After more research I finally made my choice. The cable type electric park brakes systems were a much cheaper option, however mounting options were limited and the angles I needed to pull the cables from were not ideal. I could have sourced a cheap cable pull motor assemble off eBay listed for Hyundais and alike but needed an ECM to control the process adding to the total expense. Information on wiring and packaging wasn't available, and I could see myself spending months trying to sort it all out.
I already have rear disc brake brakes (VS commodore). The Wilwood kit I purchased were for 10mm rear disc rotors. Even on the Summit racing and Wilwood web sites they didn't list any kits for 10mm rotors. However, on the Rocket Industries site they do. Did the drive yesterday to Rocket and sussed out the kit and purchased.
The kit has a caliper for each side, ECM, harness and dash switch. The calipers are electric park brake only and the original hydraulic rear calipers are retained in the original position. I will have to make the brackets to mount the Wilwood calipers but don't expect this will be reasonably easy process.
Don't know why my photos get turned 90 degrees when posting ? any ideas from the more tech savvy experts on here.
park brake.jpg 275.84K
1 downloads
1 downloads
