Non GTR + XU1 tag verification thread
LJ Torana tag check GTR or XU1?
275 replies to this topic
#226 _HDT5308_
_HDT5308_
Posted 28 October 2018 - 06:04 PM
Hi Guys
I am looking at buying a 4 door LJ S pack Torana.
The Chassis is : BLJ 32830A
The Body No :94200 A
Paint Colour (currently blue)  Tag colour is : 567-15332
Engine : LD1
Trans M40
Any info on this or where to find this info in this forum would be cool
CHEERS
#227 S pack
Posted 28 October 2018 - 06:55 PM
11/73 Adelaide build LJ Torana S.
Chassis and Body numbers align perfectly for the time period.
567-15332 is Cyan Metallic (Blue)
LD1 is the option code for the 2850cc (173ci) high compression 6cyl engine.
M40 is theTrimatic 3 spd auto transmission.
There should be a long skinny tag on the drivers side of the radiator support panel that has the VIN number on it.
Should be somewhere around 8B69DDL25779*J
#228 _Black betty_
_Black betty_
Posted 29 January 2020 - 08:26 PM
hi all , chasing more info on this torana i am restoring
modelLC82569
Body no 5463A
Trim 180 9 44p
Paint 56712191
Build 5/71 Lc28723a
long tag 82569cl175216
all 3 tags in place , colour electra blue met ,  not on 71 colour charts i can see , cant seem to find any photos . Any idea of original engine or even capacity ?
Thanks David
#229 S pack
Posted 29 January 2020 - 09:09 PM
82569CL175216 is a 4dr Torana SL completed at the Elizabeth assembly plant on the 07/05/1971.
All the numbers you have provided align for the build date.
The original engine number was H36129.
The car was optioned with a 161 high compression engine, M20 Opel 4sp transmission, front disc brakes and 3.08:1 conventional differential.
The body coulour as you have already stated is Electra Blue metallic and the interior colour is Twilight Blue with faux wood inlays in the door trims, the instrument fascia and lower instrument panel.
The car was sold by Dealer 068 Preston Motors, Albury, NSW during 05/71.
Electra Blue finished in production on the 28 June 1971 so the colour shown on this chart is representative of the colour of this car.
Edited by S pack, 29 January 2020 - 09:15 PM.
#230 _Black betty_
_Black betty_
Posted 02 February 2020 - 11:29 AM
Thanks Dave much appreciated  :clap:
#231 _Pinhead_
_Pinhead_
Posted 12 February 2020 - 04:03 PM
LJ GTR identification request.
Hi All
Looking at a LJ to purchase with the following I’d.
LJ 82911
Body no: 298819B
Trim: 1868 50x
Paint: 56715335
11/73
BLJ54634B
8D11LDH298819
Engine no : QL 694819
Any help appreciated.
Cheers Shane
#232 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 15 February 2020 - 11:55 AM
Hi Shane
I sent you a response to this question by PM a couple of days ago.
Bazza
#233 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 11 November 2020 - 10:17 PM
I might be able to move my LC out of it's current location in next few months so thought I'd see what info is available on it.
Has 2 out of 3 tags that look like never been off the car. Body number in guard is there.
The vin tag says 82311CL653802.
Other tag says 12/71 ALC39345A.
Looks like 1 of the last of the LCs.
#234 _gtradam_
_gtradam_
Posted 30 November 2020 - 02:26 PM
Hi Guys, Im after some help, I've been looking at an LC 2-door and before I buy I want to make sure I'm not getting screwed.
The no's on the car look very different to what I've been seeing on other posts.  The seller is certain they are all original tags and it doesnt look like any of the tags have ever been off.
It only has 2 tags in the front left corner.  The body number on the tag doesnt match the number stamped on the actual body? Is this normal? I have photos if that helps.
VIN:82311C1144493
Model No. LC82311A
#235 S pack
Posted 30 November 2020 - 02:45 PM
VIN:82311C1144493
Model No. LC82311A
82311H144493 is an Acacia Ridge built Torana S 2 door sedan completed on the 30/09/1969.
It was originally optioned with LD1 161ci engine, M40 Tri-matic transmission, G92 2.78:1 ratio conventional differential and J52 front disc brakes.
The car was sold in January 1970 by dealer 754 McKinnon Holden in Casino NSW
LC82311A, the A suffix on the model number denotes the car has an automatic transmission.
Note: Cars built before 01/01/1970 were not required to have a Compliance Plate fitted.
#236 _gtradam_
_gtradam_
Posted 30 November 2020 - 03:19 PM
Thanks Dave, did you mean 'C' instead of 'H'?  Is it normal for the body number not to match?
#237 S pack
Posted 30 November 2020 - 04:18 PM
Sorry brain fade. 82311CH144493 is the VIN number. C = LC model series and H1 = Acacia Ridge assembly plant in Brisbane QLD.
The Body number on the Body ID Plate is the number below the Model number, it will be suffixed with a B meaning 'Brisbane'.
The body number normally will not match the VIN number on the PSN tag or the chassis number stamped into the left hand wheelhouse panel, and the chassis number will also not match the VIN number.
Edited by S pack, 30 November 2020 - 04:19 PM.
#238 snuff1966
snuff1966
  • 194 posts
  • Car:LH G pack
Posted 30 November 2020 - 04:26 PM
The dealer in Casino in 1970 would have been DL Cowan & Sons, Bob Mckinnon did'nt take over till the early 80,s. I did my work experience from school and Tech there in 81 and 82
#239 S pack
Posted 30 November 2020 - 04:37 PM
Thanks Dave, Will note that in my info.
#240 _gtradam_
_gtradam_
Posted 13 December 2020 - 06:19 PM
Hi all, Im looking at an LJ 2 Door, it has a compliance plate that matches the body number but doesnt come with VIN or build plate. I have been told I can register in Vic with just the body number (even though the car is in QLD now. My question is what does no VIN or build tag do to the value of the car? he’s definitely not letting it go for peanuts.
#241 S pack
Posted 13 December 2020 - 06:47 PM
IMO, if it is a Torana S then the missing VIN tag and Body ID plate won't make a huge difference to the value compared to if it had all three tags. Perhaps a couple of K?
At the end of the day you have to decide what you believe the car is worth and if it suits your needs.
Edited by S pack, 13 December 2020 - 06:49 PM.
#242 _Up2nogood_
_Up2nogood_
Posted 12 April 2021 - 08:51 AM
Hi guys.
Just looking at a bit of a mess of a car, wanted to check what numbers I have to try and ID it.
BODY 5054-A
TRIM 1823-48F
PAINT 568-13137
Body number (A?) LC34374A
All help appreciated!
#243 S pack
Posted 12 April 2021 - 12:06 PM
Hi guys.
BODY 5054-A
TRIM 1823-48F
PAINT 568-13137
LC Torana S, Olive Green body paint with Sandlewood vinyl trim.
The chassis number and Body number place this car as most likely being completed in late August or early September 1971.
There appears to be quite a batch of Torana S built in this time frame, most are 2250, M15 or M40 and drum brakes.
#244 _Up2nogood_
_Up2nogood_
Posted 12 April 2021 - 01:09 PM
Thank you very much. I'll have the VIN and compliance shortly, will post 'em when to hand.
#245 _Up2nogood_
_Up2nogood_
Posted 13 April 2021 - 02:45 PM
Best interpretation of vin is:
82311GL185721
#246 S pack
Posted 13 April 2021 - 05:59 PM
82311GL185721
Are you sure it is 82311CL185721?
82311CL183721 is the number I expected you to find on the PSN tag.
#247 _Up2nogood_
_Up2nogood_
Posted 13 April 2021 - 08:58 PM
That's the one on the long thin tag. Body number is on the Compliance plate.
#248 S pack
Posted 13 April 2021 - 09:12 PM
Yes the long skinny tag has the Model Number followed by the Production Serial Number (PSN)
The number on the Compliance Plate is the chassis number and it must match the number stamped into the left hand wheelhouse panel.
The Body number is contained on the Body Identification Plate, along with the model number, paint and trim information.
Edited by S pack, 13 April 2021 - 09:14 PM.
#249 _Up2nogood_
_Up2nogood_
Posted 13 April 2021 - 09:27 PM
Gotcha. The compliance plate number matches the inner guard number. ALC34374A.
The only obvious one is the model, LC82311.
#250 S pack
Posted 13 April 2021 - 09:33 PM
Hi guys.
BODY 5054-A
TRIM 1823-48F
PAINT 568-13137
Where did you get this ^^^^ info from then?
