. First picture is of the two flares the old and the new. I wanted to post this pic when I started but I forgot to download it. You can the difference between the two. The new flares are 20mm wider than the old.
Attached File  cutting hatch guards 081.jpg   126.11K   3 downloads
Early in the piece I said that these hatch flares were the best fitting flares that I had ever seen. If you are wondering why I had to cut the bottom of them to fit it was to cover the old flares holes in the 1/4 panels so that I did not have to paint the 1/4's. When I was trying trying to fit them when I cut the end of the flare I found that the passenger (near side) fitted very well but when I got to the driver's side (off side) I found that I had to modify the end of the sill panel to get the flare to fit and line up. Where I am pointing is the where I had to cut to get the small end to fit.
Attached File  cutting hatch guards 100.jpg   127.68K   3 downloads
Attached File  cutting hatch guards 084.jpg   115.68K   2 downloads
Once the end of the sill panel was cut the little piece went on fairly well but there was still a bit to do.
Attached File  cutting hatch guards 085.jpg   107.57K   3 downloads
Attached File  cutting hatch guards 101.jpg   133.09K   2 downloads
To finish getting the end piece to fit on the driver's side I had to grind a bit out of the end piece. If you have a look at the two bits you can see the difference between the two. I had to grind a bit out to the gap between the wheel and flare near the same size on both sides. Here are some pics of the two sides and I am pointing to the area that needs grinding away to match the two up.
Attached File  cutting hatch guards 090.jpg   101.54K   2 downloads
The blue line is where I have to grind away the flare end piece to match the two up.
Attached File  cutting hatch guards 087.jpg   162.66K   2 downloads
Attached File  cutting hatch guards 088.jpg   192.54K   2 downloads
Attached File  cutting hatch guards 091.jpg   116.66K   2 downloads
Attached File  cutting hatch guards 092.jpg   102.96K   2 downloads
This is what it looked like after I ground the end bit down.
Attached File  cutting hatch guards 093.jpg   98.27K   2 downloads
Once the end was ground down it went on but I had to put a screw in the end to hold it in place until I glassed it.
Attached File  cutting hatch guards 102.jpg   137.06K   2 downloads
Once the end of the flare was on both sides and I was happy with fit I put the car on the ground to see how it all looked. I was very happy with how both sides lined up and there was only a few millimetres difference either side.
Attached File  cutting hatch guards 094.jpg   182.4K   1 downloads
Attached File  cutting hatch guards 095.jpg   173.51K   1 downloads
Attached File  cutting hatch guards 096.jpg   173.66K   1 downloads
Attached File  cutting hatch guards 097.jpg   149K   1 downloads
Attached File  cutting hatch guards 098.jpg   154.95K   1 downloads
When I was happy with the way it all looked I put the car back on the hoist. Now I learned something from our mate Dirtbag. He taught me to tape over whatever I wanted to glass then put body filler over the tap to hold it all in place so that I can take it off and glass the inside, thanks Tim yo taught me a valuable lesson.
Attached File  cutting hatch guards 103.jpg   141.95K   2 downloads
Attached File  cutting hatch guards 104.jpg   116.42K   1 downloads
Attached File  cutting hatch guards 105.jpg   136.42K   1 downloads
Attached File  cutting hatch guards 106.jpg   120.07K   1 downloads
Attached File  cutting hatch guards 107.jpg   141.82K   2 downloads
Attached File  cutting hatch guards 108.jpg   166.91K   1 downloads
#30 hanra
Posted 24 October 2011 - 07:18 PM
Huh..... I havnt taken notice of anything you have written because Ive been to focused on this rear end......FARK YEAH
#31 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 24 October 2011 - 07:26 PM
Once the outside was done I took the flares off and glassed the insides, very happy
Attached File  cutting hatch guards 113.jpg   157.01K   2 downloads
Attached File  cutting hatch guards 112.jpg   173.02K   1 downloads
Attached File  cutting hatch guards 111.jpg   162.34K   1 downloads
Attached File  cutting hatch guards 110.jpg   182.89K   1 downloads
Attached File  cutting hatch guards 109.jpg   134.42K   1 downloads
Attached File  cutting hatch guards 127.jpg   150.58K   1 downloads
While the flares were off, glassed and drying I took to the 1/4's with my trusty 9 inch grinder and trimmed the arches to give us plenty of room for big wheels.
Attached File  cutting hatch guards 117.jpg   154.23K   1 downloads
Attached File  cutting hatch guards 116.jpg   127.38K   1 downloads
Attached File  cutting hatch guards 118.jpg   170.38K   2 downloads
Attached File  cutting hatch guards 119.jpg   130.42K   1 downloads
Attached File  cutting hatch guards 120.jpg   108.95K   1 downloads
Attached File  cutting hatch guards 121.jpg   130.74K   1 downloads
Attached File  cutting hatch guards 122.jpg   202.25K   1 downloads
Attached File  cutting hatch guards 123.jpg   220.13K   1 downloads
Attached File  cutting hatch guards 124.jpg   112.5K   1 downloads
Attached File  cutting hatch guards 128.jpg   109.33K   1 downloads
Attached File  cutting hatch guards 125.jpg   137.39K   1 downloads
That's it for now. Hopefully I'll have the 1/4's all welded up tomorrow. More pics soon.
#32 _SS Hatchback_
_SS Hatchback_
Posted 24 October 2011 - 09:09 PM
hope you have this finished by the weekend Dennis :) and the hatch looks the same shade as your sunburn from the drag day
love your work mate
#33 Tyre biter
Tyre biter
  • 982 posts
Posted 25 October 2011 - 02:52 PM
Ruts, just fantastic.
I have to be honest, I thought the flares are just what they are, fit how they fit, and one can only work around them.
Never even considered they could be made to fit so well.
Love watching this thread despite it teaching me what I should have done.
Cheers, TB
#34 _rob350hatch_
_rob350hatch_
Posted 25 October 2011 - 07:56 PM
well thats just awesome.cant wait to drive it.it looks the goods with those 285's.i take back everything i thought about you :tease:
#35 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 26 October 2011 - 05:25 PM
Thanks but don't worry, I STILL think the same about you.
#36 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 03 November 2011 - 06:18 PM
Ready for more updates. Once the flares were off I ground the body filler off and then removed the blue tape and was left with a pretty good surface to work with on the outside.
Attached File  cutting hatch guards 130.jpg   120.96K   1 downloads
Attached File  cutting hatch guards 131.jpg   132.71K   1 downloads
As you can see in the above photo I ground back a bit of the outside so that the fibremat filler has something to stick too. The fibremat filler is a body filler that has fibreglass mixed into it. It dries hard and can be used to fill large areas if need be but I try to use it over surfaces. If I have to fill large areas like I did on the bottom of the flares I use the fibreglass repair kit. Here is the fibremat.
Attached File  cutting hatch guards 158.jpg   168.16K   1 downloads
This is what it looks like once applied the top of the flares.
Attached File  Copy (2) of cutting hatch guards 133.jpg   161.37K   1 downloads
Attached File  Copy (2) of cutting hatch guards 132.jpg   113.8K   1 downloads
Here is the fibremat once it has been sanded back.
Attached File  Copy of cutting hatch guards 147.jpg   92.4K   1 downloads
Once the fibremat was sanded I applied a top coat of body filler.
Attached File  Copy of Copy of cutting hatch guards 148.jpg   105.61K   1 downloads
Here is the finished product once the top coat was sanded.
Attached File  Copy of cutting hatch guards 149.jpg   138.96K   1 downloads
When the flares were finished (or as I thought) I put them back on the car to see if they held in place. With the flares refitted I found two areas on the passenger's side that sat a bit too far away from body. This creates a problem when you put the flare piping between the flare and the body. If the gap between the flare and body is too large then the piping will fall in between the flare.
Attached File  Copy of cutting hatch guards 150.jpg   99.9K   1 downloads
Attached File  Copy of cutting hatch guards 151.jpg   97.91K   1 downloads
Attached File  Copy of Copy of cutting hatch guards 152.jpg   105.43K   1 downloads
To fix the gap I put a few strips of tape on the body where it needed to filled. I then used the fibremat to fill the gap while the flare was still on the car.
Attached File  cutting hatch guards 169.jpg   99.88K   1 downloads
Attached File  cutting hatch guards 170.jpg   98.05K   1 downloads
I ground down part of the flare before applying the filler so that it had something to bite too.
Attached File  cutting hatch guards 171.jpg   105.67K   1 downloads
Attached File  cutting hatch guards 172.jpg   101.4K   1 downloads
Once all the filler was rubbed back I took the tape off the body and did a refit to see it all looked. The flare piping will be a snug fit now. I'm very happy with the fit so the flares are off to the painters.
Attached File  cutting hatch guards 180.jpg   121.57K   1 downloads
Attached File  cutting hatch guards 181.jpg   148.04K   1 downloads
#37 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 03 November 2011 - 07:08 PM
Now the flares done it's time to concentrate again on the body. This is where we left it last time. Both inner and outer guards were evenly trimmed so when we put the filler piece in it will site flat.
Attached File  cutting hatch guards 119.jpg   130.42K   2 downloads
To fill the gap I used some 1.6 sheet steel. I went to a mates workshop who let me take a couple of strips.
Attached File  cutting hatch guards 134.jpg   143.77K   2 downloads
Attached File  Copy (3) of cutting hatch guards 135.jpg   132.51K   1 downloads
The good thing about this is that I can easily bend it over my knee to get required shape of the wheel arch.
Attached File  cutting hatch guards 138.jpg   172.44K   1 downloads
Attached File  Copy of cutting hatch guards 137.jpg   130.75K   1 downloads
Attached File  Copy (2) of cutting hatch guards 136.jpg   158.67K   1 downloads
I then bent the strip into shape against the arch until I got it fairly close.
Attached File  Copy (2) of cutting hatch guards 140.jpg   144.3K   1 downloads
Attached File  Copy (2) of cutting hatch guards 141.jpg   138.62K   1 downloads
when I got it close I trimmed it to the correct length.
Attached File  Copy of cutting hatch guards 142.jpg   131.39K   1 downloads
Attached File  Copy of cutting hatch guards 143.jpg   132K   2 downloads
Once it was all trimmed it virtually sat in there by itself.
Attached File  Copy of cutting hatch guards 146.jpg   148.8K   1 downloads
Attached File  Copy of cutting hatch guards 144.jpg   150.93K   1 downloads
Now once I was happy with the fit it was time to start tacking the strip into place. You have to be careful when welding onto a body shell especially when it has the interior and other items still inside. In side the 1/4 panels can have body filler, sound deadener or anything else that can catch fire. To help prevent fires I bought a fire blanket from Bunnings.
Attached File  cutting hatch guards 163.jpg   215.2K   1 downloads
Attached File  cutting hatch guards 164.jpg   110.53K   1 downloads
What I did was stuff the fire blanket in the 1/4 panel which will help stop sparks from flying through the car. You can also use these to throw over windows to stop sparks from marking the glass.
Attached File  cutting hatch guards 166.jpg   137.14K   1 downloads
Attached File  cutting hatch guards 167.jpg   90.27K   1 downloads
Attached File  cutting hatch guards 168.jpg   174.22K   1 downloads
When the blanket was in place and I was happy with the fit I tacked the strip in place with the INSIDE edge matching up directly with the inside edge of the wheel arch. This leaves most of the strip sticking out past the outer edge of the 1/4 panel. This makes it easier later on to trim the outer edge of the strip. Just think of the strip as a very small wheel tub if that makes sense. All the welding will be finished tomorrow.
Attached File  cutting hatch guards 179.jpg   132.81K   2 downloads
Attached File  cutting hatch guards 178.jpg   145K   1 downloads
Attached File  cutting hatch guards 177.jpg   152.09K   3 downloads
Attached File  cutting hatch guards 176.jpg   178.25K   4 downloads
Attached File  cutting hatch guards 175.jpg   107.87K   2 downloads
I thought I would play around and see if my new 335/35/17's would fit under the guards while the car was on the hoist. You can see that they stick out a bit but the exhaust was stopping them from going in far enough. They will fit with a bit of work.
Attached File  cutting hatch guards 155.jpg   141.2K   2 downloads
Attached File  cutting hatch guards 156.jpg   127.43K   2 downloads
Attached File  cutting hatch guards 157.jpg   152.61K   1 downloads
#38 _LH SLR 3300_
_LH SLR 3300_
Posted 05 November 2011 - 10:09 PM
Love watching a fellow panel beater work his magic on a Torana. If i ever decide to flare one of my Toranas, i'll definately call on you for some advice, it's one job i've never quite had the confidence to tackle.
#39 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 05 November 2011 - 10:47 PM
Thanks mate, back at ya.
#40 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 17 November 2011 - 04:52 PM
Ok all this the last instalment so here we go.
The flares were sent to mate of mine in Bargo who has a panel shop who specialises in custom work. The name of the shop is Pro Image and my mates name is Carl. So if you are looking for any sort of panel and paint work done in the Bargo and surrounding areas give him a call on 0412125860 and tell him Dennis sent you. He also hires out his spray booth if you want to tackle the your own paint job. Here are the flares, I'm very happy with the finish.
Attached File  cutting hatch guards 186.jpg   192.61K   2 downloads
Attached File  cutting hatch guards 187.jpg   179.78K   1 downloads
Before fitting the flares I covered the welds and filled the gaps in the welds with Sikaflex.
Attached File  cutting hatch guards 190.jpg   146.83K   3 downloads
Attached File  cutting hatch guards 189.jpg   171.47K   1 downloads
Attached File  cutting hatch guards 188.jpg   133.62K   1 downloads
I also took the chance to paint the bolts and washers black. They were chrome when it arrived so I thought black would look much better. Who cares what the owner wants......lol. When I paint flare bolts I stick them through the bottom of a box and I tape the washers to a flat surface. I double the masking tape over on itself so that it sticks to the table and then washers stick to the tape.
Attached File  cutting hatch guards 191.jpg   118.3K   2 downloads
Attached File  cutting hatch guards 192.jpg   222.1K   1 downloads
Attached File  cutting hatch guards 193.jpg   205.55K   1 downloads
Attached File  cutting hatch guards 195.jpg   187.4K   1 downloads
Attached File  cutting hatch guards 194.jpg   158.21K   1 downloads
Once the bolts and washers were dry I put the flares on the car but only started the nuts finger tight. What this does it allows me to slide the flare piping between the flare and the body.
Attached File  cutting hatch guards 196.jpg   167.37K   1 downloads
Attached File  cutting hatch guards 197.jpg   159.77K   1 downloads
Attached File  cutting hatch guards 198.jpg   133.1K   2 downloads
When installing the flare piping I start from the rear and work towards the front. When I reach a bolt I mark the spot where the bolt is with a pen and then I slice enough out to fit around the bolt.
Attached File  cutting hatch guards 199.jpg   119.13K   1 downloads
Takes a bit of time and fiddling but I was very happy with the fit.
Attached File  cutting hatch guards 200.jpg   136.85K   2 downloads
Attached File  cutting hatch guards 201.jpg   133.29K   2 downloads
Attached File  cutting hatch guards 202.jpg   173.76K   2 downloads
Attached File  cutting hatch guards 203.jpg   164.47K   1 downloads
Attached File  cutting hatch guards 204.jpg   159.25K   1 downloads
Attached File  cutting hatch guards 205.jpg   154.09K   2 downloads
Attached File  cutting hatch guards 206.jpg   166.15K   1 downloads
#41 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 17 November 2011 - 05:19 PM
When the rears were done I took the opportunity to install the 4mm piping and paint the front bolts and washers. Here it is with the large piping and chrome bolts.
Attached File  cutting hatch guards 207.jpg   165.35K   2 downloads
Attached File  cutting hatch guards 208.jpg   115.77K   1 downloads
Attached File  cutting hatch guards 209.jpg   126.92K   1 downloads
Here are fronts with the small piping and painted bolts and washers, much better.
Attached File  cutting hatch guards 210.jpg   137.03K   1 downloads
Attached File  cutting hatch guards 211.jpg   166.08K   2 downloads
Attached File  cutting hatch guards 212.jpg   167.77K   1 downloads
Front and rears all done. Rear 15x10 hotwires now fitted to stay on before car is taken off the hoist.
Attached File  cutting hatch guards 213.jpg   215.93K   2 downloads
Attached File  cutting hatch guards 214.jpg   150.76K   1 downloads
Once the car was back on the ground it was moved out of the shed and given a good wash. It was then taken out the front where I took these photo's with hopefully one very happy owner standing nearby. I think it looks pretty good. What do you guys think.
Attached File  cutting hatch guards 215.jpg   371.08K   2 downloads
Attached File  cutting hatch guards 217.jpg   355.68K   3 downloads
Attached File  cutting hatch guards 218.jpg   375.92K   1 downloads
Attached File  cutting hatch guards 219.jpg   279.55K   1 downloads
Attached File  cutting hatch guards 220.jpg   351.41K   1 downloads
Attached File  cutting hatch guards 221.jpg   336.18K   2 downloads
Attached File  cutting hatch guards 222.jpg   308.14K   1 downloads
Attached File  cutting hatch guards 227.jpg   301.14K   2 downloads
Attached File  cutting hatch guards 226.jpg   359.21K   1 downloads
Attached File  cutting hatch guards 225.jpg   384.2K   1 downloads
Attached File  cutting hatch guards 227.jpg   301.14K   1 downloads
Attached File  cutting hatch guards 223.jpg   318.96K   1 downloads
Attached File  cutting hatch guards 228.jpg   416.75K   1 downloads
Attached File  cutting hatch guards 229.jpg   355.73K   1 downloads
Attached File  cutting hatch guards 230.jpg   234.2K   1 downloads
As the car drove away I took a few happy snaps with one very happy owner driving. When Rob got home he called me and told me that the guards did not rub even with a car full of kids. I'm happy, he's happy and I hope you guys are happy with this thread.
Attached File  cutting hatch guards 231.jpg   356.73K   1 downloads
Attached File  cutting hatch guards 232.jpg   281.98K   1 downloads
Attached File  cutting hatch guards 233.jpg   203.04K   1 downloads
THE END
Edited by Ruts, 04 July 2019 - 09:04 PM.
#42 _homer_
_homer_
Posted 17 November 2011 - 05:34 PM
Great job, and very informative. Thanks
#43 Statler
Posted 18 November 2011 - 12:02 AM
:spoton:
#44 TerrA LX
Posted 18 November 2011 - 01:31 AM
Thanx Dennis... I must resist flaring the hatch...
#45 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 18 November 2011 - 08:17 AM
Great job, now I have to change my piping to the smaller one. Yeah & get Rob to straighten that rear #plate-it looks a little pissed.
#46 Ruts
Ruts
    How Fast!?
  • 1,118 posts
Posted 18 November 2011 - 08:53 AM
Yep, just like the owner.
#47 _toranarama_
_toranarama_
Posted 18 November 2011 - 09:12 AM
There's only 2 states to be in...
Queensland
OR
P!$$ed ;) :P
Top job by a top Cop btw :spoton:
#48 MRLXSS
Posted 18 November 2011 - 12:18 PM
SHIT HOT!!!!
#49 tsn007
tsn007
  • 1,022 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 18 November 2011 - 08:42 PM
well done Dennis
Now its time to do yours lol !!
#50 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,429 posts
  • Name:facebook dave
Posted 18 November 2011 - 09:37 PM
top job ruts
whats next?
