The rebuild
847 replies to this topic
#626 _mikecatts_
_mikecatts_
Posted 23 April 2015 - 01:01 PM
Hi all.
well after my little bit of depresion.. family matters.. Im back into it...
I rubbed the last clear down.. (Im sooo over rubbing down) I wasnt to happy with the "depth" that the 4 coats of clear gave me.. so I applied another 4..
Much better now.. good shine off the gun.. will be better when polished.. Ill let it sit now for 6-8weeks.. then block and polish.. Ill have to do the engine bay/boot later as the hardners I have are for 25-35 deg... Not 15-20.. Im not going to spend another $400 on winter hardners/thinners.. I can wait..
It still is a little orangy red as to red red,, but weve been through that.. Its a nice colour.. The clear really throws the colour out.. Looks nice in the sun..
All told.. the paint price is a scam, looks good though, so it should for the price.. Nearly 7k in paint/materials.. That includes everything from sandpaper to rags...
It has 6 coats of undercoat.. blocked down to 4.. 10 colour, blocked down to about 7-8 with 2colour/clear on top. then 4 clear then 4 clear.. should be enough.. Acrylic isnt as thick as 2k..
would of been a LOT cheaper if I chose Protec.. Not for me as I now it doesnt perform... Ill try their brand on one of my "play" cars and compare..
Thers a little over spary on the underneath paint.. Ill get to that later...
Mike
#627 Potta
Posted 23 April 2015 - 01:17 PM
That looks Rally Red to me Mike.
Also looks fantastic.
Good to see you back into it.
#628 _grumpy 026_
_grumpy 026_
Posted 23 April 2015 - 01:23 PM
Mike,
I would love to see this in person, absolute perfection.
G.
#629 _mikecatts_
_mikecatts_
Posted 23 April 2015 - 01:29 PM
sure does.. and ta Craig
Mike,
G.
You probably wont.. This car, when done will go into my other shed for storage,, not to be driven.. Purly an investment for later on in my life... I have plenty of others to fix and drive..
It turned out sooo flat with perfect lines in all the correct placers, which are nice and sharp. Its a very straight car, no ripples/no imperfections in the paint/body at all...
Im happy with the result...
Edited by mikecatts, 23 April 2015 - 01:31 PM.
#630 RIM-010
Posted 23 April 2015 - 01:41 PM
A true work of art mate! It's an inspiration, keep it up :)
#631 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 23 April 2015 - 05:21 PM
Looks bloody brilliant...keep at it, the fun stuff is yet to come.
#632 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 23 April 2015 - 08:15 PM
Mike you should be proud of your efforts and hopefully standing back and appreciating what you have achieved will help you through the hard times that life can throw at you.
Well done.
#633 _Agent 34_
Posted 24 April 2015 - 06:06 PM
Mike,
go bro go !
with the peel the car is sitting up high and you see a lot more of the panel at eye level, once it's on it's wheels then you will really only be looking at the top of the line paint and the bottom will not be an issue.
bloody hell it looks pretty good to me .
i reccon the price you were asking for the car was very reasonable given the work.
it's hump day !
your on the down hill run Bro - Go go Go !
HAAA !
#634 _woosha_
_woosha_
Posted 05 May 2015 - 08:22 PM
Looking good Mike, question how does the car balance up with the trolley you made up for it when you move it around. I was thinking of making one up for my car but was unshore were to mount it out the back, as I was thinking it could be back heavy and tip. Let me know whats it like.
Cheers Woosha
#635 _mikecatts_
_mikecatts_
Posted 06 May 2015 - 05:02 AM
Cheers Woosha
If you notice how Ive mounted the trolley, the back wheels are further back than the mount.. works a treat..
#636 _mikecatts_
_mikecatts_
Posted 06 May 2015 - 05:06 AM
Got the engine bay and boot ready for colour.. I spent some time getting it smooth/flat.. Its just me being fussy....
#637 _duggan208_
_duggan208_
Posted 06 May 2015 - 09:33 PM
You have set a high standard, so much that every thing has to be at least to that standard, if not it will stand out like chrome balls on a black dog. you will need to be fussy now.
Regards
#638 _mikecatts_
_mikecatts_
Posted 07 May 2015 - 06:06 AM
Regards
thats the plan  :-)
#639 _mikecatts_
_mikecatts_
Posted 07 May 2015 - 01:34 PM
picked up some bits I had zinced.. is $250 ok for this lot? I bead blasted them all before giving to him.
Some bits look a bit dull??????
#640 _grumpy 026_
_grumpy 026_
Posted 07 May 2015 - 03:43 PM
Mike,
Seems reasonable to me, I've spent similar. Some bits will plate with different shine, don't know why.
Look"s like you have the rare twin headlight model, lol.
G.
#641 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 07 May 2015 - 04:22 PM
Sounds about right considering there's a few big parts like bonnet hinges and catch. Depending on how coarse the finish from the blasting was can sometimes make the finish a bit dull, I had that with my headlight buckets.
Are you going give them a clear coat to help maintain the appearance?
#642 _mikecatts_
_mikecatts_
Posted 17 May 2015 - 03:00 PM
Hi all... Its a very nice day in SA today.. so I thought I might as well paint the engine bay.. All done.. Prick of an area to paint..
Lucky its 2k...
Used PPG Cobra 2K 60%satin black sprayed wet on wet over PPG D839.
Looks nice..
#643 _mikecatts_
_mikecatts_
Posted 17 May 2015 - 03:10 PM
Ta for that James.. Gives me an idea.. Probably wont.. Ide like it dull over time as per original..
I got another lot done.. small screws etc.. I took a bit more time cleaning these.. a lot better shine.. only $80...He a nice guy to deal with.. if u want his info PM me... Hes behind the old Cheltnham race course just off Torrens road.
#644 _mikecatts_
_mikecatts_
Posted 18 May 2015 - 10:03 AM
Hi all...
Ive been teaching myself how to zinc plate.. Lots of info on the net... Only want to do the bits that you cant see, will save me heaps.. Only cost $40 to set up..
works well... Just have to work out the right time/volts/amps..
The test bits were very rusty, hence the "pitted" finnish.. Just wanted to see what it could do..
#645 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 18 May 2015 - 12:00 PM
Nice work Mike.
#646 _72yellow_
_72yellow_
Posted 18 May 2015 - 02:31 PM
Good read & excellent work so far - body looks great
Nice investment for you
#647 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 18 May 2015 - 05:55 PM
Mike is there anything you cant do? Try gold zinc plating next.
#648 _duggan208_
_duggan208_
Posted 19 May 2015 - 12:51 AM
Very interesting, I remember seeing a kit for zinc plating, a while ago know.
Regards
#649 _mikecatts_
_mikecatts_
Posted 19 May 2015 - 03:29 AM
no kit, just house hold items and some zinc anodes.. its easy..
http://home.comcast....incplating.html
#650 _j.e.d._
_j.e.d._
Posted 19 May 2015 - 08:17 AM
Slar did a write up a couple of years ago too that's pretty good..
http://www.gmh-toran...e-zinc-plating/
