GMH Dealer Built LJ V8 Torana's
315 replies to this topic
#76 S pack
Posted 09 August 2012 - 04:42 PM
Dave
Willow has this 1973 LJ V8's in his Head
^^^^^ that and vacant space?
#77 xu2308
Posted 09 August 2012 - 04:55 PM
Edited by xu2308, 16 February 2018 - 07:32 PM.
#78 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 10 August 2012 - 03:55 PM
i will let you know that 60 sets of heads and 60 engine blocks (308) where made for the 72 lj toranas. They are easy to pick as the are the only ones with an x on the end of the head and the blocks have a x on the inside.
Edited by lcxu105, 10 August 2012 - 03:56 PM.
#79 A9X
Posted 10 August 2012 - 04:37 PM
don't believe you
#80 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 10 August 2012 - 05:52 PM
they where later put into the l34's. according to Tony torana RIP from Brisbane who was right into the a9x's
#81 sagman
sagman
  • 331 posts
Posted 10 August 2012 - 10:23 PM
The cylinder case assembly for the LJ V8 was an existing production unit and had new part no. bearings and studs and windage tray, it had a new piston and rod assembly and used an existing crankshaft assembly. The oil pan held 7 pints of oil.
The heads had a new part no. and had new inlet valves and new springs and dampers. There were no other major changes to a standard 308 but in a nutshell the parts could well have formed the basis for the L34 engines.
As far as 60 engine and block sets , well the requirement of 200 cars would have meant 200 engines for the initial homologation of the V8 LJ , as this was a major change to the vehicle that was already homologated.
From that point on any other 'go fast bits ' could have been homolgated as they were previously ( and as we know into the future) , only a very small number of cars would have been required to have all the homologated parts fitted to satisfy Cams ( thanks Dave 'S Pack' )
Laz
#82 _outer control_
_outer control_
Posted 10 August 2012 - 11:23 PM
x blocks dated 73 so that blows your theory
#83 unclefestal34s
unclefestal34s
  • 1,130 posts
Posted 11 August 2012 - 09:56 AM
well with all respect to the late Tony M..this X bit is a big crock shit..
L34s were the first of the 308s to have extra webbing at back of the block in 74
and it was one there strength selling points as they were trimatic pattern
from then on when the HJ holdens were fitted with turbo 400s
all the 308s had the extra webbing at the back of the block
this bit about 60 special blocks in 73 is garbage
let alone this magical X THAT APPEARED on the blocks
and yes i have seen a X on a 308 block but it nothing to do
with a L34 engine let alone this cast X on the cylinder head
i've personally owned over a dozen GENUINE L34s in a
28 year period and been around some off the engine builders from that time
i've had hand in purchasing perhaps another dozen...i've seen
my fair share of dismantled L34 engines to know a few facts..
in the last 10 years or so with these cars rising in value a lot
claims with distorted facts that be can't proved or disproved have emerged
more so to sell things and make a fast buck....
#84 sagman
sagman
  • 331 posts
Posted 11 August 2012 - 10:40 AM
Does any one have the part nos. for the heads and inlet valves for the L34 as well as the piston and rod nos.
Laz
#85 A9X
Posted 11 August 2012 - 11:19 AM
don't believe you
rest my case
#86 xu2308
Posted 11 August 2012 - 11:23 AM
#87 _outer control_
_outer control_
Posted 11 August 2012 - 12:25 PM
Laz
no secret there are thousands of copies of the part no,s but l34 heads had the same part no cast into them as normal heads just not doctored by dave bennet. L34 valves with light turned down stems give no support with a high lift cam think about it
Edited by outer control, 11 August 2012 - 12:26 PM.
#88 sagman
sagman
  • 331 posts
Posted 11 August 2012 - 05:08 PM
Reason for asking is that the heads for the V8 LJ have an 'N' alongside of the part no for the head on the parts listing which denotes a new part number.
Head 2825893 inlet valve 28258913 spring/damper asm. 3927142 are all listed as new part nos. for the 308 which would suggest they had not previously been used . other components for the engine have a 'C ' alongside which is for carry over parts while all new components have an 'N'
So again do these numbers appear on any other later than mid '72 308 engines as they are clearly listed as available only on 82911 bodies and given the cars were to be the basis for a performance application would suggest these components are in some way performance enhancing.
Laz
#89 S pack
Posted 11 August 2012 - 05:39 PM
Hi Laz
I don't know about any of the other parts you mentioned however the valve spring/damper assy Pt No. 3927142 is listed as part of the L34 'High output package'.
Dave.
#90 yel327
Posted 11 August 2012 - 06:28 PM
There a story's that the early 308H Engines had forged steel cranks and thicker blocks ??????.
As the 308H Block is the first 308 Engine Block, you would think the V8 LJ Block would be the 308H Block, but the Lone o Ranger
V8 Protoype had a QT 308, so seems they were using the QT Block, but in essence they are all 308 Blocks anyway.
The very early Brougham 308 engines have a slightly different crank, they have HP on them too like the blocks. These are probably ones cast back when the engines were first in development, afaik they were not forged and none that I have seen were forged but some sound different, probably a different material cast prior to the new foundry opening in 1967 (guess only). LJ V8's would simply have been HQ blocks just like the early LJ XU-1's were. 308H blocks are no different to HQ blocks anyway, the only difference is the early HT Brougham engines and a few in other cars once the 308 was made available outside Brougham have HP on them rather than 308.
From what I can understand the engines you find with X on the side, these are simply pilot versions of the new HJ block style. The early ones appear around 3/73 or thereabouts. You also see pollution red heads with an X on them, these were early version of the new HX pollution heads used in some lte HJ's. The X is there so it is obvious what they are from the outside.
#91 xu2308
Posted 11 August 2012 - 06:42 PM
Edited by xu2308, 16 February 2018 - 07:31 PM.
#92 _RichoX1_
_RichoX1_
Posted 11 August 2012 - 11:56 PM
XU2308
Tell me you haven't seen or talked about these markings before
Attached File  X1.JPG   62.08K   6 downloads
X Casted Heads 73 to 76
Attached File  X2.jpg   51.56K   3 downloads
1 X cast Rods 2 A9L Rods 3 Stock Rods
Attached File  x3.jpg   84.43K   5 downloads
X cast Blocks From 73 to 76
Attached File  B1.jpg   8.25K   3 downloads
B cast Heads from commadors
The X Heads, Blocks and Rods started in the LH SLR 5000
I have started to really like the color Willow
The only Willow Bathurst Xu1 in existence WOW WOW WOW :stirpot:
Attached File  ani-gifs-emotes-691072081.gif   25.19K   2 downloadsAttached File  ani-gifs-transportation-1496395962.gif   22.04K   2 downloads
Edited by RichoX1, 12 August 2012 - 12:01 AM.
#93 S pack
Posted 12 August 2012 - 02:09 PM
XU2308
So they have an X cast into them! What does it have to do with Dealer built LJ V8 Torana's?
#94 _RichoX1_
_RichoX1_
Posted 12 August 2012 - 02:28 PM
The X representing the First L34 casted engines
Of 73 to 76
the casted engines and heads that dave bennet was to work on
the pro zoomed Xu2 production run 150 specials
Dealer biult XU1s are mock ups to bear as a early derivative of the soon to be release Xu2 of 73
Dealer built xu1s and LJs didn't exist because of engineering laws that started in i think it was 69 or 70
No car left the factory or a dealer ship with out its exact verified engine to VIN it was not permitted by engineering laws
Edited by RichoX1, 12 August 2012 - 02:32 PM.
#95 unclefestal34s
unclefestal34s
  • 1,130 posts
Posted 12 August 2012 - 02:31 PM
a stock hq 308 manifold has a X next to the part number...wow that must special
#96 _RichoX1_
_RichoX1_
Posted 12 August 2012 - 02:34 PM
does it have a 74 L34 part number and the X if it does thats to sute them engines
#97 _RichoX1_
_RichoX1_
Posted 12 August 2012 - 02:37 PM
But its only the first 250 X castings of the L34 that was designated for the XU2
#98 unclefestal34s
unclefestal34s
  • 1,130 posts
Posted 12 August 2012 - 02:56 PM
hi richo
i have a stock mid 72 statesman 308 engine mid 1972 build untouched engine with a million miles on 11qt prefix,..the manifold has a X on it..
i'll tell a little secret but you got promise not to tell anyone..THE FACTORY L34 MANIFOLD doesn't have a part number on it..
#99 _RichoX1_
_RichoX1_
Posted 12 August 2012 - 03:01 PM
hi richo
Ha Ha the one i sold about 5 or more years back did there none as Brock manifolds they are semi pollution
I never seen a X on one any how only the heads rods and blocks
Edited by RichoX1, 12 August 2012 - 03:05 PM.
#100 xu2308
Posted 12 August 2012 - 05:10 PM
